Question about Nokia 6681 Cellular Phone
Insert sim card
Sir,
an u help me to solve this problem, the problem is my ob. working in offline mode wd sim.
  • 23 Answers
Dear cheak your simcard if it s ok thne u need to chnage simdriver
Posted on Sep 01, 2008
6681 sim ic kanha per hai please 6681 ka pura ful imege send kare
Posted on Apr 30, 2011
Sir, can u pls sent me the circuit diagram of 6681 sim IC with solution. for the offline mode i tried all ur suggetions it was of no use sir pls help me ?
Posted on Sep 02, 2008
My phone is in offline mode,when i insert a sim card it ask whether i want to continue in offline mode but when i choose no, it tells me to insert sim
when you insert your sim card and press ok when it ask you whether you would like to continue in offline mode . once your phone starts go to the settings option and click the master reset or restore factory setting. once restored swtich off your phine without removing the sim card and then switch it on after 5 mins . it should solve your problem
Oct 19, 2013 | Cell Phones
OFFLINE MODE
Offline mode means that your phone aint getting any signal from your mobile service provider's BTS. You need to check it from your mobile service provider if there's an ongoing outage, you need to check as well if the sim card is properly inserted. Try powercycling your phone.
1. Turn off your device.
2. Remove the sim, memory card and battery.
3. Wait for at least 2minutes.
4. Plug back the SIM card, memory card and battery.
5. Turn on mobile phone.
6. Check if you are still getting offline mode.
7. If so, try to insert your SIM card to a different phone.
8. If using a different phone for your SIM displays offline mode still,then its your SIM card which is faulty. If it works fine make sure that you inserted the sim properly or the SIM card slot might be faulty.
Dec 05, 2011 | Nokia E52 Smartphone
Mu nokia n73 is in offline mode even with my sim card inside the phone
Please restart your phone. After restarting, it will ask do you want to continue in offline mode, select NO. This should solve your problem. Make sure you have SIM card inserted in your phone.
Mar 05, 2011 | Cell Phones
My Nokia N72 is working only in offline mode. I therefore cannot make or receive calls. When I try to switch to general mode, it says I must insert a sim card whereas the sim card is inserted. Will you...
This problem is called the 'insert sim' problem, there are several possibilities but first of all clean the sim card and the sim card interface on your phone. Next try it with another sim card. If this doesn't solve the problem, you need to go to the mobile repairing shop to get it serviced, or if you have idea in repairing mobile you can refer to this site on how to do jumper tips and tricks for this problem..http://sephonetechnology.blogspot.com/2009/08/nokia-n70-sim-ic-jumper.html Good luck.. and please...-:)
May 04, 2010 | Nokia N72 Cellular Phone
Insert sim ard after offline sign
Hi
Try checking any other SIM card, if other cards work then your sim card is bad. And, if your sim is not bad then please tell me, we will try and reset your phone to solve this issue.
Please rate this as FixYa if found helpful and ask for any clarifications,
Thanks
Rylee
Mar 16, 2009 | Nokia N71 Cellular Phone
N72 mobile working only in ''offline''mode.
The phone is showing Offline, hence I have inserted the sim card and switched the phone on, and choose general profile too. But it is showing Please Insert Sim Card. Please help with a solution.
Nov 22, 2008 | Nokia N72 Cellular Phone
Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
Sep 15, 2008 | Nokia N70 Cellular Phone
Insert sim card
Alright, take out your sim card, grab an eraser, erase the gold contacts on your sim card and test it again.
If it fails, take out your battery, grab any small metal that you could stick on to the battery contact points, the gold ones, and scrub it. Just like cleaning the contacts.
Hope this helps...
Jul 24, 2008 | Nokia 6681 Cellular Phone
Nokia 6681 Cellular Phone Logo
197 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
