Question about Brother MFC-5440CN All-In-One InkJet Printer
Brother mfc-5440cn Printer has stopped printing using black ink, information tell me ink cartridge is low. Have changed cartridge and still have same message and still printing in black only
  • smartyteddy Jul 24, 2008
    Still nothing printer has been off for over an hour. Still get message saying cartridge empty
  • SoCalhiker Aug 25, 2008
    Same problem. Black printer cartridge indicated low ink at time black ink stopped printing. Replaced cartridge. Ink indicator fine, but still won't print. Did cleaning cycle. Powered down completely for more than an hour. Even disconnected it and re-connected it to another PC. Same problem. Bad print head??
    Novelist:
    Scholar:
  • 125 Answers
The cartridge has no chip to reset. I'm guessing that the problem might be the printer. Have you tried turning off the printer for about 30 seconds? If this didn't work try turning it off and unplugging the usb and power for 30 seconds. This is to reset the printer to recognize a full cartridge. If this doesn't work, did you put the cartridge in the correct position? Is it aligned correctly? Hope this helps.
Posted on Jul 24, 2008
I cant print it says I'm out of black link and I just replaced it and it's flashing E 1 6
From http://www.refreshcartridges.co.uk/igloo/clearing-canon-pixma-error-message-e13-e16/
Locate the STOP/RESET/RESUME button on your printer which is represented by a triangle within a circle on the body of your printer and is usually in red, white or black as pictured below. With the reset button located hold it down for at least five seconds and then release it.
Aug 02, 2015 | Canon PIXMA Office Equipment & Supplies
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
I use 3rd party ink and why my color ink light up at my printer pixma mp 287
This will either be because your printer is having trouble recognising the cartridges or warning of low ink because the cartridges have been refilled. Connect a computer to the printer and it will hopefully give you more info.
If your printer cannot recognise the cartridges try wiping the contacts on the front of the cartridges and re-installing. If your printer still doesn't recognise the ink cartridges then sadly they will need replacing.
If it is just a low ink warning then carry on printing untill the printer thinks the cartridges are empty and prevents you from printing. You can them get around this message by pressing the stop/reset/resume button for 5 seconds and continue printing. More information on this can be found here: http://www.refreshcartridges.co.uk/igloo/the-infamous-canon-resumestopreset-button/
Hope this helps.
Feb 21, 2013 | Canon PIXMA MP210 Photo All-In-One Printer
How can tell if the ink level is low? hp 2420
Cartridge comes along with memory, the information of estimated ink/toner levels will stored in this memory(Depends upon the cartridge model yield will varies). When printer performs the printing, memory count will comes down, when its reaches the minimum count printer will display the message of "low ink/toner/remain pages" levels, once its reaches to '0', display will changes like "replace the cartridge"...But there is no electronic component or mechanism to measure the ink/toner levels in the cartridges.Only estimated levels only printer can recognizes.. Take usage page through menu, you will get the information that usage % & printed pages info,you can judge how much remain it can print...
Dec 06, 2011 | HP LaserJet 2420 Printer
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
HP C6280 Error: Ink Cartridges Empty
I want to print in black only and have changed the properties to grayscale, but it still won't let me print in black only. The magenta is out and it says I must replace, but i don't want color! help!
Aug 20, 2009 | HP Photosmart C6280 Printer
Have changed Ink Black and Colour... Stil getting error Message.
Make sure the tape covering the hole on the bottom of the black cartridge is removed. and then go into the printers folder and right click on your printer icon and go into the properties of that printer and there should be something in there to tell it that you changed cartridges and you can also print a test page as well.
Feb 06, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Reset Ink levels for canon mx310
How to reset Canon MX310 printer low ink signal
1. Power off the printer.
2. Holding the stop/reset button, press and hold power button also. Hold both buttons together for 5 secs.
3. Still holding the power button, release the stop/reset buton, then press the stop/reset button twice.
4. Release power button (the screen should now say 'Service Mode').
5. Wait until the power button lights steady green, then press the stop/reset button three times with a 3 sec space between each press. On the 3rd press the indicator should turn steady orange.
6. Press the power button once, (the orange light should go off).
7. Open the printer and remove both cartridges. Wait for 10 seconds. Replace the cartridges and close printer. Wait for 30 seconds.
8. Press the power button, and wait until printer has shut down.
9. Press power button to power up. The printer will feed one piece of paper, then ask you to set the language.
10. The page counter is now reset! Enjoy.
Jul 29, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Brother MFC-5440CN All-In-One InkJet Printer Logo
269 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
