Question about RCA Lyra X2400 1 GB Digital Media Player
Does not power on
The Unit turns on with as dc adapter and looks as if its charging but when cord is taken out, the unit does not work. Do i need a new battery?
The tiny LED where you plug the charger in should turn from red to blue when the LYRA is fully charged. If it stays red, I would have to say that you need a new battery. Search for an NP-120 or a D-L17 camera battery on the web. It will work as a replacement.
Posted on Nov 19, 2008
No power ac or dc IFR 1200 super s
Try another Cord/charger, with the EXACT same power specs, without the battery installed. If it works on the AC/DC cord/charger, replace the battery with a genuine battery with the exact same power specs.
Mar 15, 2013 | Computers & Internet
My toshiba a 205-s5825 satellite wont power upo and no lights nothing
The problem is in the power supply adapter, or the dc jack in the laptop is loose, if you move the cord from the power adapter to the computer and it comes back on then it is more than likely the dc jack in the laptop that is attached to the motherboard. The remedy is to replace the dc jack or resolder the old one, in order to do this the computer must be taken apart down to the main board for service.
Jul 09, 2012 | Toshiba Satellite A60 Notebook
My hp scanjet 7800 does not turn on, the adapter has the green led light showing that it is getting power
First get a multimeter and check if the power is going through the adapter to the end of the cord. The AC/DC transformer should output 32V DC at the end going into the scanner. If it has power, then the scanner power switch or the unit itself has failed. If there is no power passing through the cord, then try a new adapter. (You can find some by Googling - I saw some from various vendors.) If it is the scanner itself that has failed, check if it is under warranty.
If it is under warranty, contact HP for service. They may have the power cords as well but I didn't check that far. Otherwise decide if it is worth the service charges.
I hope this helps.
(at least I do not think this scanner has a hard power switch on the side of the unit.)
Oct 04, 2011 | HP Scanjet 7800 Pass-Through Scanner
Unit will not power on// has a solid amber light// turns green for about 3 seconds then back to amber
You may have a bad DC connector:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 17, 2010 | IBM ThinkPad T20 2647 Notebook
Unit will not stay powered up. When plugged into DC power adapter, unit will power up but turns off after a few seconds. Unit indicates low battery. Unit had been successfully used during the previous 24...
Check the fuse on your power cord if it has one. Also try using a different power cord, perhaps one for use inside or use a USB cable if one was provided. Borrowing one or using one at an electronics store as a test may also help.
It sounds like the power cord you are using has stopped functioning and your battery is depleted and requiring a charge.
Feb 16, 2010 | Garmin StreetPilot C330 GPS Receiver
Hello my name is greg and we were having trouble with our electricity and we shut off the wrong sircut breaker and now our WII doesnt turn on but we are unsure if it is the power cord
The best way is checking the power cord with voltmeter or some unit like charger for mobile phone (plug it and look the phone charging).If the power cord is OK plug the Wii AC adapter.If Wii not turn on check the AC adapter with voltmeter.If working the problem is in your Wii console and it need repairing.If AC adapter not work just buy new.
Nov 09, 2009 | Nintendo Wii Console
XPS M1330 issue -- laptop won't charge battery using power adapter which has been replaced. The unit will only work with the power adapter plugged into electrical outlet. How can I tell if it is truly the...
Try another known working battery in the laptop and see if it charges, if it doesn't then its going to be a problem with hairline cracks in the dc jack on the laptop. The solder points underneath the dc jack if they have hairline cracks in them won't allow the battery to charge. Basically the laptop would need to be taken apart and the motherboard taken out.
If you have soldering skills, all that needs to be done is to put new solder on the solder points that hold the dc jack in place.
If after you do this the battery still wont charge then you know for sure the connector is bad and then the connector would need to be replaced.
Aug 20, 2009 | Dell XPS M1330 Notebook
Cx2620 gateway wont turn on
Possibly Need a New DC Jack In Your Laptop... the DC JAck Is The Port Where Your AC Adapter Plugs Into...
Though You SHould as well Check For Proper Power To Your CHarger Cord.. Not all AC Cords That Have Their Lights On Are Able To Charge...
To CHeck If It's The DC Jack... Remove Your Battery..... Plug In the AC Adapter Cord... Power On... If You Get No Lights/ No Power/ No Fans Etc..... It's Your DC Jack
Nov 20, 2008 | Gateway Convertible CX2620 Notebook
Dead laptop
hi there if you are having some problems with laptop starting up then i would look at the power cord that charges your battery and make shure your battery is locked in the slot as well . what type of laptop you have there ? is the power cord adapter still working ? it may not be charging your battery sometimes this will happen before you take laptop to surgury make shure that the power adapter cord is still charging battery ok to do this plug in power adapter and using a multi meter check to see the voltage that is comming from adapter plug ok on the adapter it will tell you the input voltage and the output voltage that you should be reading on your dc multimeter ok try that first ill wait on a fixya soon bye for now
Jul 19, 2008 | Acer Computers & Internet
Battery charge
Simply plug the included power cord into the power input on the DVD player. Leave the unit "off". Allow to build a charge. The included power supply items are:
Flexible power supply: up to 2.5 hours rechargeable Li-ion battery,
12volt car cigarette lighter adapter and AC/DC power adapter
Jan 08, 2008 | Mustek PL-510 Portable DVD Player
RCA Lyra X2400 1 GB Digital Media Player Logo
81 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
