http://www.p4c.philips.com/files/s/spc700nc_37/spc700nc_37_dwv_eng.exeSergio
Todo: Check USB port
Howto:
Refit the USB cable into the port.
Plug the webcam into another USB port.
Use an external powered USB-Hub. Some USB ports on computers do not
have enough power to feed USB devices (this mostly occurs with laptops).
Try to install the webcam on another computer.
Todo: Update your computer
HowTo: Update the USB driver in Windows
USB driver update in WindowsXP
Click
Start ->
Control Panel ->
System
Click the tab
Hardware and then click on
Device manager Click at the bottom of the tree on the + sign before
Universal Serial Bus controllers
Select the first entry, right mouse click and click on
Update driver... Follow the steps to update the USB driver
Windows2000 Click
Start ->
Settings ->
Control Panel ->
System Click the tab
Device manager At the bottom of the tree click on the + sign before
Universal Serial Bus controllers Click on
General USB Hub, right mouse click and click on
Properties
Click on the tab
Driver and click on the button
Update Driver.
Todo: (re)install the latest driver
HowTo:
Deinstall any webcam driver (Philips drivers or webcam drivers from other brands you might have installed in the past)
Cleanup the computer with for instance
CCleaner (select Issues (1) and click Scan for Issues(2). Fix issues if necessary)
Download and install the latest driver.
