Suspect controller to Tevion Set Top Box.Batteries replaced. How can I tell if is the STB or controller without purchasing another?
Opened up the remote controll to find corrosion on the the positve contact within the unit.A rub with emery cloth fixed the problem.
Posted on Jul 25, 2008
I am unable to find the owners manual for the Teac MC-DV100 SuybWoofer
For almost any set-top box, there isn't a sub-woofer output. Without that output (it would be labeled on the STB), you can't hook up a subwoofer directly to it.
HOWEVER, the model number you give isn't just a subwoofer: it's a whole sound system with a subwoofer attached to it. If you have the whole sound system, you just hook the STB's audio output to the amplifier's "Aux Input" (it might also be called "line input").
If your model doesn't have that (can't tell from the web), you'd have to buy an "AV Receiver" that has at least a 5.1 set of outputs. These start at maybe $150 new, $50 on eBay. MAKE SURE YOU BUY A RECEIVER WITH A "powered" SUBWOOFER OUTPUT!! You connect the receiver to the STB, and the subwoofer to the receiver.
Jul 15, 2015 | Teac Audio Players & Recorders
Everything works fine. Just want to know what this abbreviation is: STB Refw Design. STB is Set Top Box..what is the rest? Thanks
The rest is "Reference Design". Only a few companies created the set top box chips/electronics plans. These companies license their designs to the various vendors/builders of STB boxes.
I hope this helps.
(Sometimes you'll see a reference to the STB RDK. This is a set-top box reference design kit. It's pre-packaged set up for the manufacturers.)
May 08, 2015 | Televison & Video
Tivax stb t8
i'm going to ask a goofy question but I have done this...
are the batteries in the right way?
Dec 31, 2017 | Televison & Video
Rank arena
Check these links Pull up older posts there. Setup code list to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/
Jun 06, 2013 | Televison & Video
I increase all the volume on the tv to watch regular tv and the sound is very low but to watch movies on the dvd is fine, what could be the problem? thanks
If you get your tv through some kind of set-top-box (if you have cable or satellite tv for instance) the STB (set-top-box) may have it's own volume control that is set to a low level. You will have to look through "settings" on your STB.
Mar 14, 2011 | Panasonic Televison & Video
Can the Panasonic DMR-EH55 be made to receive digital channels? e.g. via a digital capable TV or a set top box? If not, I suspect it will be obsolete when analogue channels cease this year (in Australia)
If you receive your channels through your local cable company, nothing will change. The DMR-EH55 will continue to work normally.
If you receive your channels with your rooftop antenna you'll need a Digital to Analog TV Converter Box. The unit itself will not receive digital signals directly.
Jan 16, 2010 | Panasonic DMR-EH55 DVD Recorder/HDD...
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Tevion TV set top box remote control code
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
Jan 01, 2009 | GE JASRM84964 Remote Control
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
