Laptop's power cannot turn on even with charger plugged in
My laptop worked fine one day before, but today , I cannot turn on the power even with the charger plugged in, the light for charger connetion is on(green), so can u please help me wit this problem?
  • 2 more comments
  • Anonymous Nov 10, 2008
    same problem....charger light is on, i push the power button, and nothing happens
  • Anonymous Dec 27, 2008
    me too
  • Anonymous Mar 04, 2009
    Me too. I replaced the battery and power supply. Still dead as a door nail.
  • Anonymous Mar 29, 2009
    Same problem
I HAVE THE SAME PROBLEM MATE
Posted on Jul 24, 2008
Won't Charge
If it's not a recognized charger it'll stop charging the battery and try to run on the charger alone. If the peak draw of the laptop is higher than the charger output, it'll go right back off.
Try removing the battery and see if it'll boot on the charger alone.
Apr 01, 2014 | ASUS Q200e Touchscreen Notebook
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
I have been using presario CQ50 compaq laptop, it was working fine but as time went on the laptop felt as though it was starting to overheat and would randomly turn off, i wasnt sure if maybe it was the...
are you going to spend hard cash on this junk
its old and worth Zero
now
try a new battery, oops those are expensive.
i see working
presario CQ50
for $30 working
not working worth nothing
its worth at best the cost of potted plant.
why fool with it>? or spend cash on any COMPAQ.?
got to "GOODwill" fine a 10 year or newer system.
best advice of all that. one that works too.
Mar 28, 2017 | HP Compaq Presario 730US Notebook
Why does laptop stop working through adaptor after battery flat
Hi There,
Your battery charger/adapter connects to the DC Power Jack to power your laptop and charge the battery. Since the charger/adapter does 2 things, there are 2 "cells" inside it to do those 2 different things. It's not uncommon for one or the other (but not both) to fail. So, often just purchasing a new charger/adapter solves the problem you're having. It appears that yours is continuing to charge but has stopped "adapting" AC current to DC current to power the laptop directly.
Jul 10, 2010 | Computers & Internet
Charger was plugged in and working fine, went into
OK unplug power supply from back of laptop, remove battery, insert power supply, if NO light, on laptop, power supply is broken..Replace. IF it is OK, hold power button ON for a while, or until, the PC starts, if/when it starts, shutdown, with power ON key, and then take out power supply, replace battery, replace power supply, turn laptop on, now should be OK.
Mar 01, 2010 | Toshiba Satellite A70-S249 Notebook
Unknown problem
I would say your battery is fine. What happened is the computer was running off the battery even though it recognized it was plugged in. There is a piece in the power jack that tells the laptop that you are plugged in, but it doesn't necessarily mean the adapter is working. I would have the adapter checked to be sure it's working before I suspected the battery.
Jan 08, 2010 | HP Televison & Video
My new acer laptop only works if pluggd in
u try one thing just shutdown laptop remove battery and charger from laptop then after push power button for 1 minute after that install battery and charger. but not start laptop and check that charging led of laptop is running if it's runnig then put in same condition for 3 to 4 hours after that start laptop using battery only after proper booting when os load attech the charger and check charging status.
Dec 27, 2009 | Acer Aspire One PC Notebook
My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Aug 22, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
