Question about Lexmark X5150 All-In-One InkJet Printer
X5150 and Vista print issue
Purchased laptop with Vista Home Basic. Lexmark X5150 installation disk would not load. Went to Lexmark website and pulled new drivers for X5100 series and installed on laptop without a hitch, test page printed fine.
However...when I send more than one print job to the printer now, it prints the first one, and that is it. All other print jobs stack up behind the first one. When I open up the que for the X5150, it shows the computer trying to delete the first print job, but the print job never deletes, and I am unable to manually cancel it. Since it never deletes, the print jobs behind it never print. I have to cancel all print jobs (the one showing being deleted still shows after I have cancelled all), I have to shut the computer off, then turn it back on, and that normally will delete the print job being deleted.
Try it again with just one print job, and it prints, then trys to delete the print job in the que, and it hangs there. So if I was to send another print job to the printer, it will not print.
  • 19 more comments
  • star98 Jul 25, 2008
    Exact same problem. Have uninstalled/reinstalled drivers.
  • merricav Jul 25, 2008
    Same here. I have to wait for each print to complete before sending the next to the printer. Sometimes turning the printer on and off can start the next print job.
  • Anonymous Aug 02, 2008
    Add me to your list. I have the same problem with my Lexmark 5150. Sometimes it prints several jobs and other times it locks up so I can only print one. Also if you know if there is faxing software for the Lexmark 5150 I would love to know. Ever since I downloaded the Vista drivers the scanner does not work
    Thanks
    John
  • fixmy5150 Aug 03, 2008
    Same here
  • Anonymous Aug 13, 2008
    The print spooler hangs after printing 1 document. I is trying to delete the document just printed from the queue, but it never deletes; therefore additional documents will not print
  • Hemau Aug 14, 2008
    I have the same problem.When i swicthed the printer off and on again the deleted file is gone and the next printjob started
  • fixyaDJ Sep 26, 2008
    Same exact issue, any resolution yet? Tried to chat with Lexmark, kept getting disconnected, very tiring.
  • d_fn_warbux Sep 27, 2008
    I installed my X5150 on vista & could not print test page. I could not cancel print either. I downloaded the drivers from lexmarks website. When I attempted to install the driver, I'm prompted to uninstall the previous drivers. However, after it starts to uninstall, I get the '(not responding)' message. Have tried several times and no luck. Can't unistall, print, or anything!
  • nila_shah Sep 27, 2008
    exactly the same problem. I'm unable to print with Windows vista and lexmark x5150
  • kayk4_5_79 Nov 13, 2008
    I can print but can not do any thing else
  • txpowells Nov 23, 2008
    We have the exact same problem with Lexmark 5150 and Vista. We'd love to hear when someone gets an update that fixes the issue. Thanks
    Kristi
  • Candace Leap Nov 23, 2008
    Ditto - I have a Lexmark x5150 and laptop with Vista....I cannot print!
  • Anonymous Jan 03, 2009
    I have exactly the same problem with my X5150 on Vista- can only print once and then I have to switch off the printer to clear the completed job.
  • mbaer27 Jan 20, 2009
    I have the same issue but with Windows XP. If I try to delete a print job before it has started, it never moves past the "deleting" message. I've tried turning the printer off, disconnecting the printer, logging off to no avail. I have to reboot the PC.
  • Anonymous Jan 31, 2009
    i have this too... anyone found a fix ?
  • BevKarol Apr 03, 2009
    My X5150 (Vista X64) - will print and not remove the document from the queue -- just showing "deleting". Can't print anything again until I re-boot.
  • Anonymous Apr 12, 2009
    I had exactly the same problem. After turning off UAC, the print jobs are removed after printing. Thanks douglionberg!
  • jimls Apr 14, 2009
    Two symptoms:
    1. If the print suceeds, the printer window stays open as though the print is not complete, if I click cancel, the print clears from the queue.
    2. Sometimes, the printer window closes, and then the printer is hung until I power the printer off and reboot Vista x64.
    Jim
  • gfmccullough Apr 18, 2009
    I have exactly the same problem. Please advise any solution. Thankyou gfmccullough@comcast.net
  • fixmy5150 May 11, 2010
    I also have this problem and would very much appreciate a solution. Thx in advance. Rob
  • George Kohler
    George Kohler May 11, 2010
    Welcome to my world! This problem with Lexmark and Vista is a known issue and you are doing nothing wrong. The programmers at Lexmark are trying to Iron out this issue and I flagged you so when I get the Go code I will E-mail you the fix, Post a yahoo or google type throw away address and I will add you to the list of Lexmark Vista victoms bulk E-mail fix list. Until then Just print 1 page at a time. I'll keep you updated on this one.
    George
I am posting this in hopes of helping others that are having issues with the Vista print spooler. In my case, I have an HP Pavilion laptop running Vista connected to a wireless hub. I also have a Minolta Konica 2300DL printer that is connected to the network via the wireless hub as well. Ever since obtaining this laptop, I have not been able to print to the printer other than stopping and starting the print spooler to obtain a single print 'job'. After about six months I found a post that contains the fix - I cannot take credit for it! Follow these instructions to get your printer to work:
1.) Go into control panel - I would suggest classic view as it is a little easier to navigate.
2.) Then go into User Accounts.
3.) From User Accounts go into Turn User Account Control On or Off
4.) UNCHECK Use User Account Control (UAC) to help protect your computer.
5.) At this point you will probably require a reboot.
Once this exercise is complete, you should be able to print. One more item off of my Honey DOO list!!!!!
Posted on Oct 28, 2008
I got my x5150 to scan in vista x64 ultimate - make a custom color profile with file type .bmp. I still can't print more than one print job at a time. The queue is hung up. I have had UAC turned off the whole time -- ie. since before I installed the driver for this printer. Normally you can restart the print spooler service to counter this type of issue ie a hung job so it is probably their usb printer connection shim that is causing the problem but that is just a guess. Stopping and starting print spooler in this condition does not remedy the problem.
Posted on Nov 18, 2009
I have this problem with Vista drivers and have found that after each print I turn off the printer and turn it back on it will delete the last print and print the next in the list. agravating but it will print. No scan Though.
This driver is only to print so the nice printer scanner that worked so well with XP and win98 is a sorry page printer. Lexmark is unresponsive and useless for helpI. I will never recomend Lexmark again
Bill
Posted on Aug 06, 2008
I am trying to add my printer X5150 to my new hp laptop dv7-4177 and as it is loading it comes up to say that it does not have English every other language except English I did't have that problem with my...
I recommend you use the Lexmark X5150 driver from the Lexmark website. But first, make sure there are no existing Lexmark X5150 driver on your computer. Go to the Start menu -> Programs -> Lexmark X5100 Series -> Tools -> Uninstall. Reboot pc when prompted.
To reinstall, click on this link Lexmark X5150 Drivers.
Then click on FILTER.
Click on the Complete Driver under Recommended Downloads. Download, execute the file and follow the instructions on the software. NOTE: Use Vista driver in Windows 7.
I hope this information has been helpful. Thanks.
Jan 04, 2011 | Lexmark X5150 All-In-One InkJet Printer
Lost x5150 all in one installation disk
Access the manufacturer's web-site:
http://support.lexmark.com
and enter 'X5150' and click "search".
Select the device-driver for your printer and your Operating System. Download it. Install it.
May 28, 2010 | Lexmark X5150 All-In-One InkJet Printer
I cant get my Lexmark all in one x5150 to download to my HP vista computer ,pls help me
Hey,
The lexmark drivers and software required for installing the printer is available at www.lexmark.com
Select Drivers & downloads then driver finder.
Type in your model x2350 for example
Select your windows version
Download the setup program.
1.Download software
2.Run the downloaded setup
3.Plugin the printer when asked
4.Done
Thanks,
Ekse
ps. if no vista drivers are available then your only option is to use general drivers that came with vista or contact lexmark and request drivers for the printer.
Mar 04, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x5100
Go to Lexmark support website and select download software. Search for your printer model and download the software needed to work with Vista.
Jun 01, 2008 | Lexmark X5150 All-In-One InkJet Printer
Need Help
Last Month i Purchse Laptop Compaq Presario V3702TU With Vista Home Basic. Wrongly I delete the Partition and again I Installed Vista Home Premium down load all Drivers and install only Web Camera Driver not installed kindly help me out how to installed web camera driver on vista home premium 32 bit.
Apr 06, 2008 | Compaq Presario R3000 Notebook
Lexmark x5100
I have lost the installation cd to my lexmark x5100 how can I get it to install?
Jan 13, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
1,005 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
