FixYa.com
Tags:
Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio CL3500N error code SC581 (by 2 users)
posted by joseph1942 on Jul 24, 2008
Printer is 120volt model, was plugged into 240volts... :~{
Now shows error code SC581.
Q1 - is power supply module likely to fix it?
Q2 - how much has to be dismantled to change power supply?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by office166, posted on Sep 04, 2008
My Printer is a Aficio CL 3500N
I printed to my printer this morning and was printing just fine.
All of a sudden when I tried to print a simple Word Document it says Ricoh Aficio CL 3500N in the reading panel. No error code comes up. I have turned it off, unplugged it, changed the Waste Toner Bottle and tried to get it to respond by exiting, etc. Turned off Computer and then the printer to reset and it just keeps returning the to same thing on the panel. Ricoh Aficio CL 3500N - HELP - Any idea what it would be?
THank You - office@sk-architects.com Ramona
Best Solution
posted on Jul 24, 2008
Helpful (85)
JackHeath
Rank:Guru Guru
Rating: 88%, 47 votes
Q1 - Possibly, I have not seen an SC581 error before. Usually using too much power would give you something like an SC240 error "Power Supply Excessive". So it depends on the extent of the damage. You could also have to replace the main board, motors, etc.
Q2 - You will have to pull back the feeder tray, remove the back panel, there is a cover over the main board and the power supply is below it and fairly easy to get to. But if other components were damaged it could be a much more involved repair.
Rating Locked! (?) joseph1942 has rated this solution as Helpful
Can you Help with these Printers problems?
Light blue lines in the color...
I called Ricoh getting light... Answer This...
SC 486 error
sc error consulte a su tecnico Answer This...
Hi!
I have a ricoh aficio 3500N... Answer This...
how to clean lens on our ricoh...
please tells us how to clean... Answer This...
Richo Printer many white lines...
Strange problem, the printer... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
