Question about True GDM-9 Beverage Cooler
Interior Lighting on True Refrigerator Unit
The inside lights went out in my True Cooler. I replaced the bulbs but this did not correct the problem. Is there a starter to replace? Where is it located?
  • nevillepoots Aug 26, 2008
    can't find the ballast on 3 door true refrigerator
  • drmike011 Dec 11, 2008
    same problem.......new bulbs, still no light. Is there a ballast or a starter to replace or check?
  • 122 Answers
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Posted on Sep 23, 2009
What size light bulb for a GDM 12 coke fridge
  • Safety shielded fluorescent interior lighting.
  • Cabinet lighting utilizes electronic ballast and T-8 bulbs for brighter illumination, longer bulb life and increased energy
  • Remove yours and take to THD or Lowe's. Could call first; make have to go to specialty lighting store if not available at the DIY stores.
    Mar 05, 2014 | True GDM-12 Refrigerator Commercial
    Interior light and temperature light not lighting up. Worked when first plugged in, then shut off.
    take the bulb out and check it with a meter or put it in a lamp to see if it's good,if it is good then you either didn't screw it in correctly or the light switch is bad and needs to be replaced,i've gone in and found the bulb not in correctly,you can turn it in and cross tread it.look where the door closes in,you'll find a switch that the coor hits to shut off the light when it closes,try pushing the switch in and out to see if the bulb lights,if so change out the switch.
    Sep 06, 2012 | Refrigerators
    Interior lights problem on a 2006 Lexus SC430
    Only one light inside light works on my Lexus SC430 and I have been told that I have to replace the whole part which is about $700 because it is computerized. Is this true
    Aug 10, 2012 | 2006 Lexus Sc 430
    Light bulb replacement what size? cannot find one to fit
    Most appliance take a standard bulb similar to this:
    http://www.reliableparts.com/product/inv_240436702/Appliance-Light-Bulbs-461460
    My experience is that most stores with a lighting section will stock replacement bulbs for ovens and refrigerators. The best thing to do is to removed the burnt out bulb and take it along with your to the store to make sure you match the replacement.
    According to your manual your interior light is a 40 watt appliance bulb.
    Trust this is helpful.
    Apr 21, 2012 | KitchenAid KSRP25FNSS Side by Side...
    Elite trio, 795.755 Refrigerator light stays on, getting hot. Refrigerator space warming up to 45 degrees. Pressing in both door switches gives no clue. Both feel smooth.
    Some of these Kenmore Elite refrigerators built by LG have a design defect that has been the subject of a class action settlement. The interior lights stay on even if the doors are shut, turning the refrigerator interior into a version of the child's Easy Bake oven toy. There are many cases where plastic interior parts of the refrigerator got so hot they melted. I replaced the 60W incandescent bulbs with 7 Watt LED bulbs just in case. The LED bulbs will not get hot enough to harm anything even if left on indefinitely.
    This model also has problems with the wires inside the door (water dispenser side) The wires break inside the door and are not replaceable. I ran new wires through the interior and bypassed the broken wires to avoid buying a whole new door.
    May 21, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
    Dash board doesn't light up
    remove dash to the bulb components (the layer of dash with only bulbs[looks complicated]) turn dash lights on and identify wich bulbs are not working, replace them with the correct bulbs. if this is unsuccesfull find the connection from the bulbs to the wire and also the connection from the wire to switch. ensure the components inside the connextions are clean(pull apart and check for rust, dust, dirt ect..) you can buy connection cleaner from most car orrientated shops.
    Nov 24, 2009 | 1991 Nissan Pickup
    The light bulb burnt out. It is located in the center of the fridge between the two doors. I'm not sure how to remove the bulb in order to replace it.
    Unplug the cooler to avoid a shock. Try pulling bulb up and then out from bottom. The bulb should be resting in spring loaded receptacles.
    Nov 13, 2009 | True GDM-49-RC Refrigerator
    Flourescant lights flickering
    is there a ballast or a starter? if there is a starter (little silver metal or white plastic can), then replace the transformer inside the lamp housing. if there is a ballast (long black rectangle with many wires) and you replaced that and the lamp, then there must be a power drain in the unit somewhere.
    Aug 25, 2009 | True GDM-12 Refrigerator Commercial
    Replacing temperature control on a True beverage cooler
    Remove the doors, then the evaporator cover. Just be careful.
    May 20, 2009 | True GDM-7 Beverage Cooler
    True GDM-9 Beverage Cooler Logo
    570 people viewed this question
    Top True Refrigerators Experts
    Dennis Boxerman
    John Tripp
    John Tripp
    Are you a True Refrigerator Expert? Answer questions, earn points and help others
