Question about Brother IntelliFax-2820 Laser Fax
Paper jam will not go away - Brother IntelliFax-2820 Laser Fax
  • doyleroof Jan 02, 2009
    We cleared the paper jam from the front cover. Now the machine is still insisting that there is a paper jam. But then it changes and says to remove drum. We have put in a new cartridge but it hasn't helped. There are no other obstructions to be removed.
    Sergeant:
  • 329 Answers
What model??? Doors are not closed or the jam detect switches and there are ussally three or four, are broken, out of place or stuck. On common one to move ofer and stick is on the multifunction in the document feeder....
Posted on Aug 28, 2008
Printer has new ink & wont print also has paper jam
The paper jam is the problem.
Clear the paper jam, recycle (Turn off, then turn on the printer) , and the other problems will go away by themselves.
Oct 25, 2015 | Office Equipment & Supplies
My Brother Intellifax 5750e has paper jam issue. The paper jam sign will not go away. I took out the paper that was jammed. Still problem.
take your drum unit/toner out and close door to see if "jam" goes away. if so, look closely on bottom of drum unit in the middle. may be a scrap caught in there. if jam doesn't go away, you may have a piece caught in the fuser which is just b4 paper exits and that area is not easily accessible w/o tearing machine down.
good luck,
razors
Jul 28, 2011 | Brother IntelliFAX 5750e Laser Fax
There is a document jam 1. After I remove the paper and code goes away, the printer may print a page or two and then jam again. I have tried a new pack of paper (fanning it) I have tried a new...
You refer to a document jam then you mention fanning new paper but that refers to a paper jam.Which one is the problem? What does the screen say? If document jam then its your originals you are copying. If paper jam then its the paper in the machine. I cant help you any more because your do not state the make or model. Please repost with a lot more detail. Cheers
May 16, 2011 | Office Equipment & Supplies
There is still error 2 even after restart the printer (canon mp145). How to reset this error?
(remember to vote this solution plz)
I use a Canon MP210 myself, its a Pixma like yours. Anyways, Error 002 or 02 means theres a paper jam. Sro if you can fix that jam it will go away. If your looking at the printer and you cant see any jams still, the printer still thinks it is jammed, so heres what I would do.
  • Turn off the printer.
  • 3
    Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • 4
    Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • 5
    If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • 6
    If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • 7
    If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • 8
    Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • 9
    If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  • Still? Take a cereal box of cardboard (cut the back/front , push that through the paper trayand get your hand on the other side and work it like your flossing your teeth)
    Yes that works.
    Thanks
    Rhos Barnes, MCSE, CCNA
    Squamish, BC
    rhos_2k@yahoo.com
    Jan 23, 2011 | Office Equipment & Supplies
    Hi, I have a 200.00 paper jam in areas a and c. The paper jam has been removed but the error is still not going away. I have pulled out every thing that can be pull out and checked with no luck.
    check any dis alignment on the paper jam sensors..or check any posible broken wire on its harness that leads to the paper jam section..
    .....kenthbats
    Jun 07, 2010 | Lexmark C920 Led Printer
    Copier keeps telling us there is paper jam, we have looked where screen shows jam and find nothing. We have taken out the paper tray, still don't find even a tiny scrap of paper anywhere.
    There are several possibilities. After you inspect for the Jam and close the drawer, does the copier come to ready? Have you checked the behind the doors on the right side. If the copier comes to ready and you press the start button does the copier jam right away. If so check the dial on the paper drawer and be sure its set to the right size paper. If its not the copier will jam, right away. It is important with a Canon to check all areas and open both the paper drawer and the right side doors when checking for jam, if the right sequence is not followed in checking for jams the jam may not clear. If still Jammed you might take some canned air open the right side door and blow out the paper feed area, a sensor may be blocked or dusty. If all else fails turn the machine off and un-plug it from the wall, let it set a few minutes and plug it in and try it again.
    May 20, 2010 | Canon imageRUNNER 2000 Copier
    Got a paperjam. Pulled out the paper, but the paper jam error won't go away and the printer won't print. I read that it may be the paper jam trigger spring that is out of place now and requires...
    No it's not. Make sure to open EVERY door on the printer and check for any additional paper. Also, power the printer off and back on a few times and see if it goes away.
    Dec 24, 2009 | Canon imageCLASS® MF4150 All-In-One Laser...
    Paper jam
    IS IT THE PAPER JAM LIGHT? LOOK IN THE PART WHERE THE PAPER COMES OUT OF THE MACHINE IN THE CAVITY ON THE LEFT SIDE FIND THE EXIT ROLLERS IS THERE ANY PAPER THERE? PULL OUT YOUR PAPER CASSETTE ALL THE WAY LOOK IN THAT CAVITY. OPEN THE RIGHT HAND DOOR THERE IS A GREEN ARROW THAT MOVES THE GATE LOOKIN THAT AREA. HOPE THIS HELPS IF THESE DO NOT FIX YOUR PROBLEM YOU NEED A TECH TO LOOK AT IT.
    Dec 31, 2008 | Sharp AL 1631 Copier
    Lexmark x1270 paper jam
    hah - I had this problem on my old 1270 - there is a jam - its just very small - mine was caused by half a peanut lodged under a pickup roller - take the back paper guide off and check carefully - it might just be a piece of grit - the paper will skew away from the point of the jam so see where it skews and check around there
    hope this helps, cheers
    Dec 07, 2008 | Lexmark X1270 All-In-One InkJet Printer
    Paper jam
    Very frustrating ... checked all over for remaining jams - but the message "paper jam" just won't go away after clearing a paper jam. Eventually, it goes away but no way to predict how long it will take!
    Feb 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
    Brother IntelliFax-2820 Laser Fax Logo
    289 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
