Question about Linksys WRLS BRIDGE |WMB54G MUSIC R
Connect befw11S4 with wmb54g
How do i open ports on befw11S4 to make it work with wmb54G
  • 60 Answers
You dont need to open ports on the router. Just configure the music bridge with the same wireless settings as your router so that it will work.
Posted on Aug 24, 2008
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
How do i set up the wireless bridge without a
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 30, 2010 | Linksys Wireless-G Music Bridge (WMB54G)
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Can you run WEP and WPA simultaniously?
If you did do both simultaneously, and you can on the separate systems, you would experience a severe denigration of your service in terms of speed and the real possibility of a lot of down time.
Yes, you can, but should you is the real question. If the linksys only does WEP and you want the N speed, then switch off the encryption of the lynksys.
Apr 20, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Linksys WMB54G: No Connection Via the Software Utility
It appears the configuraion IP address you are using is wrong it should be 192.168.1.100 or 192.168.1.1
Jan 03, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Wmb54g and apples
The utility needs to be installed in a computer in order for you to use the WMB54G and it will only work with windows version. You can't use it on a MAC computer.
Jul 10, 2008 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Dropped connection
Step 1:
Connect the Wireless-G Music Bridge to your router using an Ethernet cable. For instructions, click here.
Step 2:
Access the Wireless-G Music Bridge’s web-based setup page. For instructions, click here.
Step 3:
When the Wireless-G Music Bridge’s setup page appears, scroll down to the Wireless section and look for Wireless Mode and select Infrastructure.
Step 4:
Look for the Wireless Network Name (SSID) field, enter the wireless network’s SSID.
If this doesn't work let me know
Aloha
Bob
Dec 13, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Lynksys router model befw11s4
You're going to have to reset the router, itself.  There's a reset button found on the back of the router.  Insert something small enough to fit in that hole, push & hold down the button for a few seconds. However, this will clear all the data from your router, including your settings...make sure you have all your settings information before resetting the router.
Sep 19, 2007 | Linksys WRLS BRIDGE |WMB54G MUSIC R
How to Use as Simple Bridge
set the uptime variable to "0" in the main bios sytem configuration 7
Nov 11, 2006 | Linksys WRLS BRIDGE |WMB54G MUSIC R
Linksys WRLS BRIDGE |WMB54G MUSIC R Logo
255 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
