I am suscriber of MTNL CDMA dial up internet connections and company promises of speed 144kbps, but I'm just getting 2kbps.I've contact regarding this to company but there is no response. Is there any software/Torrent to solve my problem by increasig speed.
One thing to know while choosing internet plans is that the speed offered is in kb not kB.
There is a huge difference between these two values.
Small b stands for bits whereas capital B is byte which we know.
the computer shows speed in bytes not bits so your 2 KBps is equal to 20kbps.
Because you are using cd-ma connection you will need to operate from a area where you can find powerful network to utilize your full 144kbps that is 14.4 KBps.
Sorry the only solution is changing your plan to a higher speed one..
it is not giving good speed
Just to avoid any ambiguity / misunderstanding, kindly clarify what you meant by kbps... Normally kbps would mean "Kilo Bits per Second" and KBps would mean "Kilo Bytes per Second".
If your connection is really 144kilobits per second, considering that you have a CDMA connection the maximum download speed that you could get is only 12KB (Kilo Bytes) per second. In which case there is nothing much you can do.
If you are using the MTNL unlimited Garuda plan, I would suggest you move to a better broadband connection if the above is the case.
Besides I heard that MTNL needs the network strength to be 100% during operation for maximum speed.
