Question about Apple iPhone Smartphone
My iphone 1.1.3 doesn't work
The screen was frozen, just every 2 or 3 minutes the time changes on the screen but nothing works, and the screen stills lighting more than an hour ago..
i tried to restart the phone but it doesn't respond and doesn't shut down..
when i try to call it it i can hear on the calling phone that it's ringing, but the iphone doesn't ring and nothing changes on the screen
  • Anonymous Jan 22, 2009
    I pressed those buttons but it still doesnt work
    Problem Solver:
  • 17 Answers
Press power button and home button together. press them 2gether for 10 secs. this is soft reboot.
this shud reboot the iphone.
u may need to put ur network settings again.
chao.
Posted on Jul 24, 2008
My iphone 6s plus apple logo on and off but phonw will not start
Hold down the home button & the lock button together for at least 2 mins while it does a full reboot, you will not lose data or anything, it will either start normally or give you the black screen with the plug in your phone to charge screen, now plug it using a apple charging cable only, then leave the phone to fully charge, then all should resume as normal, hope this helps.... Has worked on ours & we all have iPhones here....
Feb 08, 2018 | Apple Cell Phones
My iphone 4 which i renewed in the last 3 months has frozen with no response, nothing on the screen at all, what can i do
all Apple iOS devices can give a reset, by pressing both, the home button and the on/off button, for several seconds. (long enough till the apple loge comes on the screen. Then wait about one minute and press the on/off button to switch on again. When really does not work this way (don't forget to charge) visit the genius bar in an Apple store.
Or check out the supper site from Apple and follow their steps in this link:
iPhone Apple Support
Feb 05, 2015 | Apple iPhone 4 Black Smartphone
My iphone screen is completly black i've tried holding the home and the off button down at the same time and its still not working wtf . i really need help !!
Hi, this happened to me once and I researched a fix by looking for 'iPhone black screen of death'
Here's one of the current articles that comes up under that search:
1) If an application (such as Safari) is frozen, just press and hold the iPhone's home button for about 5 seconds, or until the home screen shows up. (This didn't work for my iPhone so we had to perform a soft reset).
2) To perform a soft reset, press and hold the iPhone's Sleep/Wake button and the Home button for several seconds, or until you see the apple logo on the screen. (This action did reset my iPhone and I was very happy at this point). The guys that helped me said that continually performing soft resets can cause problems however.
3) Hard resets are not recommended, but are required when a soft reset won't do the trick. The Apple Geniuses wouldn't tell me the key combo to perform a hard reset because it restores the iPhone to a state that's unusable. Users risk losing data and you must synch your iPhone with iTunes to make it function after a hard reset.
Also, if you are not turning off apps after use they could be overloading things and might cause it to happen again. to turn off apps do a double tap on the 'Home' button, and all your open apps will be listed along the bottom of the screen. press on one icon and hold until the icons start to wobble and have the X in the top right corner click on these to turn them off. Its also good practice to do this several times a day if you use a lot of apps because having ghem open eats up your battery power.
Apr 17, 2013 | Apple iPhone Smartphone
I got msg "check operator
Go to your phone settings and locate (line 1/ Line 2) function...switch the Line 2 to Line 1 then ok....now turn phone of and on an try it...
(if this doesn't work the first time ...change line 1 to Line 2.)
this will stop the problem..
www.joestechreview.ning.com
May 12, 2011 | Apple iPhone 3G Black Smartphone
I have had frozen lexicon on my iphone for 2 years. now i cant connect to server it says. i removed it and reinstalled from back up but still nothing. Help...
I've had an email from them and they are no longer supporting online gaming. You can still play them offline. V sad, I had their solitaire as a web app since day 1 and it was the first app I bought :(
Jan 30, 2011 | Amplified Games Frozen Lexicon
My lock button as well as my sound buttons won't work
It sounds like you may have accidentally turned them off. To make sure the sounds are on, do the following:
1. Click on "Settings"
2. Select "Sounds"
3. At the bottom you will see "Lock Sounds" and "Keyboard Clicks".
If the sounds are on, I would then recommend preforming what's called a "Soft Reset". To preform this, do the following:
1.Press down the "Home" button and the "Lock" button at the same time.
2.Hold these buttons until you see the apple logo appear.
3.The iPhone may take up to 2 minutes to come back to your "Lock Screen"
This should fix your problem.
Oct 06, 2009 | Apple iPhone Smartphone
My iphone 2g touch screen not functioning
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Clean the screen, if that doesn’t work. Reset the phone or use iTunes to restore the phone to the factory defaults. If that doesn’t work you will need to take the phone by the Apple store and have them check it out. The touch screen component of the iPhone is like a second screen under the display; it can break and you can still have a perfectly clear picture but no touch response.
Oct 02, 2009 | Apple iPhone Smartphone
I am so confused because i can´t turn on my iPhone the screen is still black This is what i tried... 1. Pressing the Power Button (Result: Nothing happens.) 2. Pressing the Power Button and the Home...
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
Jun 12, 2009 | Apple iPhone Smartphone
Iphone frozen on white blank screen
Hmm. I've been browsing the net for iphone problems (courtesy of my own) and i remember reading something about this. Look up the Apple website, especially the discussion forums. You might find something there.
In the meantime, try restarting your phone. For that, press both the top on/off button and the Home button together and keep holding them down. Your screen will go blank but keep holding them and the phone will restart.
If this doens't fix things, look up other answers. You might have to restore your phone, like I had to, You should be able to find the procedure to restore easily on the Apple website.
Feb 26, 2009 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
295 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
