Question about Canon PIXMA iP8500 InkJet Photo Printer
Uneven borders I am currently trying to set up an IP8500 to print with an even border around the image. I?ve checked the Photoshop printer dialogue box for ?centre image? yet there is a significantly bigger border at the bottom and to the left. The ?Specify Margins? in Page Setup of the printer?s dialogue box are all set to 0. Any help greatly appreciated.
  • Justin321 Jul 24, 2008
    Where are printer settings found to align this?
    thanks very much
    Sergeant:
    Champion:
  • 214 Answers
Go to printer settings and align it
Posted on Jul 24, 2008
  • Subhendu Das
    Subhendu Das Jul 24, 2008
    here are the steps to be followed:
    strat-printers & faxes - right click the the printer icon - select properties - maintenance - print head alignment
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Uneven borders how do i fix it
If you are trying to do this by setting borders manually you are probably running into the Canon's minefield of "minimal printed borders" which throw off calculations. The manual setting is primarily for off-setting images rather than for perfectly centered images.
For a centered image, the borders are automatically set by the relationship of image sizing to paper size, with "center image" checked and other sizing options unchecked. This has worked perfectly in the three Canon printers I've owned, whereas trying to set even borders manually was always off a bit and a real pain.
If you want the same border width for all sides, the aspect ratio of the paper and image will have to be different, strangely enough, for all but square images. For 1" borders all around on 10x15 paper, e.g., your 2:3 AR image will have to be cropped and sized to 8X13" dimensions.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For Canon Printer Support
Mar 07, 2014 | Canon PIXMA Office Equipment & Supplies
Cannot load template to Sony UP-CR10L, how can I copy the custom made tempalte to CR10L?
You need to copy the border you created in the border creater software to a border folder on you computer that you have created to store you borders in.There is a folder on the CD that came with the machine that
I would suggest you copy to your hardrive as this will need to then be copied to a compact flash card that is then installed in the expansion slot on the inside of the ribbon carrier door.If you save your new border to the folder on you hardive you can always back it up at anytime.If you
print different sizes you will need to create a border for each size of print. Once you have installed the card in the machine switch it on and
go to the print option screen and you will see the border ikon is not greyed out but now active simply select this option and the the border you require.Then it should print.
Sep 18, 2009 | Sony SnapLab UP-CR10L Digital Photo...
How do you do borders in Photoshop please
The easiest method to make borders on your images is by using the ‘stroke' command in Photoshop.
To do this, start by pressing “Ctrl-A” to select the entire image, go to “Edit” on the menu, select “Stroke”. You will then choose how thick you want your borders to be in px (pixels), what color, and where you want your border to be placed in the image (inside, center, or outside).
Hope this helps.
Aug 17, 2009 | Computers & Internet
Problem with printing borders, and with cartridge.
Hmm, I got the same problem once in my university LABs.
What i do was the same you have done, but do try again because if "some side" of the border is not been printed, then its the "Border Setting".
Try using Ms Word 2007.(I guess you are already using it)
Goto Page Layout Tab > click Page Borders (Borders and Shading dialogue will appear) > Then insert a border, apply it.
Now again go there, and this time in the bottom right corner of the dialogue box, you will see Options button, click it.
Make the Margins Maximum (31pts) (Measure from : Edge of Page)
if this doen't work, then;
You can also change the margins but now (Measure from : Text)
But the first one works for me perfectly.
before doing this all also re-insert your blx/wht cartirdge.
  • If helpful, Kindly do Rate
Jul 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
HP C4480 Won't Print Borderless
Most pix you shoot are not exactly 4x6 which will leave white edges top and bottom- Sides Try using the HP software- see if any difference Inkypete
Apr 22, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Kyocera fs-1030d wont print frames on MSWORD2000
wrong... the kyocera only prints what you send to it... you need to go into your print settings and make the adjustments so it can print frames borders/ shadings... this has been my experience with explorer and photoshop... not very much fun but necessary...
Mar 06, 2009 | Kyocera Mita FS-1030D Laser Printer
Image is partially cut off when printed
Your expert patiently talked me through several possibilities. Finally, in the print set-up window, I clicked on Properties in the upper right and made all my printing choices there. I still got a border, even though I didn't want one, but it was all the way around the photo...not on two sides, and the photo was not chopped off.
Aug 11, 2008 | HP Photosmart 325 InkJet Printer
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
Canon PIXMA iP8500 InkJet Photo Printer Logo
162 people viewed this question
old marine
old marine
