Philips rear pro 46PP8621 ..fuzzy image, lower screen has a wavy section with distorted image, very noticeable with text.. this section is a bright green colour. Colours seem to be ok......... with thanks
  • 19,396 Answers
Your tv is probably in need to replace the color disk. Follow instructions on last pages of your manual to find out hou to get repair service.
Posted on Jul 24, 2008
Image is distorted. Like the guide is in a wavy
Its sounds like the convergence is out of alignment. Instructions on how to adjust it is in the manual. If you don't have the manual you can find it on the sony support site.
Mar 01, 2010 | Sony KP-53HS30 53" Rear Projection...
I have a problem with the convergence of red and green my screen is wavy my television is a philips model #46pp930217f how can i fix this?
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 24, 2010 | Philips 46PP9302 46" Rear Projection...
Half of the screen is distorted
You have a bad lower Y-buffer board. On these sets it is not uncommon for them to fail. At the same time of replacing the lower Y buffer board you should replace the upper Y buffer board since they work together. This is not a repair for the novice so seeking a TV technician to do the repair is recommended.
Feb 01, 2009 | Philips 42PF9630A 42 in. Plasma Television
Green Background with red wavy lines
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2009 | JVC AV-56WP74 56" Rear Projection...
Picture distortion
I have a vs 8087 good working condition
$700 you pick up Chicago area
scott_kehoe@sbcglobal.net
Jan 11, 2009 | Mitsubishi VS-8087 80" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips x57 laptop. screen has suddenly went fuzzy. distorted colour and images jumpy.
Have you set the right screen resolution. Check screen resolution & color quality setting in display properties.
Aug 17, 2008 | Computers & Internet
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Image reduced by dark edges
An adapter tube has to flare out at the end or it will cut the corners off at the wide angle setting. Telephoto should be ok though.
Dec 04, 2007 | Canon PowerShot A620 Digital Camera
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
Electro Med Services...
