To correct a Memory Card Lock:
one the side of the memory card is a plastic toggle switch, slide it down and up again to reset the switch and then stick it back into your camera.. see if that fixed the problem.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
The CX6330 is designed to work with SD and MMC cards. It will not work with SDHC cards. You need to use SD cards 2GB and smaller.
You cannot use the card on the camera. If you have a card reader or other device compatible with SDHC cards, you should be able to format the card there.
Make sure that you are installing a fresh/ full charge battery Remove the memory card and the battery Clean the metal contacts on the battery using a clean cloth Use the camera w/o the memory card If problem still persist call the Tech Number
I have this camera and it sparked on me back in April and no longer works. I have taken it apart several times in attempts to fix it. If you are still in need I can send you my toggle switch as I'm preparing to trash it.
