When i turn on my computer it appears with a windows boot mananger and wont leet me acess my computer
    Problem Solver:
  • 19 Answers
That would be an administrative isssue contact your computer maker webside and seek support thru their tech help.... good luck
Posted on Jul 24, 2008
Im trying to reformat my sAmsung laptop but i cannot find the cdrom to first boot, only the hardisk and windows boot manager will appear!.,.thnkx
You may have to go into the setup (BIOS) and check to see that the CD-ROM is enabled as a boot device. Some BIOS allow you to disable the CD-ROM as a boot device. It would not be listed in the boot manager if that were the case.
Dec 22, 2014 | Samsung Computers & Internet
Dont startup
1 Turn on the computer.
2 As the computer starts, press <F8> on the keyboard until the Advanced Boot Options menu appears on the screen.
new_note.jpg Note: You must press <F8> before the Windows logo appears on the screen. If you press <F8> after the Windows logo appears on the screen, the Advanced Boot Options menu will not appear on the screen. If you do not see the Advanced Boot Options menu, restart the computer, and then repeat this step until you see the menu on the screen.
Dec 14, 2013 | Dell Inspiron 1501 Notebook
My husband is trying to acess the bios to set the pc back to factory setting cause the cds wont boot what function key will allow him to boot bios
To open the BIOS Setup screen:
  1. Turn off the computer and wait five seconds.
  2. Turn on the computer.
  3. When the first screen displays, immediately press the F10 key if your computer was built in 2006 or later (came with Vista or Windows 7). Press the F1 key if your computer was built before 2006 (XP or earlier). Press the key once every second until a BIOS Setup utility screen opens.
  4. Use the keyboard to move through the menus.
Sep 24, 2010 | HP Compaq Presario 6310US (DA201A#ABA) PC...
Problem with boot mananger will not boot windows
i suggest you reformat your system..
you are experiencing system error or corruption of system...
best way is to format it so you can use it again...
Feb 06, 2010 | Advent Netbook
I have a new acer notebook,aspire 1410-2954. i set it up, turned it off and then back on, and would no longer let me in. it keeps saying wrong password, and it wont even let me change password.how would i...
Back up any files you want to save
Note:
3 Press the <Down Arrow> on the keyboard to select Repair Your Computer on the Advanced Boot Options menu, and then press <Enter>.
4 Specify the language settings that you want, and then click Next.
5 Log in as a user who has administrative credentials, and then click OK.
6 Click Acer Factory Image Restore.
7 In theAcer Factory Image Restore window, click Next.
8 Click to select the Yes, reformat hard drive and restore system software to factory condition check box.
Dec 26, 2009 | Computers & Internet
Blue screen with windows xp can't boot from cd
Most toshiba will boot if you press F12 and a boot screen will appear . the bios is most of the time acessed through F1 or F2 try that and let me know what happens
Nov 07, 2009 | Toshiba Satellite A135-S2246 Notebook
Unable to boot
Hi there.
To run fdisk from DOS, you will need the Win98 boot disk instead of the 95 one, it has more option available to you while you are in DOS mode so a 98 boot disk will do the trick.
Thanks for choosing FixYa!!
May 30, 2009 | Intel Pentium MMX , 200 MHz
Mult.i. bo.o.t screen.... .on .turn o.n and .do.t.s.....
Go to the device mananger. Hold down the windows key and press the Pause/Break key. Go to the Advanced Tab, Then Settings under Startup and Recovery.
You can uncheck to display the startup menu and you can also edit the boot.ini right there.
and remove other boot option that appears at start up
The other thing youve mentioned
means this disabled by infection
now there are 3 software that you should download and run in order to fix this issue and any future infection
1.malawarebytes
2.combofix
3.trojanremover
These are poison pills for such infection also they are freeware
Thanks And Regards
kindly rate this solution
May 13, 2009 | Fujitsu Siemens (MAN3184MCB) Hard Drive
My system has booting problem. its not leeting ot login
Try to boot in safe mode. Press F8 constantly till you get a screen with many options. Select Safe Mode. It may take some time to boot. Scan for viruses. If no viruses found insert windows cd and select "upgrade". (NO New Installation).
Dec 17, 2008 | Computers & Internet
I have a terrific problem / Tengo un terrible problema
Run a repair in Philips Device Manager
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Computers & Internet Logo
David Payne
David Payne
