Question about Samsung SYNC SGH-A707 Cellular Phone
Phone will not power up
Even after charging the phone just flashes once in a while but will not power up.
  • Silos Jul 31, 2008
    Having very similar problem. Phone was fine last night. Checked it today and it will not power up or down. Screen just flashes on and off with no picture. Tried another battery in this phone- no change. Tried this phones batter in another phone- battery is full and works fine. Tried without Sim Card and still does not work. Please advise.
I am actually having the same problem with mine-- if I find a solution, I'll let you know. It was fine last night; I turned it off and plugged it in because it was nearly dead, and this morning, it won't turn on. I've even tried switching batteries.
Posted on Jul 30, 2008
My phone is tecno T722 with fault not charging and not powering on even when charged with desktop
replace the battery and check then if the problem is solved if not it will be the charging jack in the phone.
hope this helped
thanks
Jan 14, 2015 | Computers & Internet
ALL MY PHONE DOES IS FLASH LG
Try going into the stock recovery and then plugging in the charger. To get into the stock recovery: Pull battery. Hold power button for 30 sec to clear the phone. Hold home + volume down button, then power button (All at the same time) until you see your android recovery screen. Then plug phone into charger for 30min. Unplug charger, then select reboot system. Once rebooted finish charging.
If this doesn't work then you could have a defective battery, cable, or wall plug end.
Mar 23, 2014 | LG Cell Phones
My battery does not charge on the HTC hero and it says that its overheating with the two led flashing lights green and orange. The battery isnt even hot when it does it but I can barely ever charge my...
Hello, why the phone is not charging is because the cell of the battery is weak and can power on the phone for to long, that's why it shots down so quick,
You will need to replace battery with a new one for longer talk hours.
Make sure you charge battery for 6hours before use.
And also if the battery still doesn't work that means the phone memory is weak and it will need to be flashed to restore back the phone memory.
What you will need to do is this,
You will have to flash the phone to restore the memory of the phone.
You can use this link to see how to flash your phone
hubpages.com/hub/How-to-Flash-your-cell-phone
and
unlocktotalk.com/UnlockCodeInstructions.htm.
Take care.
Sep 12, 2010 | HTC Hero Smartphone
Samsung flight will not power on - battery charged
The problem is a software problem.
All you have to do is to flash the phone with the appropriate software and cable.
The phone will be in good condition again.
Take care
Jun 22, 2010 | Samsung Cell Phones
No power will not charge sccreen flashes white
hello there,
the problem would be that the charger is not sitting properly, therefore it tries to connect but ends up not charging.
try to replace the charhing port of the phone then you can try to charge again. or look for a charger that fits properly.
goodluck
Feb 03, 2010 | Sony Ericsson Walkman W810i Cellular Phone
I hv a blackberry 9000 phone and the red light blinks but I cant switch on the phone even thouh its connected to a power adapter for charging
Take the phone off charge and take off the battery on the phone, you can now put the battery back into the phone. Press and hold the red power button on your phone. If the problem persist then go ahead and download the blackberry desktop manager unto your computer. Connect your blackberry to the computer and initiate the blackberry desktop manager. Once it shows connected as status between the phone and your BDM (blackberry Desktop Manager). Reinstall the software on your blackberry. Make sure the computer is connected to the internet.
Regards
Jan 24, 2010 | RIM BlackBerry Bold 9000 Smartphone
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Help ME!!! V3i dead Now!!!!
Once you flash the v3i to R441D you cannot go back to R397 but if you power on phone while holding down # and * you can go into bootloader mode and then use FlashBackup to re-flash phone with R4441D firmware. I have had this issue a few times and always been able to recover it. If this doesn't work locate someone in your area via google or craigslist that offers Smart-Clip service and they can fix it for you.
Jan 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Mobile phone not charging
hi, you need to go to the sony ericsson support site http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/k810i?cc=gb&lc=en , download the software updator( you will find it if you have a look aroud) once downloaded follow the instructions to update your software, this will flash your phone with software that will fix it..
hope it helps
ps leave your phone to charge for an hour first even if it seems not to be doing anything
Nov 27, 2008 | Sony Ericsson K800i Cellular Phone
Samsung SYNC SGH-A707 Cellular Phone Logo
79 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
