Question about Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42hdt50 wont turn on, blnking amber light
There are 2 indicator lights on the lower right front. the bigger one on the right is usually red for off and green for on. there is a smaller one to the left of it that is blinking amber, set wont turn on. The control box turns on and off, and I unpluged everything and tried again. any help would be appreciated. Tony
  • 579 Answers
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Posted on Feb 10, 2008
SOURCE: hitachi 50v500 tv lamp light blinking no picture
I have one of these units, if the light is blinking and no picture as you have stated then you will need to replace the bulb in the unit. it is contained in the front of the unit behind the front panel on the right, you would remove the front panel after unplugging the unit, remove the single screw and pull out the box. replace it and then reverse the proces. the bulbs can be obtained for about $130.00 to $200.00 depending on where you get it from. Shop around.
Posted on Feb 10, 2009
  • 19396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 22, 2009
SOURCE: Hitachi 50" Plasma (P50X01AU), power light comes on but no screen
Hope you already resolve it, if not, here what I went through 1. Try to get a service manual for your model ($10-18) from or similar place. 2. Open the back and follow instructions how to remove and test the SDR-D and SDR-U board on the far left (take one off, see if you could see half the picture). Inpsect the chips on those two boards, you might be able to spot the burned out holes (that would be the defected board, seemed to be a known issue for particular models) 3. If it is the board, go to ebay and get the pulled out board replacement ($70-90) I fixed my 50 inch plasma this way
Posted on Jun 12, 2009
Rally Guy
  • 3 Answers
I can't help you because after 26 months of ownership mine is doing the same thing (started on 7-12-09). Judging by the number of people with the same complaint I believe Hitachi knows that they have bad boards but refuses to replace them for customers unless they are within warranty. It also explains why the merchant that sold it to me in 2007 stopped offering Hitachi in 2008.
I'm disgusted because I'm anticipating a $300-$500 repair bill simply because Hitachi's design did not provide an external way of resetting it. Impossible to get to the menu to do a reset within 12 seconds before it starts the powering on booting cycle again.
Adding salt to the injury, mine is wall mounted and repair people will only work on it if it is readily accessilble when they walk in the door or if it is brought to the shop. Know what a 55" plasma TV weighs? Too much.
Posted on Jul 13, 2009
My monitor it dose not turns on but it have a green flashing light
This is a protection error code, indicating it is having defects in the power supply or inverter or some other area. Might require attention by a qualified service technician.
Jul 11, 2012 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Cliks but wont turn on
you can check base on the light indicators of your television at the front of your screen. red light means standy by power mode and green is power on mode. once light is green its working but the lamp does not working. change the lamp.
Feb 04, 2011 | Hitachi 53UDX10B 53" Rear Projection...
My Hitachi 42hdt50 turned off while watching it and will not turn on. The standbye light on the TV will not come on at all.
Open up the tv then go to where the on switch is on the bottom of the tv. After that make sure you have the metal back off and look on the circuit board near the power plug socket there should be a fuse cylindrical one. Just have to replace it same thing happened to my 42hdt50 guy i am friends with told me i needed a new one. So, thats what it might be if not then I do not know.
Aug 10, 2010 | Hitachi 42HDT50 42 in. HD-Ready Plasma...
Hitachi tv LCD blinking red light tv wont' turn on. replaced lamp model 60V500A
I have hitachi lcd rear projection tv model 60v500A at first I was getting a red spot on centar of tv with in two mounths the spot got bigger. I chanched the lamp but now i don't have a picture, the red indicator on tv is now blinking.
Aug 10, 2010 | Hitachi Televison & Video
Lenovo Ideapad Y510 won't turn on or off
try removing the battery and removing the adaptor press and hold down the power button for 5-10 seconds then let got this will power drain your system board noy turn the system on using the battery only without any adaptors to charge or power the system, try turning the system on if the system turnes on leave it turned on for a couple of hours then conenct your sysem adaptor monitor if the battery light and the battery indicator on the lower right of the screen in windows woll indicate that the system is chargin if it is then I believe everything should be fine the blue indicator is for your system if it is blue then your system is turned on and has power if it turned orange and blnking then the battery will be more likely be almost out of juice or may need charging.
Jun 23, 2010 | Lenovo IdeaPad Y510 Notebook
What to change the color for the light in my 08 flhx can i
Red to the rear, amber to the front, no colors other than red or amber side lights read within 18" os back end and amber within 18" of front end. Any yhing else could, not will, get you cited or at least give a cop a reason to F*** with you.Now, can you what? :)
Jul 08, 2009 | 2008 Harley Davidson FLHX Street Glide
Amber light on front of laptop flashes.
The Battery indicator LED is to the right of the power LED. Flashing AMBER indicates a fault with the Battery. To resolve, replace the system battery.
Apr 13, 2009 | Dell Inspiron 2200 Notebook
Red Flashing Icon
The icons from the left: 1. Power indocator 2. Hard Disk indicator --> it is a tube icon, not battery, but means hard drive. 3. Power Source indicator 4. Bluetooth indicator
The third from left means the power source indicator. Normally it is light green. If there is battery problem (can not charge or battery overload) it flashes amber/orange. If flashes red, it indicates that the battery power is low. You need to change the battery or connect the AC adapter.
Dapid Candra
Dec 02, 2008 | Dell Latitude D505 Notebook
I'm going throught the exact same thing right now. After the lights quit blinking, and the blue light goes off, does the red lamp light stay on. This usually means your lamp has gone bad ($200.00 plus). But when I ordered the lamp, it did the same thing. Had to have the certified hitachi repair man come out for the and told me it had to be a bad lamp, so I ordered a 2nd one with the same result. He came out again and had to take the TV away, later telling me the ballast must have blown when the original lamp went bad. Another $200.00 part. I haven't fought this one with Hitachi yet but am going to try. The ballast shouldn'e go just because the lamp goes out. The set is only 21/2 years old and I've already had to spend about $700.00 on the light enging replacement and now this lamp and ballast expense. Love the TV but would expect a lot less problems from a $2500.00 top model Hitachi. I'm going to see if they feel the same way, hopefully not but I'm not real optimistic they will care. Hope this helps.
Dec 14, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
No picture-lg ru-52sz51d
Depending on what light is flashing it could be a few things. If the Lamp light (the middle one) is flashing that is problem with or around the lamp. That orange or amber light is an indication that the lamp is reaching the end of its life
If it is the Temperature light (the far right one) then the TV is shutting down because it is over heating and you need to check the cooling fan.
Nov 14, 2007 | LG 52SX4D 52" HDTV
Hitachi 42HDS69 42 in. Plasma Television Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
