Question about Acer Computers & Internet
I have Acer monitor 22, and I cannot get the right resolution. It is stretched and the text is not really sharp as it should be. I'm running windows 2000. thank you in advance
  • 3 Answers
First u see your computer configuration, if u have a pentium 4 or core 2 due computer, u go to satting and control panal and system change the resolutio 1040x1025 or above, if your problem is not solve u purchase a AGP card minimum 256 mb and install the card your computer and change the resolution and enjoy...........
Posted on Jul 24, 2008
My laptop screen resolution is already set to 1200 *600 and windows 8 does not support in that screen resolution they want to 1200 *768 what can i do
  1. Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
  2. Tap or click Adjust resolution.
  3. Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Screen Resolution in Control Panel shows the recommended resolution for your monitor.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Oct 12, 2013 | Samsung N150 (36725723009) Netbook
The text on my screen is too stretched and unfocused
Make sure that you are running at the recommended resolution for your monitor. for example, and 20" widescreen should be at a 1680x1050 res
you may need to update your drivers and or video card to achieve a widescreen resolution.
Jul 31, 2009 | Acer Computers & Internet
Can't change W to H ratio
use another monitor crt not LCD. adjust first the resolution. then connect again to your acer LCD. or you can auto config your acer from menu.
May 29, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
Acer P193W monitor stretched image
What service pack of windows xp are you running? Also, do you have your old monitor, if so, then plug it in and see if the same problem occurs. If not , go under the settings for your graphics card (not windows display options) and see if there can be a correction made to the settings for your monitor. Also, try going to microsoft.com and updating your computer (it's free) and you'll probably get the required driver to fix the problem from them. Check under your control panel and see if you have automatic updates turned on, if so you may want to limit what updates are to be installed by allowing updates but you choose which one's to install. Hope I could help. My e-mail
tallcoolone@yahoo.com .
Jan 04, 2009 | Acer X193W LCD Monitor
I can not get the higher resolution on my Acer 22in X223W
Monitors have Max resolution. What you call VGA is not really VGA, the standard for VGA is 640X480, SVGA is 800X600 and XGA is 1024X768. VGA and DVI are capable of different "GAs". Consequently you are not able to go beyond the capabilities of your monitor. Right-Click on a blank area of your Desktop and click on Properties. Then click on the Settings tab. Move the slide all the way to the right and that will be the maximum resolution for your monitor.
Dec 25, 2008 | Acer 22" X223w LCD Monitor
Text ghosting on Acer 22" widescreen monitor
Hi...there,
It's seems you need to reset your WB (white blance). Open your on screen display and look for WB settings... Good lucks!
Oct 05, 2008 | Acer Computers & Internet
Acer Monitor Display of text and image is not sharp
This might seem obvious, but is your video card output set to the native resolution on the monitor? If not, it will look fuzzy. Try 1680x1050, if you don't know the monitors native resolution.
No need to use anything higher than a 60hz refresh rate either.
Mar 29, 2008 | Acer AL2216WBD LCD Monitor
Resolution of the text
What is the resolution that you are running the monitor at? There are two possible reasons that come to my mind.
1. You are running at a non native resolution. Based on your LCD spec you should run it at 1280x1024 resolution to have very sharp text as you normally expect from LCD's. However if you have set another resolution (say 1024x768) the text is blurred and this is a known issue with LCD's, which unlike a normal CRT monitor will get blurred running at any other resolution :(
2. You have not installed the monitor driver, hence again this limits your resolution and windows only allows you to select a resolution that is non-native (Meaning since the driver file is not there the operating system may not allow selecting the native resolution the monitor should run at). You can find the driver file at the samsung site. Its a common driver file for all LCDs.
Dec 12, 2007 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Computers & Internet Logo
21 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
