FixYa.com
Tags:
PC Desktops
Generic problem for all PC Desktops
HP compaq nx9110 has a
posted by c513 on Jul 24, 2008
HP compaq nx9110 has a very very dull screen when running on electricity. When you run it on battery it is perfect. However battery last for seconds and cuts out.Obviously the battery needs replacing. Will this fix the dull screen issue?
Thankyou
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 24, 2008
Not Rated (0)
XEN_TUALATIN
Rank:Wiz Wiz
Rating: 75%, 6 votes
You'll have to replace the battery, of course...but for fixing the screen thing...you'll have to see if the powersource has the exact parameters that are writen on it...like for example I had the same problem with a fujitsu...and the actual charger, or powersource was having a lower output that the one writen on it...it was a 14 Volt, and 2 Amper, that was writen, but it only had 12 Volts and 1.3 Ampers at the output, when I measured it...so...I had to replace a 4.7 Ohm resistor, right at the exiting points, and it got fixed, so what I mean to say that after replacing the battery, you really have to check the powersource for any errors and see if the output is identical to the one writen on it...please tell me if I was right.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: HP Pavilion a1010n (PS563AA) PC Desktop HP Compaq Presario SR1430NX (PS566AA) PC Desktop HP Compaq Presario SR1920NX PC Desktop HP Compaq Evo w4000 PC Desktop HP Compaq Presario S3040SE (DF222AR#ABA) PC Desktop HP Compaq dc7600 PC Desktop HP Compaq dx2000 Microtower PC Desktop
Can you Help with these PC Desktops problems?
PC Desktops
hi i have a problem
hi i have a problem conecting... Answer This...
PC Desktops
need x63 printer software...
need x63 printer software... Answer This...
PC Desktops
I have tried to download
I have tried to download Adobe... Answer This...
PC Desktops
cannot reboot windows xp...
cannot reboot windows xp... Answer This...
PC Desktops
windows will not load.gets...
windows will not load.gets... Answer This...
Repair Service
Find PC Desktop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
