Question about Sony Ericsson K510i Cellular Phone
Navigation Pad is not working
My 5 way navigation pad is not working
sometimes the right one does, but most of the time all of them don't work.
what do i have to do
  • mikeboy1000 Jul 24, 2008
    thank you very much, but how do remove the LCD ?
    thank you.
    Genius:
  • 1,011 Answers
Dear,
unscrew ur phone and use a contact cleaner. spay on it or if u dont have in spray form then put a drop of liquid contact cleaner on the navigation pad and simultaneouly press keys many times one by one. DONT FORGET TO REMOVE LCD FIRST BEFORE DOING THIS b'coz contact clearner can damage it.
after cleaning install it back but very careful for it.
Posted on Jul 24, 2008
  • SALMAN NASEER Jul 24, 2008
    dear,
    remove the casing first. then u will see two screw on the bottom side and two on the upper side. unscrew it with it with common small starick screw driver. then remove the jack of lcd carefully and also remove the lcd carefully because there are two or three folding of reflecting sheets inside it. there is only 1 LED that provide light to whole lcd . the main work is off reflecting sheet. so becarefull. dont touch much the sheets because those are sensitive to oily hand or dust.
    its a trick but u can do it with a lot of care,
    regards,
How do i get my phone to send pic messages it just says invalid destination address every time i try to send a pic message?
This is from the following link: http://www.verizonwireless.com/support/knowledge-base-83298/To
Take and Send a Picture via Messaging.
  1. From the main screen, navigate: MENU > Media Center > Picture & Video.
    Utilize the 5-way navigation pad to highlight and the center button to select.
  2. Select My Pictures.
  3. Select a picture then press the right Soft key to choose Options.
  4. Select Send.
  5. Select Picture Message.
  6. Enter the 10-digit mobile phone number or email address then select OK.
  7. Select SEND.
To send an existing picture this is from the following link:
Send an Existing Picture via Messaging Samsung Convoy Convoy 2
Send an Existing Picture via Messaging - Samsung Convoy™/ Convoy™ 2
  3. Select the picture then press the right Soft key to select Options.
  4. Select Send.
  7. Select SEND.
Mar 03, 2016 | Samsung Convoy Cell Phone
My LG VX 8550 phone was not working properly so i brouth it into the Verizon store and they replaced it with a new one. My music is downloaded on the memeory card which was placed in th enew phone which is...
may be files in the memory card are corrupted or the software which is needed to play the format is not installed ...
if that software is installed then there may be some firmware problem ....
try giving the restore factory settings once if there is any firmware problem it will be solved
Jul 01, 2008 | Cell Phones
Hello sir my name is makarand kelkar i'm 4m mumbai my cell phone is nokia 5130 my cells kye pad is not work properly means navigation key of left & right & also go to key and music kye...
The Navigation key set can be changed, it will cost around Rs.250.... Just take it to a mobile repair shop and ask them to change the key navigation board. It is very simple, even you can buy the spare and change it yourself... But the music keys I'm Not sure they will work or not, because it is a well known complaint in Music series of Nokia and nothing can be done properly(so don waste time in spending money for music keys)...
May 13, 2011 | Cell Phones
I WAS SETTING WIFI ON MY HP PRO BOOK 4520S AND SUDDENLY MY MOUSE PAD AND NAVIGATION KEY STUCK AND NOW IT IS NOT WORKING KINDLY GIVE SOME BETTER INSTRUCTION TO MAKE MY LAPTOP WORK SAFELY
Do not worry .. You disabled the touch pad by mistake .
Press two times the touch pad area where you can see yellow light...
two times press make it lock and unlock both......
Mar 31, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
I forgot the unlock code for my HTC Ozone. I bought it from a friend,who bought from a friend....anyway I can bypass it?
  1. You will have to restore it to factory settings (hard reset) . Im assuming since the phone is new this isnt a problem. Follow the steps below
  2. From the Today screen, press the left soft key to choose Start.
  4. Select System Tools then press the center of the 5-way navigation pad.
  5. Select Clear Storage then press the center of the 5-way navigation pad.
  6. Select Factory Default. Enter 1234 then press the left soft key to choose YES.
Please leave me a rating if Ive helped you :)
Mar 11, 2011 | HTC Cell Phones
The screen is stuck on the align screen i reset the phone and attempted to reload windows mobile and when the align screen came up i tapped it but it wont go away
Did you perform a hard reset? To do this:
  1. Slide open the device to expose the QWERTY keyboard.
  2. Press and hold the center of the 5-way navigation pad.
  3. While holding the center of the 5-way navigation pad, use the stylus to gently press and release the reset button.
  4. When Clearing Data... appears on the screen, release the center of the 5-way navigation pad.
  5. When prompted, tap the screen to setup the device.
Sep 07, 2009 | Samsung SCH-i760 Smartphone
Hard reset
Hi Friend,
You can't hard-reset it on your own, that can only be done by a Nokia Care Center by flashing the firmware again on the phone.
The phone itself only offers a "soft" reset which only resets the settings.
if you mean a master reset (back to factory settings)
From the stand by screen, select Menu by pressing directly in on the navigation pad.
Scroll to Settings, and select by pressing directly in on the navigation pad.
Scroll to Restore Factory Settings, and select by pressing directly in on the navigation pad.
Enter current Security code and select OK by pressing directly in on the navigation pad.
NOTE: Default Security Code is 12345.
Regards,
Ayyasam
Jun 04, 2009 | Nokia 6085 Cellular Phone
The Navigation up and right button stops working. please give a advice.
one rubber pad or studs is there under the navigation you r using keypad somany times no thats way that rubber pad loose that strenth, or that rubber pad move little bit side of the coorct position, so you remove your phone panel and re insert that pad.
Jan 24, 2009 | Sony Ericsson Walkman W810i Cellular Phone
Buttons losing function
If these phones are still under warranty, take them back. It is a motherboard issue. I hope this helped.
GOOD LUCK!!
Nov 10, 2007 | Sony Ericsson W300 Cellular Phone
Sony Ericsson K510i Cellular Phone Logo
49 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
