Question about Microwave Ovens
Microwave makes loud noise and does not heat. Smell of light burning
Its a 5 yrs old Whrilpool Over the counter Microwave. All of a suden it tarted to make loud noise, 3 times usual level, and food does not heat up. Can smell light burnig.
Can this be fixed? Please advise makes noise and does not heat up
microwave hood combination kenmore
makes noise , will not heat
  • hp429 Sep 16, 2008
    I just installed a used 1000W microwave.  It doesn't heat and smoke is coming out of the vents.  It smells like an electrical part overheating.  It sounds like it is humming louder than it should be.  The 15A circuit breaker popped after running 30 seconds so I plugged it into a 20A.  After 45 seconds it started with the smoking so I unplugged it.  The guy I bought it from says it worked when he bought the house but replaced it during the remodel.  He ran it for about 30 seconds (with nothing in it) to make sure it still worked before selling it.  I read that is bad for them.  I would like to repair it if possible because it was a good deal ($80).  I still want my money back though.  Whirlpool model MH1141XMQ-0.
  • Anonymous Mar 29, 2014
    Intello Wave Even Heat System
  • Microwave Ovens Master
  • 9,098 Answers
Chances are you have a bad magnetron.
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 28, 2008
3 Suggested Answers
SOURCE: Microwave makes loud noise and does not heat. Smell of light burning
replace it
Posted on Aug 07, 2008
shaggyrat
  • 1224 Answers
yes anything can be fixed but a do it yourselfer i reccomend against this cause thats a radiated element in the micro
recommend go out and purchase a replacement go with G.E. they have the 7 year warranty great little micro. too change out is easy
Posted on Jun 02, 2008
Loud boom and burning smell in microwave
Is there any holes burnt into the liner inside the micro wave.? Or burn spots showing.? If there is thow it out. It is not safe to be useing it.It could start on fire. That problem is from when they are not clean out once in a while. End food is burn,t onto the interior liner end grease end oil,
Oct 22, 2012 | Sharp KB6001NS 24 Inch Microwave Drawer...
We were using the microwave the other night and it started making a loud noise like the fan was running (although the fan was not). We let it sit for awhile and try to use it again but the noise came...
The loud noise and no heat means that the magnetron has failed. It the part that generates the microwaves that heat the food. When it fails it shorts out, causing the transformer to heat up. That is what was causing the burning smell. The cost of a replacement magnetron is around $130-150 range so it may not make sense to have it fixed.
Mar 24, 2011 | Maytag MMV4205 Microwave Oven
Generic problem for all Kenmore Microwave
Loud hum is usually due to faulty hv diod, resonance capacitor, or the magnatrone feed thru capacitor , chk it with a ohm meter , one by one n replace it .. zaheer Islamabad
Dec 31, 2009 | Kenmore Microwave Ovens
Sharp R-7A82, buzzing/no heat
buzzinsg / humming / loud or louder than normal .is probably the mag / it has failed and the trans is making that noise . if older than 5 yrs I would replace ans the mag is 100.00 + and w / labor you have paid for a new on but have the old one .**** ..
Dec 23, 2009 | Sharp R-630D Microwave Oven
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
Jun 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE profile spacemaker micro XL1800
It sounds like your magnetron has failed.
I would put a cup or so of water in it and heat it for about 3 minutes.
Then check inside and see if you smell any electrical burning or other smell.
You should have a 5-year warranty on the magnetron.
GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Feb 06, 2008 | Whirlpool GH8155XJ Microwave Oven
Microwave Ovens Logo
1,832 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
