Epson c90 i had my epson c 90 for about 6 mos now but the ink that came with it only lasted a few wks so i bought another set but then i didnt replace it in just one time, i first replace black then the yellow & magenta a week later and the blue which made me happy lasted the longest.however when i replaced the blue ink& i try to print in blue it still came out as pink so i thought it could be the cartridge so i bought a brans new epson blue cartridge the budget type which is 290 pesos only.but still came out pin, why is that so?its the only color that not working...the pink yellow & black are doing fine,help me pls.
Hello! everyone
can you help me for my problem, i have a printer epson c90, i try to change the ink cartridge black in deferent ink number, fist i was use is the 73N in cartridge, and then i change to a 91N ink cartridge, when i go back to 73N ink cartridge, they have a problem they cannot read the 73N ink cartridge.
plaese...help me for my problem..thank you....
emer's
Posted on Oct 10, 2008
  • 781 Answers
Did you remove protective strip from cartridge
Posted on Jul 28, 2008
I have a f4480 hp printer. Used it about 3 times in last 6 mos. It was not printing with the black ink so I just bought #74 & #75 ink from Staples. Now the yellow light on the front of the printer...
If the ink cartridge in the printer is 6 months old, it maybe dried out and would need to be replaced with a new cartridge. When buying new cartridges from places like Walmart, Target etc. check the dates on the packages before buying. Sometimes the cartridges will set in the store too long and dry out.
Jun 17, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Ink replacement issue!!
have you bought genuine ink??? well if your answer is both yes or no, you can always opt to have it replaced from where you bought it, but please try to buy genuine inks, so as you will have no problems regarding ink cartridges.
Jun 03, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Epson C90 failed to detect ink original cartridges
I guest, the problem is chip module attached on the head (housing). Need to be change
Hope could solve ur the problem
Rusdi
Mar 10, 2010 | Epson Office Equipment & Supplies
Ink is not visible on paper
First NEVER raise the tanks of a CISS above the height of the printer otherwise all that is going to happen is that the ink will syphon out and end up getting everywhere.
As you have not used the printer in a long time there wil be dried ink in the print heads 3x head cleaning is nowhere near good enough to clear the blockages.
One thing I would do as you have a set of OEM carts is the following presuming you have the equipment.
Drill a small hole in the top of each cart and extract as much ink as ps=ossible with a syringe (you can put it in the ciss ink tanks) and replace with head cleaning solution. Reseal the ink carts (if clean selotape will do) insert carts and do 5x head clean, leave 24hrs and do 5x head clean again. This will allow the head cleaning solution to get right insine of the print head, soften the dried ink and then flush it through..
A lot of messing about I know but you've just shelled out a few bob for a CISS so it's worth it.
NB
Make sure you keep the CISS carts above the tanks whilst outside of the printer.
Aug 24, 2009 | Epson Stylus C88 InkJet Photo Printer
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson Stylus DX 8400
If ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
I just bought you epson stylus cx9400 printer fax series and it was suppose to come with the ink and there was not any in there. I have it all set up and no ink if I take it back to the store I have to...
HI bingoliz,
You are right, you are supposed to get an ink with it. Here's what call Epson technical support and inform them that you didnt get an ink with it. Try to doublecheck the foams in the boxes because sometimes inks are embedded on those foams. if there is none call this number 562-276-4382
Hope this helps
Apr 23, 2008 | Office Equipment & Supplies
Epson 3100 life battery
I have a 3100z and you are right that alkaline batteries do not last long. The thing to do is buy a couple of sets of NiMH rechargable batteries and they last much longer. I,ve just been on holiday and had no problems at all with the batteries. (Although the camera does not give much warning when they need replacing).
Sep 13, 2005 | Epson PhotoPC 3100Z Digital Camera
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
