An error keeps coming up on initial boot up. The error 0211 key board error is displayed, you can not access the setup menu or anything as the key board will not work.The make and model fujitsu siemens esprimo edition p2510 model M13w-D480 any help would i would be gratful.Thank you
  • Anonymous Jan 21, 2009
    error 0211 on a desk top by Fujitsu.
    What causes it and how can you fix it when you have no mouse or keyboard control?
  • hwne11224 Apr 26, 2009
    I have an 0211 keyboard error on my toshiba equium A110. I replaced the keyboard but still have the same problem, after awhile it comes up with a password screen. Before I had this problem I had the blue screen of death, I then had the operating software re-installed. The laptop worked about a dozen times then failed to boot up again with dreaded 0211 keyboard error
    Problem Solver:
  • 6 Answers
My fujitu esprimo wont let me add file to windows setup, it says it either cant find the file or dosnt regognise the disk is in the drive
Posted on Aug 09, 2009
  • 3 Answers
Your keyboard connactor is damage change the key board, u purchase USB key board
Posted on Jul 24, 2008
Won't read keyboard
usb or ps2 keyboard ? might need to be enabled in BIOS
If you want to use a USB keyboard to access Windows command prompt options, make changes in the BIOS (Basic Input/Output System), or to operate legacy operating systems, you must enable support for the device inside the BIOS.
Shut down the computer and disconnect the USB keyboard. Connect a PS/2 keyboard to the PS/2 connector port on the rear of the computer. Turn on the computer and press the "Delete" key several times as soon as you see the initial boot or company logo screen. Wait for the main BIOS setup screen to appear. Press the right or left arrow keys to move the cursor to the "Advanced" or "Advanced Settings" menu option. Press the "Enter" key. Move the cursor to the "Integrated Peripherals" or "Peripheral Configuration" menu option. Press the "Enter" key. Press the down-arrow key to navigate to the "USB Controllers" option. Press the "+" or "-" key to change the menu option to "Enabled." Move the cursor to the "USB Legacy Support" or "USB Legacy Function" field. Press the "+" key repeatedly until the value option changes to "Enabled." Press the "F10" key to save changes to the BIOS settings and exit the setup utility. Wait until the computer begins to restart and then press the power button and hold it for approximately four or five seconds. The computer shuts down completely. Unplug the PS/2 keyboard from the computer and set it aside. Reconnect the USB keyboard restart the computer. As soon as you see the initial boot screen, tap the "Delete" key several times and wait for the BIOS setup screen to appear. If you are able to access the BIOS setup screen with the USB keyboard, USB support is active in the BIOS.
Feb 15, 2013 | Dell OptiPlex GX110 PC Desktop
When I try to access the digital channels having watrched something on analogue TV get an error mesage 'error cannot acces digital services. Cannot access retune facility in tool menu, tried switching...
If you are accessing the tuning menu correctly; according to the TV's manual, try unplugging the set for half an hour or so, it will discharge all the capacitors and return to the initial setup page. If this does not work, there is a problem in the digital tuning board and would need to be serviced. Hope this helps.
Jun 01, 2011 | Televison & Video
My digicam lens keeps on moving... coming in and coming out and the screen says "ACCES"
The ACCESS error message displays when there is an internal malfunction or a malfunction with the Lens. This may also appear when accessing the Memory Stick for reading or writing the data. If the Lens is moving in and out then follow the steps mentioned below. The error message normally displays with the issue with the Lens. Try the following steps to check if the issue can be resolved.
Try power resetting the Camera.
Turn off the Camera.
Remove the battery pack.
Press and hold the power button for 15 seconds.
Then, allow the Camera to remain without power for 60 seconds.
Re-insert the battery pack and check if the Lens retracts.
You can also try resetting the Camera back to factory default. To reset the Camera back to factory default, select the INITIALIZE option from the Setup 1 Menu of the Camera to OK. (Menu-->Setup-->Setup 1-->Initialize-->OK.)
This should resolve the issue. If the issue persists, service may be required.
Thanks for using FixYa
Jan 19, 2011 | Sony CyberShot DSCS750 Digital Camera
How can i set first boot drive on an IBM PC, model is FRU PN 02R4087
Hi van Carlisle,
you will have to go into BIOS during the startup, I am not familiar with the FRU PN 02R4087 but the process is more or less the same for all PCs.
When you start your PC watch the screen carefully, at one point there will come a text similar to "to enter setup press Delete" usually it is either the Delete key or F2 or F10... watch your screen to find out which key is for the setup on your computer. you may have to start many times over before you get everything.
Once you have entered BIOS you will have to look for a page that contains an entry like "First Boot Device" or something similar. it should be set to HHD1 or CDROM or Disk... then follow the directions on how to change this value to what ever it is that you wish. Be Aware that there are other options in BIOS that in changing them you can quite possibly damage your computer, so do not change anything else unless you know what you are doing.
I hope I was able to help you on this.
Oct 21, 2010 | Computers & Internet
Acer laptop gets hanged every time it is opened. on dignosis it shows code 0211= key board error.pl advise
Try this:
  • open BIOS
  • Look for HALT settings
  • Change settings of HALT ON ALL ERRORS to HALT ON ALL ERRORS EXCEPT KEYBOARD
  • Wait for windows to boot then try your keyboard again
Oct 19, 2010 | Acer Computers & Internet
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
Would like to know how you access the setup menu or BIOS
I believe that you want to press the F2 button as soon as you turn it on, and keep pressing it until the BIOS setup screen comes up, If F2 doesn't work then try F10
Apr 04, 2010 | Compaq Presario 5304 (120969-004) PC...
PC REBOOT OVER AND OVER AGAIN.
YOUR HARDRIVE MAY BE MALFUNCTIONING, IF U HAVE A RECOVERY CD, U MUST GO INTO THE COMPUTER SETUP, WHICH GIVES U THE KEYS TO PRESS WHEN THE COMPUTER COMES ON USUALLYA KEY LIKE F1 OR F8, PRESS THE CORRESPONDING KEY, GO TO THE BOOT MENU AND CHANGE THE BOOT SEQENCE TO BOOT FROM CD DRIVE INSTEAD OF HARDDRIVE FIRST ORDER. RESTART THE SYSTEM AND SEE IF U CAN ACCESS THE HARD DRIVE
Aug 11, 2008 | Dell OptiPlex GX620 PC Desktop
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Computers & Internet Logo
521 people viewed this question
David Payne
David Payne
