Could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Does the gas need to be turned off before changing the ignitor?
No, gas does not need to be turned off. You may want to unplug the stove. When you remove old ignitor cut the connector off so that you can join it back to the new ignitor.
Use the ceramic wire nut to after joining wires together
