Question about Creative Labs ZEN Vision:M Digital Media Player
Creative Zen freezes
Everytime I use the play button, my Zen freezes. Is his a hardware problem or software. I tried to reset, he rebuilds and then the same story.
  • 728 Answers
This should help you right here: Detach the player from the PC and turn the unit off. Then slide the power switch towards the power icon and hold the switch. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. Release the power button when the recovery mode appears. Select format (all) and select yes to format the player. After the player has finished formatting, select reboot. Then retransfer the tracks to the player as doing the format will erase the whole player.
Posted on Apr 16, 2009
Hi, My Creative ZEN has frozen up. When you switch it on a 'rebuilding' screen is displayed and once that has run its course the last song that was playing is displayed as playing but does not play &...
First of all, I hope you mad a backup of it's content, becouse there is
no other way, it need to be fomated from it's service menu.
1. Make sure bthat your Zen is turned off and has a full battery.
2. Press and hold the Play/Pause button and Back/Options button simultaneously.
3.
The Recovery Mode screen appears when the player, and three menu items are shown: Clean Up, Format and Reboot.
4.
Format your ZEN and then do a clean up.
5. When done reboot.
6. Hook it up to your computer an reflash to the latest firmware, you can download the tool here to flash your firmware:
http://ccfiles.creative.com/ManualDn/Applications/PDE/10398/0x8CCCF7FC/CT-RT_PCAPP_2_00_05.exe
Jul 28, 2010 | Creative Labs Zen Touch MP3 Player
I have a creative Zen 2GB & when I turn it on it has to rebuild libraies and then once that is complete it freezes on the one song & I cant turn it on or off
Ok just fixed mine by pushing pin into reset hole. Hold play button turn zen v back on format player. yes you will lose your data but its better than buying a new mp3 player. download zen firmware update plug player in and update. This problem is caused by a corrupted file so the only way to fix it is full formate.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Rebuilding Problem (Freezing)
Hold the reset button with a paper clip AND the play button at the same time while flipping the power switch. The ZEN should go into recovery mode. You probably want to do format all but you can try the different options. You also may need to download/update the firmware here.
Feb 07, 2009 | Creative Labs Zen Digital Media Player
Creative Zen Freezes on Rebuilding
My Zen locked when I turned it on. It wouldn't play the track the screen was on so I pressed the reset button and turned it on again. It was then still locked on the same track so I tried turning it off which then froze as it was shutting down. After another reset it went through the rebuild screen then locked again. I then used the above fix (pin in reset, then hold play and power switch down). Taking me into the kind of bios screen I formatted the contents. Then added my library again. It's now working fine.
This is the second Zen I've had because the first one had the same problem so I took it back without trying to fix it. Both times the problem occured when I had my Zen plugged into my car stereo auxiliary jack whilst switching the ignition on in my car. I can't understand why this would cause the problem but I'll avoid doing that in future.
Dec 27, 2008 | Creative Labs Zen Digital Media Player
Rebuilding
You need to use the Recovery Tool from Creative's website at support.creative.com
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 23, 2008 | Creative Labs Zen Digital Media Player
Keeps Freezing
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 04, 2008 | Creative Labs Zen Touch MP3 Player
My creative zen keeps freezing!
Hi -
I know this response is way late to help you, but I was having the same problem. I could turn the zen on fine, but as soon as I tried to play music it would freeze and I couldn't turn it off. Using the reset button didn't help any since it would still freeze if I tried to play anything.
But I found reformatting the entire zen totally fixed it.
-directions-
Connect your zen to your computer, go to windows explorer, click computer on the side bar, and your zen should be under "portable devices". Click on it. You should now be viewing the "storage media". Right click and select "Format...". This completely resets the zen, clearing any preferences or media you put on it and the freezing problem.
It was annoying putting all the pictures, videos, and itunes back onto my zen, but at least it works now. Since I've reformatted it, I have had no problems.
Hopefully this helps others who experience this problem.
--Lillian
Jul 01, 2008 | Creative Labs Zen Digital Media Player
Not rebuilding Library all the way
1. Press and hold the Play button while powering on your player.
2. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Oct 27, 2007 | Creative Labs ZEN SLEEK MP3 Player
Creative Labs ZEN Vision:M Digital Media Player Logo
159 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
