Question about Pioneer AVIC-N2 DVD/CD/navigation receiver with 6.5" monitor Car Video Player
Power I replaced the battery in my car and now my system won't turn on. I pushed the reset button but that didnt work. Any suggestion?
    Champion:
  • 227 Answers
Try checking all of the fuses that related to the power of the deck in the fuses boxes and in the back of the deck on the harness.
Posted on Dec 03, 2008
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
The reset button is pushed in and therefore unable to reset it. Do you have any suggestions?
A faulty reset button. They are usually spring loaded. Replace the push button as it is stuck.
Jun 27, 2014 | CyberPower POWER,550VA,UPS,BK (CPS550) UPS...
All of a sudden last night when typing a text message anytime I push space or ? or . or anything but a letter it kicks me out of the message. What gives??? I can't take it much longer and won't be...
Try turning the Palm Treo off using a Soft Reset.
  1. Save your work and close all active programs and games.
  2. End wireless connectivity by holding down the red "End" button for 5 seconds.Take off the battery door cover.
  3. Remove the battery from the Treo.
  4. Press and hold down the red "End" button for five seconds to drain the memory.
  5. Insert the battery back into the device and replace the battery door.
  6. Wait for the Palm Powered logo screen to appear. The preferences screen will appear and prompt you to enter the time and date.
If you encounter data loss after a soft reset there is a serious hardware malfunction and your device must be serviced.
Sep 22, 2011 | Palm Treo Pro Smartphone
94 mercury grand marquis LS wont start. Turns over. Replaced relay, checked fuses, replaced fuel pump ( tho didnt need to- wired it to car battery and it does seem to work.) Will run with priming (starter...
Hello, There is a fuel cutoff switch in the drivers side of the trunk. It is referred to as the Inertia sensor. It will detect an impact and disconnect the power to the fuelpump.
If you look at the drivers side of the carpeted trunk there will be a slot in the carpet or a hole. All you need to do is push on the switch button and the system will reset. If you have air ride the Inertia switch is next to it.
Aug 03, 2011 | 1994 Mercury Grand Marquis
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
3 year old pushed the z power key and computer went into shutdown mode. Now it has no power. I have unplugged it, and held down power key for 30 seconds as suggested by ACER but still no power
shouuld havee restartd when you hold the power button down release and push to start but try this remove the charger and battery from the laptop
then press and hold thee power button down for about 3seconds
replace the battery and charger(charger should be plug into power source)
push the power button to turn on should start up
May 30, 2011 | Acer Aspire m5640 PC Desktop
Cannot switch off the gps 350
Do you feel a light click when you push the power button?
If not the switch is probably defective, If you do feel a click, hold it there for several seconds. It should switch off.
Mar 16, 2008 | Garmin nuvi 350 GPS Receiver
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
Pioneer AVIC-N2 DVD/CD/navigation receiver with 6.5" monitor Car Video Player Logo
100 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
