Question about Boss C150 Car Audio Amplifier
Hi, i bought a guitar pedal, a boss OD-3, it works great when its on and sounds fantastic, but when i step on the switch to bypass the circuit so i just hear my guitar without the effect, it cuts the whole sound from my guitar and basically just mutes it. Could anyone please help me as i have to play a gig tonight! thanks!
  • Anonymous Dec 02, 2008
    I need to know the value of the resistance R24 of the boss chows c150 200w 2ch
    Thank you for his(her,your) collaboration
  • Starfish Phoenix May 11, 2010
    http://experimentalistsanonymous.com/diy...
    Heres a schematic if your confident of having a look inside for yourself ... As for no sound when effect is off ... Is your guitar all the way up? Are you using a mono lead? Are you running of external power or battery?
    Scholar:
  • 73 Answers
I had a similar problem, but opposite. the bypass was normal and the on position muted the distortion output levels. it turned out to be a couple bad ic's. it is not cost effective to repair these pedals. the parts are cents on the dollar, but the time consumed to trace down the issue is ten fold. as well, it is more than likely not just one part gone bad. the film on the board is so fragile that you may end up finding yourself having to repair your test points as the film disintegrates. if you want to fix it i would recommend assuming the ic/s are bad, replace all of them, replace the caps as well, and while you are at it the jfets. the cost on the parts from mauser.com with shipping would be under 20 bucks. then its just a matter of swapping them out carefully with a 700-800 degree solder iron. i would also get a solder wick or a desolder braid from radio shack, which you can use to remove the old solder from the board onto the braid. i would just keep it for parts and try to get another off of ebay.
yostamplifier.com
Posted on Jan 22, 2010
  • 22 Answers
Make sure your power is running solid with the pedal.
Posted on Sep 28, 2009
My Boss ME-70 han only two dots when i power on ,pedals dont lit when i press it down, is there a solution with this?
PDF]BOSS ME-70 Training Guide - Roland
cdn.roland.com/assets/media/pdf/ME-70_Training_Guide.pdf
AC adaptor. • $418.50 List, $299 MAP ... Connect the ME-70 to power using a BOSSPSA-120S AC Adaptor. 4. Plug a guitar into the ... For illustration only ). 4. Press the ...1. Turn the MODULATION TYPE knob to select a Modulation effect. Do not ... 2. Pressboth pedals down again or press EXIT to return to Manual Mode.Missing: han ‎dots
ME-25 Guitar Multiple Effects Review ' Boss ' Guitar Effects ...
https://www.ultimate-guitar.com/.../boss/me-25_...
Ultimate Guitar Archive
Rating: 8.6/10 - ‎135 votes
Sep 16, 2015 - Overall the effects are very very full sounding and don't sound too digital by any means. ... With 2 selector pedals, up and down, its a pain in the ? ... Editing the patch is as simple as press 2 buttons at the same time and turning ... If this was stolen I would probably get the ME-70 just because it pretty much ...
Tom Scholz's Guitar Sound - Van Halen Links.com
Jan 06, 2016 | Roland Boss ME-70 Guitar Multiple Effects...
Boss ME-70 distortion changing mid play why.
Is distortion changes like we turn the OD/DS selector (changes to Boost-Natural-OD1-Blues etc)?
If so, the OD/DS potentiometer need to replace.24346541-2ss5ycyvkoajtv035dpuezke-4-0.jpg
If the changes are like increasing/decreasing GAIN/BASS/MID/TREBLE/LEVEL and also TYPE of pre-amp, then one of PREAMP potentiometer is bad.24346541-2ss5ycyvkoajtv035dpuezke-4-1.jpg
May 06, 2014 | Boss ME-70 Guitar Multiple Effects Pedal
My boss DD-3 makes a strange tapping sound on all modes. tapping sound gets more frequent when i turn the delay time pot to the right. its like a little tap sound getting into the circuit with the guitar...
Check your power source or battery. The sound is probably due to the internal processor recycling due to watchdog timer. If power is OK, then service will be necessary to repair the problem.
Apr 03, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
Hello, My Boss CS-3 Compression Sustainer pedal is having issues. I bought it around 6 months ago. When I first discovered the problem, it didn't work at all when turned on. It just made this feedback...
Make sure you use Alkaline battery and NOT rechargeable type... the rechargeable battery will NOT work in the pedals (their voltage is lower even though they are labeled as 9 volt replacement).
Other internal problems can be due to cracked circuit board or broken solder joints. These are very common as people step on the cables when plugged in. This breaks the connection inside. A fuzzy sound often occurs when one of the contacts is marginal due to bad solder at the jack terminals.
Mar 22, 2011 | Roland Boss CS-3 Compression Sustainer...
My DD3 pedal doesn't work. Checked the battery and the adapter. The light won't go on it will only light momentarily when I click through the modes. Any help would be appreciated. Greg
Check all connections including the battery clip if you use a battery, and the adapter jack if you use the AC adapter. Also check you guitar cable connections as the pedal turns itself off if the guitar plugs have a loose connection. Make sure the guitar jacks on the sides are tight and don't need tightening. Any of those issues could cause the pedal to operate sporadically or not at all.
It could also be and IC problem internally on the pedal's circuit board, but before you open anything, check all the connections non electrical issues can occur more often on pedals.
Feb 19, 2011 | BOSS AUDIO SYSTEMS Boss Dd-3 Digital Delay...
When i'm on clean sound the machine sounds ok, but when i switch to other effects on factory setting the effects sound level cut down tremandously. it just sound like being muted or being **** in. any...
A lot of pedals when on bypass actually just connect the signal straight through... WHILE when using the effect, the volume control parameter is active. You need to balance the effect volume control against the straight through level which you have no control over.
Jan 06, 2011 | Boss ME25 Guitar MultiEffects Pedal with...
My boss MT-2 plays is extremely quiet when turned on, the clean channel comes through great, as soon as i turn it on its hardly audible, using the boss power supply, with correct ins and outs, and tested...
It is possible the pedal is DESIGNED to be used with an amplified (preamp within guitar) and yours MAY be a passive guitar. You did not tell us what guitar you have.
Many of the processors for guitars depend on having a "line level" signal and that requires that your guitar has a built in preamp.
If your guitar doesn't have a preamp in it, buy a preamp to put ahead of this pedal.
Apr 28, 2010 | Boss Mt 2 Metal Zone Effects Pedal
How to set up foot switch in order
Personally I recommend the following set up:
Distortion>Effects>Compression/Noisegates/Sustain
This will ensure that the signal won't have any odd hiccups due to an odd pedal setup. But if you play around with different orders, you can end up with some very interested sounds.
Nov 24, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Metal Pedal mutes my guitar.
Sell the pedal and get a digitech, or convert it into a looper pedal.
Apr 05, 2009 | Boss Mt 2 Metal Zone Effects Pedal
Boss C150 Car Audio Amplifier Logo
54 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
