Question about Compaq Evo N610C Notebook
Battery charging problem
My laptop battery does not charge when plugged in and the charging light on the laptop does not come on either. Battery is ok in another system.
What could be the solution to this.
Thnk you
Evans
  • 1 more comment
  • Anonymous Aug 03, 2008
    mi bateria dell laptop no carga que hacer
  • giggleshart Aug 07, 2008
    my compaq evo n610c dosent wanna turn on it dosent wanna charge the battery
  • kungfu kid Dec 28, 2008
    hi, i recentley baught a new battery for my evo 610c. at first it charged then after that it shut down and my control panel keeps telling me that there is no battery even though clearly there is.
    i even on restarting my laptop pressed f10 and tried to configure the battery however once again its telling me there is no battery.
    PLEASE HELP!!!!!!!!!!!
It is not a fault with your laptop it s a problem with the power circuitry of some sort on the mother advice i got was to through laptop out and get a new one seems to be a comon nproblem
Posted on Aug 11, 2008
What does a orange power light mean
please see the commentary. God bless you
  • The majority of laptops will display a solid green, blue or purple battery light to indicate that the battery is fully charged. Most manufacturers indicate that a laptop is in the process of charging by displaying a solid or blinking green, orange, blue or purple light. If your battery indicator light is green, blue or purple, the battery is probably functional, regardless of whether the light is blinking. If the light is solid orange, the laptop is probably in the process of charging.
Battery Error Coneventions
  • Many battery manufacturers use rapidly blinking lights to indicate that a battery's charge level is low. In general, a laptop will rapidly blink orange or red when its charge drops below a certain level until the computer is plugged into a power outlet and charged. If your laptop's battery indicator continues to blink rapidly in orange or red or if it remains red even when it is plugged into the charger, it indicates a problem with your battery or the charger.
Read more: http://www.ehow.com/info_12183593_blinking-battery-light-laptop-mean-charger-not-charging.html#ixzz2fu5qhEWg
Sep 25, 2013 | Computers & Internet
Zoostorm laptops
please read and execute the commentaries. God bless you
Charging Conventions
Sep 25, 2013 | Gateway Computers & Internet
ACER 5810T LAPTOP BATTERY NOT CHARGE IT SHOW THE MESSAGE "PLUGGED IN ,NOT CHARGING"
If your laptop computer runs normally on your acer 5810t charger, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
Jan 29, 2013 | Acer Aspire 5810T-8060 Notebook
Hi, I've recently obtained a Toshiba Satellite
Have you since re-inserted the battery to see if it charges? A battery that is past its ability to hold a charge may show as fully charged, but will discharge usually instantly if put under load and one that has deteriorated to the point of no longer accepting or retaining a charge can cause problems that you have described. The best way is to obtain another battery and test that in the laptop. If that too fails, the issue is likely to lie in the charging circuit. Some laptops, the Packard Bell easynotes were notorious for this.
It is also good practice to remove the battery once charged and running on mains, as this extends the battery life
Dec 24, 2010 | Toshiba Satellite A45-S151 Notebook
It is plugged in but not charging,eg if 40% is the battery charged is available then it does not increases the battery life. neither the charging light is lighting.
HI, sounds as if you may have a bad battery. Go into you control panel and check you power options, it will show you how much of a charge you battery has left, and also if the battery is charging.
Dec 20, 2010 | Acer Computers & Internet
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
Battery not charging
1. plug the power cord into the laptop
2. remove the battery
3. try to power on the laptop
if the laptop led lights up and/or powers up without the battery it can be determined that you need a new battery
if the laptop led doesn't light up and/or power on. then you may have a charging port or power cord problem
Apr 18, 2009 | Dell Latitude D600 Notebook
Dell battery problem
Hi Roy,
Dell, apparently have had some problems with their batteries, as they called back some, including yours.
Goto Dells homepage here and goto -> a bit down this page -> Step 1: Is your battery model affected?
Hope your battery is among these, as you will be able to get a new one.
regards
/Teis
Dec 17, 2008 | Dell Latitude D600 Notebook
Compaq Evo N610C Notebook Logo
89 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
