Regarding Acoustic Research Speaker model AW811-----------I was using the speaker and for some reason it stopped playing. I don't know what happened. Can you help. I know have 3 of them. Do you have a phone # to call? Thanks
  • 2,071 Answers
Check the speakers resistance if not open , use a multitester for checking and there connection if not loose.post a message whatever the result...
HOPE THIS MAY HELP;
REGARDS,
VOTIT
DON'T FORGET TO RATE
Posted on Jul 25, 2008
I have 1 speaker of Acoustic Research of 312 HO.
you have only one? or one pair? this standing speaker need a Amp to drive.
Apr 23, 2013 | Acoustic Research Audio Players &...
Looking for an owner's manual for Acoustic Research 310HO loudspeaker. I would like to know the correct crossover frequencies for bi-amping.
Try
mauritron.com
They have the world's largest library of
owners user instructions operating guides
and
technical repair schematics circuits service manuals
I'm not connected to them, just a satisfied user.
Also if you don't find your item in their listing then ask and they will get it for you
Sep 17, 2011 | Acoustic Research 310 HO Speaker
I love my speakers, but when iTunes stops playing music, they make a horrible scratchy crackling noise....any suggestions?
is your itune also connected for charging when you connected to your speaker? it could be the possible causes during itune finish playing the internal charging noise from switching supply adaptor come into the audio line get into your speaker, so you may hear the noise. If this is the problem, you may try to use differentiate line in isolator. mostly people use in the car to isolate engine alternator noise. you can find in car accessories shop.
Jul 20, 2011 | Acoustic Research AW825 Main / Wireless...
My Acoustic Research HTB-80 Speaker Bar stopped working after a storm. No lights/power. Is there any fuses in the unit that I should check?
if your unit come with external Adaptor power up type. then mostly is the adaptor already blown, replace the adaptor will do.
Jun 24, 2011 | Acoustic Research HTB-80 Speaker
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
Cuoul i replace the tweeter with any 1 inch tweeter other than acoustic research?
Providing you match the power and ohm rating of the acoustic tweeter yes. You could of course have an higher rms/watts rating than the original, but not lower. The ohm though must be the same. The only thing that might happen is that it might sound different to the other speaker, as the tweeter sound quality could be better or worse than the acoustic. Of course you could buy two and replace the other speaker one too!
Feb 14, 2010 | Acoustic Research AR PS2262 Main / Stereo...
TRANSMITTER FOR A AW811 NO LONGER WORKS.. DID WORK TOO LONG AFTER I GOT IT...HELP
did you change the distance between the two ? assuming they are plugged in, does a power light come, maybe a fuse.
Feb 05, 2010 | Acoustic Research 900MHz Wireless Stereo...
Can Acoustic Research wirless speakers be used for surround?
yeah, I looked it up on thier website. Here is what they say.
Warning: This product is designed to work with line level outputs or headphone outputs only.
DO NOT connect it directly to speaker outputs as it will permanently damage the transmitter.
You can use these as surround speakers if you like. You just need a line level surround output on the receiver. Most high end receivers have this feature but, you may only have speaker level outputs.
If that is your case the only option you have is to use a "speaker to line level adapter".... http://www.crutchfield.com/p_543ADP12/Russound-ADP-1-2-Speaker-level-to-Line-level-Adapter.html?tp=9070
Now crutchfield.com is always a little high on prices but if you look around I have seen them around $10 online.
Good luck with your project.
Jan 28, 2009 | Acoustic Research 900MHz Wireless Stereo...
Acoustic Research ARS115PS Subwoofer, No Sound
I have the same problem with the smaller AR 112PS speaker and since Acoustic Research went out of business, I too have been looking for a solution. I may have found an alternative to throwing away this really nice speaker. I found a company on the web that appears to sell an amp that may fit nicely into this speaker enclosure for $99.00. Check it out...
http://www.partsexpress.com/pe/showdetl.cfm?DID=7&PartNumber=300-805
Tenderfoot56
Feb 27, 2008 | Acoustic Research ARS115PS Speaker
 Grubhead
Grubhead
