Question about OKI Office Equipment & Supplies
C5600 being used as a network printer it will print off other 2 machines but will only print small 10cm border down the left hand side, ive deleted printer and drivers and rebooted but still no change
    Sergeant:
    Champion:
  • 214 Answers
Try to align the printer with the printer settings
Posted on Jul 24, 2008
I have small black dots down the left hand margin of each printed page approx 10cm apart. MFC8870DW
10cm means it's caused by a large roller. The only roller large enough for that would be in the drum. Replace your drum and it should clear up, the model number of the drum is DR520.
Dec 03, 2014 | Brother MFC-8870dw Wireless Multifunction...
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
I have small black dots down the left hand margin approx 10cm apart- machine is only 12 months old
hi
First try printing a few pages to try and clean the drum unit. If the problem is not solved after printing a few pages, the drum unit may have glue from a label stuck on the drum surface.
go to this link -- below for further instructions
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000200/000016/faq000216_016.html?reg=us&c=ca&lang=en&prod=mfc9440cn_all&Cat=112
hope this helps
Nov 14, 2010 | Brother MFC-9440CN Laser Printer
How do i put paper in the bypass feed of the OKI C5600 printer? I can't find the bypass tray or how to put thicker paper through the machine.
The bypass feeder or multipurpose tray as OKI call it is situated above the standard or 1st cassete paper tray.
It is usually hidden. Ther is a door door with an handle. Pull the handle to open it and then extend the tray.
For images and instructions on how to feed the paper, check page 13 and following pages of the User Manual you can download from here:
http://www.c5600.co.uk/library/documents/c5600/C56uEN1.pdf
Also, I leave you the link to the support homepage for your copier. On the left side of the page there are several useful inks (to download drivers, software and documents, how-tos, explanation of errors, etc.):
http://www.c5600.co.uk/index.asp
Aug 19, 2009 | Ricoh Aficio 250 Copier
Canon MP600, Borderless print issues
There is probably a "gutter" setting that is trying to give you a border of sorts. Check the advanced print settings and look for something like gutter and turn it off.
Jul 11, 2009 | Canon Pixma MP600 Printer
Polyester labels from tray 1 4 labels per sheet right side color
It says on the website the labels are 56lb (I guess cover weight). The only way the stock will run right (ie) fuse correctly is in the mp tray using one of the thicker settings. Also if you run labels out of the tray you run the risk of them peeling off making the turn out of the tray and into the machine. All non standard paper is better off using the mp tray.
Mar 29, 2009 | OKI C5150n Led Printer
White border on edge of print
The only way would be to use a bigger piece of paper and cut it down to the size you need...... The copier will always leave a white border a round the edges.... It is done so the toner can be fixed into the paper with out off setting or jamming
Mar 14, 2009 | Kyocera Mita Office Equipment & Supplies
HP DESKJET F4135 - CANNOT PRINT PHOTO WITHOUT BORDER
border cannot print bottom side
but you know you can print if you can do it
margin up to 1.29 of bottom that simple
Dec 29, 2008 | HP DeskJet F380 All-In-One Printer
Dark border one side of paper
This maybe your cleaning blade, your drum or the fuser unit....the best way to find out is to make a copy a to stop it before it's getting to the fuser unit ( that's the thing very hot). If you see your border it's your cleaning or drum...But when you replace a drum you must replace the cleaning blade to !
Hope it help !
Apr 04, 2008 | Office Equipment & Supplies
How can I get A4 size borderless prints
From what I can see, this printer can only do borderless prints onto 4x6" paper only. Larger print jobs such as your A4 will have a border.
artifixit
Dec 19, 2007 | HP PSC 1410v All-in-One Printer
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
