Question about Fujitsu Stylistic LT C-500 Tablet PC
Win XP on Fujitsu stylistic lt c-500
What is the procedure of installing XP on this tablet? i have a mini doc, a floppy drive, ps2 mouse and keyboard. the Win2K drivers did not not work (audio, video, pan) on my previous attempt. anyone done this?
  • 2 more comments
  • jobob55 Oct 17, 2008
    Similar problem but I Think I screwed up royally. I started the install while logged into Win 2K and chose the clean install. After the computer restarted, it either continues to restart after POST or after tweaking BIOS, it says no operating system found... I have a Floppy drive (USB) but it doesn't seem to work. Did I just make a paperweight out of this thing or can I fix it?
    Thanks
  • stoski Jan 29, 2009
    Fujitsu Stylistic LT C-500 with boot problem... have tried fdisk /mbr, complete format with FAT on another computer, installing Win 98, Win2000, WinXP, but always after POST I get a blinking cursor on a blank screen.
    Is there something about formatting the drive while it is in the Fujitsu that would be different than formatting in a desktop with an adapter installed? Why wont it recognize the location of the os on the drive? Stumped...
  • jobob55 May 11, 2010
    Chris please post your advice.... I have a new HD for it, but I still need help! Thanks!
    ....absolutely! Please post the details... I have scoured the Net using Google and I have yet to find a straightforward step by step technique to solve this problem. I tried loading the original HD onto another computer using a USB enclosure and install XP that way, until I broke one of the pins from switching the HD back and forth...anyway I digress-- anxiously awaiting your solution!
  • 6 Answers
Ok... after much slaving, trial and error, and just plain getting frustrated I finally figured out how to install XP on a Fujitsu Stylistic LT c-500 with EVERYTHING working!! The installation is difficult and time consuming but well worth it. Getting XP on the blasted thing is part of the difficult uphill battle... but Mr. Mark Rehorst does a wonderful job of explaining it here. Follow the directions carefully keeping in mind that you MUST have the cd-key for the EXACT CD you use... and that to install XP and get everything to work you really need at least a 20gb hdd and 256mb ram. Without those your system will be slow. Next once XP is up and 'running' you'll notice that your touchscreen is not working. Download the CIC XPen off of the Fujitsu support site... now here comes the interesting part. Unpack the driver to C:\Drivers\Pen once you've unpacked it find the file called fujpen.inf open it in notepad to edit it. You will see:
[ControlFlags] ExcludeFromSelect=*FUJ02B6
Make sure the last digit is 6 in that string... this is saying to exclude that model in the driver. If it's anything other than a 6 change it to a 6. Now then... further down you'll see:
[FPC.Mfg] %FPC.DeviceDesc0% = pendrv, *FUJ02B6
Now... remember what I said about the 6 above? Yeah... the driver is fighting with itself, help it out and change the last number to a 7. Save the .inf file. Go to your device manager right click on the unknown device and update it with the modified file... and presto changeo your touchscreen works!! Now for the other unknown device in there, it is called the Fujitsu FUJ02B1 Device Driver. Unfortunately Fujitsu dosen't include a driver for this... but if you google search it you should come across driverguide.com and they'll have it. You will have to sit through a few ads to get it... but wow... the world that is unlocked by xp on this tiny little pad is amazing! Good luck!
Posted on May 11, 2009
  • hardeep singh
    hardeep singh Aug 04, 2014
    very very greatfull and thankfull to you. but for lt c 500 u need not download c 3400 driver u can download c 500 pan driver and change the same in it . it will work immidiate. thanks a lot for ur guide
I have a solution to this if still required.
I realise the post was a while ago now but requestion in this post if you want full details.
It's NOT difficult but there is a technique.
Chris
Posted on Oct 22, 2008
Yank the hardrive out the tablet. Plug it up to a tower PC. Low level format the hardrive with something that will work as a program in XP( no need to go to dos or some bootable program for this.) This is the trick- Boot the hardisk drive to MAXBLAST(look it up). Go to advanced settings, install the boot loader. Then install witch ever OS you want win98 to win7. ( all this is done on the tower PC)Before snatching hardrive out of tower change system device to standard pc power interface management. Install drive in table PC. : ) Get XP pen drivers from Stylistic Lt 800 {: )
Posted on Oct 07, 2009
  • wileharley
    wileharley Feb 26, 2012
    please can explain how resolve ntldr problem ??
Got bless drakaniss he is the best of the best!!!! more people like him!!!!!!!!!!1 thak you man!!!
Posted on Sep 06, 2009
  • Fujitsu Master
  • 19,396 Answers
Follow instructions for windows 2000 here, just do with XP what is described for 2000.
I am not sure C 500 supports xp, it need at least 256 Mb of ram, do the same prescribed for 2000, in the way they work XP and 2000 are very similar, 2000 is much faster because has less cosmetic effects.
Posted on Jul 24, 2008
You can activate windows xp easily if you are willing to spend a little money buying a cheap product key, this site: https://www.facebook.com/Windows-XP-Key-1742549319367506
offers very cheap product keys, you can go to have a look.
Posted on Jun 01, 2016
This guy there un Ebay sells for a very fair price, Restore DVDs which allow you to install both Win 2000 or XP in 5 minutes, with no need to worry for drivers/stuff. I tried it and worked beautifully. Here is the link to his auctions
Posted on Apr 20, 2009
Need to replace lcd screen on a Fujitsu lt c500
Below is a link to tech support chat page for Fujitsu products. The Fujitsu site does offer a user manual, however, you need a service manual. Being a customer, you should be able to order a service manual for your notebook thru fujitsu. Here is the link for the chat page:
http://solutions.us.fujitsu.com/www/support.shtml?support/support_chat
Here is the link for the user manual:
http://support.fujitsupc.com/CS/Portal/supportsearch.do
This is a good place to start. I hope that you find this information helpful and will leave feedback to that effect if you do.
Thank You,
Brian
Jan 25, 2010 | Fujitsu Stylistic LT C-500 Tablet PC
Tip
Why would I buy this Tablet? (Fujitsu Stylistic LT C-500)
You may be wondering what an antiquated piece of computer's history could do for you, now in the year 2009. The answer may surprise you. This tablet has (when properly fitted) enough power and spirit to run XP, as a matter of fact it runs XP better than the included Windows 2000, or Windows 98SE. The thing makes this device a real possibility is the fact that it's so cheap! You can easily purchase one of these tablets for under $200 on ebay, fully ready to go with Windows 2000. Now... with Windows 2000 your options of what do use this for are a little more limited. The size and power of this device make it a perfect in car and on the go PC. Add a GPS USB dongle (about $40) and Streets and Trips (about $30-$40) and you've got yourself a turn by turn navigation pc. Have alot of .mp3's? Get a FM transmitter (about $20) and you've got music in your car that you control, and it's even cheaper than an iPod. Want to watch movies on the go? Grab a slimline DVD-ROM (about $50) and hook it up to your USB port, or just get a thumb-drive (about $10) and grab those .avi's off of your PC at home. If you've got a little know how you can upgrade the puny 6gb hard drive for something with a little more space, like say 40-80gb (about $40). While your pulling it out why not upgrade to XP... and truly unlock this little tablet's potential. XP allows quicker access to USB devices, more stable program performance, and better tools for your touchscreen experience. XP install is a minor pain in the rear... but worth it in the end. To ensure the best experience upgrade your RAM to the maximum of 256mb (about $20). If your looking for something cheap, reliable, and small enough to fit in your active life, look no farther than the Fujitsu Stylistic LT c-500.
on May 17, 2009 | Fujitsu Stylistic LT C-500 Tablet PC
I need to get aol on this computer dont know how?
go to google,com and put in need get aol.it should take you where you can get it
Jul 18, 2009 | Fujitsu Stylistic LT C-500 Tablet PC
Is a processor upgrade possible
no, it will not handle a pentium4, but you could get a much faster p3 for it. and the ram amount doesnt depend on the processor type, it depends on the motherboard and os. and it looks like 256 is the maximum ram for that model.
Feb 26, 2009 | Fujitsu Siemens Stylistic LT P-600:...
Does the Fujitsu 500 or 600 have electronic signature capablility
I don't see why, if the correct software is installed, it wouldn't be able to do it. Both devices have a passive digitizer, meaning that you "write" on the screen. Though you would need to insure that the software is windows 2000 compatible, or hire someone who has the experience with either device to install XP on it for you. Hope this answers your question! Good luck and Godspeed!
Jan 29, 2009 | Fujitsu Stylistic LT C-500 Tablet PC
Fujitsu Stylistic 3500 Pen calibration in XP Tablet Edition
Well there is a few ways to try to fix it first with a usb mouse check that the resolution is at it's native pixel count. This can be found on the manufacture website. If it is already at that resolution ensure that the CIC XPen drivers are installed. Those should have placed a recalibration program in the control panel. If those both fail, try uninstalling the drivers and restarting, then reloading the drivers. Hope this helps! food luck and godspeed!
Jan 11, 2009 | Fujitsu Stylistic 3500 Tablet PC
Loading Windows 2000 on a formated hard drive
Try detecting cd rom in bios and boot from Cd rom. and then istall windows.
If not you should have drivers in floppy during installation it will ask for drivers F6 [function key]
Best Regards
rafique
Feb 18, 2008 | Fujitsu Stylistic LT C-500 Tablet PC
Pen Problem
First try updating to SP2 and then get the latest Windows Updates from Microsoft.com.
If that doesn't fix it, here are some Win2000 drivers for your laptop.
http://www.fujitsupc.com/www/content/exe/PenW2k1.4.exe
http://www.fujitsupc.com/downloads/mobile/st3400_pen_w2k.exe
If that doesn't fix it, try these Wacom drivers.
ftp://198.145.255.42/drivers/IBMPC/consumer/503/PenTablet_503-3.exe
Oct 17, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Stylistic LT C500
I had a similar issue, the inverter has a component that broke, had to order a new one. I opened the unit and saw the component that broke, its a long ferrite piece that I guess acts as a capacitor. anyway, I took the part number off the board and did a search on ebay where I found one for about $25, this fixed my problem. good luck.
Sep 19, 2007 | Fujitsu Stylistic LT C-500 Tablet PC
Fujitsu Stylistic LT C-500 Tablet PC Logo
5,727 people viewed this question
Top Fujitsu Tablets & eReaders Experts
k24674
rob j
Tony
Are you a Fujitsu Tablet and eReader Expert? Answer questions, earn points and help others
