Question about Refrigerators
THE FRIDGE FREEZER CONSTANTLY MAKES A GROANING SOUND AND NOW EVEN THOUGH ITS FROST FREE THERE IS FROST STARTING TO APPEAR ON THE BACK WALL OF THE FRIDGE
  • mstanwycks Jul 24, 2008
    Sometimes also makes a loud ping or shot loke sound after blower shuts off. Lately the top refrigerator section seems less cold, The frrezer maintains cold but has some frost. I wonder if shutting it off for a while and then on would help?? This is a Whirlpool Designer series 36" wide.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
You could have one of two problems- 1) The defrost timer has failed OR 2) the defrost heater has failed.
Switch off fridge, open back panel check continuity of defrost heater. If it checks out OK you need to replace the defrost timer.
Posted on Jul 25, 2008
Whirlpool Refrig/Freezer Model ET21GK /E221GM - Freezer works but everything in it is starting to frost over
If the defrost drain is blocked and water cannot exit the fridge during automatic defrost it will cause this to happen. Also if the ice dispenser door is stuck open it wall also cause the same problem. Thanks John Tripp Appliance 911
Feb 13, 2014 | Refrigerators
I bought a new frigidaire fridge with the freezer on top. It's made a weird grunting, gurgling, groaning sound on and off from day one. Should have called Leon's where I bought it to complain but never...
hmmm, could be in defrost cycle when that happens, when the defrost element warms up and the frost/ice drips it then makes sounds about how oftern do you hear the noise?
Dec 18, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My freezer is cold but my fridge is room temp?
Most often when you have this condition with a frost free fridge, you have one of two problems.
It could be a defrost problem. Look in back of the freezer. Is there a layer of frost against the back wall? If yes, you are Iced up. That would be either a defrost timer, heater, or termination thermostat.
The other thing it could be is the evaporater fan motor. Do you hear it running? It could be that the sound you heard was the fan blade hitting something. It may be jammed or the motor burned out.
Your fridge needs the air moved by this fan to make it cold. Thats why when you have ice blocking the coil, it makes your fridge warm.
Good luck
Jul 28, 2010 | Whirlpool ED2FHSS Side by Side...
The fridge compartment does not coolbut freezer is ok in my no frost model, there appear to be problem in getting cold freezer air into fridge area
look in the back of freezer . if there is ice or frost on back wall . then your coil is ice packed .. this is caused by the failure of defrost system . when ice is blocking coil the air that goes to the fresh food side doesn't get there. ..
Dec 09, 2009 | Refrigerators
Freezer cold- Fridge Not, Loud Noise
that is the damper door malfunctioning this open to allow cold air into the fridge compartment the damper needs to be replaced
Sep 20, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge Icing up on N1B Candy frost free fridge freezer
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Sep 02, 2009 | Refrigerators
Hi i have a hotpoint mistral plus fridge freezer, the freezer working fine however the fridge not getting cold, i have checked in back and the fan not working, have checked the fuse that is fine. 1) Does...
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Jul 23, 2009 | Refrigerators
I have a zanussi fridge freezer combination, it is a frost free model, Im developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does...
Hello Mr Barnard
Welcome to fixya
You said, You have a zanussi fridge freezer combination, it is a frost free model, And you're developing lots of frost in the freezer which never used to happen and the fridge is not getting cold, some condensation does appear inside the fridge, it is 2years old.
Frost could mean a few things.
Is the freezer cold but the fridge not?
If so the freezer may be so full that the articles are covering the air vents in the back that share the cold air with the fridge.
I've have seen the freezers packed to the hilt!
More things to check.
Is the condenser in the back or under the front of the fridge. If it is under the front of the fridge you must remove the plastic grill`(The condenser is the thin black metal tubing that runs back and forth to make up your condenser). This needs to be free of dust and have air passing over and through it!
they sell refrigerator brushes for this at the hardware store.
I have had customers that never ran the brush under there ever and had 1 to 2 inches of dust and lint
under there between the tubes.After a few hours it was cool the next day it was cold!
The freon level pressure should be checked in case you have a leak.
The thermostat may be bad.
Let me know what works for you.
Huuum
Please remember to leave a rating!
Oct 05, 2008 | Refrigerators
Frost free fridge freezer the fridge isnt staying cold we have tried turning the temp up and down but it makes hardly any difference.
you need to find out what going on in the freezer,is the fan running?is there frost on the back wall?let me kn ow and we can go from there,mike
Sep 12, 2008 | Bosch Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
311 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
