Question about Toshiba Satellite M30 Notebook
Toshiba laptop has a corrupt operating system
When the laptop starts up, an error message says one of the operating system files is corrupt and windows XP will not start. How can I do a system restore or reset without the restore CD?
  • 300 Answers
I will assume that the operating system that you have is XP. If you can give me the exact error that comes up when you start I will be able to give you more detailed information. Until then, here is a link that details how to run system restore in safe mode, which may help if it is a software issue.
http://support.microsoft.com/kb/304449
Here is an explanation of the screens that you will see when System Restore starts.
http://www.theeldergeek.com/system_restore.htm
Thanks
Posted on Jul 24, 2008
    Master:
  • 397 Answers
When you switch the laptop on, tap the F8 key a few times and the machine should boot to a black page with white lettering.
You will be given options of "boot" you can try "last known good configuration" but I would opt for "safe mode".
If you can get into safe mode go to Start>Programs>Accessories>System Tools>System Restore and then select a time and date to restore your machine back before this problem started.
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Shut down
Possible corrupt operating system. The cause of corrupt operating system is Windows file corrupted or virus infected Windows.
Solution corrupt Windows files:
1. START - All Programs - Accessories - System Tools - System Recovery Options - System Restore (restore to the date when the OS is still normal)
2. START - All Programs - Accessories - System Tools - System Recovery Options - System Image Recovery (restore using a backup system that you created)
Solution files corrupted due to virus infected windows
Update anti-virus and virus scan (if the virus is detected, the primary action = repair, secondary action = quarantine). Then repair the operating system with System Restore or System Recovery Options.
Note:
If the operating system infected with virus (virus infected not long ago), the best solution is to use System Restore. Restore to a date when the windows are still normal.
Nov 13, 2011 | Toshiba Computers & Internet
My toshiba satellite pro/ 415cs laptop wont start up / says it needs a setup disk
If you are using the OEM operating system from Toshiba, use the disc which came with the laptop. But if you are using a retail operating system from Microsoft, use operating system setup disc.
You can attempt to use the appropriate disc to repair corrupted files. Take note that some Operating system files are unrepairable which leads you to installing the whole operating system.
Hope this helps.
Jun 16, 2011 | Computers & Internet
Can you solve the problem for my lap top Toshiba satellite E105-S1402, I am not able to register my finger print on TrueSuite Access Manager Finger Print. The error message come "failed to open the sensor"
You can try to download and install the Fingerprint Utility here and check if you will receive the same error message.
Refine Search by: Your Operating System (Vista by Default)
All Categories: Security
Title: Toshiba Fingerprint Utility for Windows Vista / XP
Download and Install
If the reinstallation of this software does not help then the issue must be related to a corrupt Windows Vista files and in my opinion the usage of the Toshiba recovery CD should helps.
Thanks for using Fixya
Jul 29, 2010 | Toshiba Computers & Internet
Can not start window vista operating system?
this error is the system corruption error and indicate that the system files have gone bad due to some reason. system recovery can be done to relode the operating system//
shut the comp off // restart it and start tapping f10 key on the keyboard// go to recovery option and follow the steps to do system recovery// remember you will loose all your documents which is saved if you do not have the backup on external HDD.
but there is no other alternative/ the HDD will get formatted and the o/s will be reloaded in new way/
your system will be as good as new // if f10 will not work then you will have to call toshiba support and get the new set of recovery cd to do the recovery on the computer//
May 09, 2010 | Toshiba Satellite A215-S4747 Notebook
''ERROR ON LOADING THE OPERATING SYSTEM''
ur boot file are corrupt...
or ur main OS files that load Win is corrupt....
re-format and load OS
u need a Win OS disk to install.
Dec 28, 2009 | Computers & Internet
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Laptop won't boot up
This is an operating system error, and sometimes indicates a hard drive failure. Start by running a system repair with your recovery or operating system disc. This usually takes care of it, if it doesn't, reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced.
Jul 31, 2008 | Toshiba Satellite A70 Notebook
Dll error
This is an operating system error. You will need to run a system repair or reload with your recovery or operating system disc. Start with a repair, if the repair doesn't fix it, then reformat and reinstall the operating system. If you have any issues or problems during the format or reload, then your hard drive has failed and will need to be replaced.
Jul 20, 2008 | Toshiba Satellite A75-S231 Notebook
Toshiba Satellite M30 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
