Question about Averatec 3200 Notebook
Power problem How do I open the computer case to get to the power jack?
You need to remove the screws on the bottom of the laptop. Once the right screws are removed the case will seperate exposing the MOBO and that and you should see the dc jack (power jack) as forwarning, almost ALL dc jacks are sodered to the motherboard..and not easy to successfully replace.
Posted on Aug 04, 2008
Replace power jack
Power supply failures in a HP computer can cause your computer to fail to turn on, to operate erratically or cause certain system components not function.
However, the power supply is one of the easiest parts of a computer to replace.
You don't need any special skills to do this.
If you're nervous about opening up your computer case and potentially damaging a computer component, don't be.
All you are really doing is plugging in power supply cables after securing the power supply.
The process should take 10 minutes maximum.
Shut down your HP computer.
Disconnect the power cable from the power supply on the back of your computer.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards.
Unscrew the side panel from the back of the case and slide it off.
Newer HP computers may have a case door you can open for access or have access buttons to press.
Look at the back of your HP computer case for a set of four screws near the top of the case. Remove these screws and set them aside.
Carefully slide your power supply out of the mounting brackets and set it on a clean working surface.
Do not disconnect any of the power connectors yet.
Slide your replacement HP power supply into the case and use the mounting screws to attach it to the chassis.
Use your old HP power supply as a guide to connect your new power supply to all the computer components.
Switch the power cables from each device from the old supply to the new supply so you don't miss connecting any cables.
Check that all the components have power cables inserted and the old HP power supply is completely disconnected from the system.
Close the HP computer case and plug the power cable into the new HP power supply.
http://www.fonerbooks.com/r_power.htm
Apr 15, 2014 | HP Hewlett Packard Pavilion Slimline...
I have no clue how to describe my problem.
If a tech opens the case, you're not going to lose your warranty, even if you do it. It sounds like the plastic container that you plug your power supply into has either broken around the outside or has come lose. If usually fits between both pieces of the case, so you have to open it to put it back in place.
Mar 17, 2013 | ASUS Computers & Internet
No ac or battery power
Here are the possibilities from start to finish
A. The outlet you are using is bad try another outlet.
B. The wire going from the outlet to the adapter box is defective (you may have a light on your adapter so if it is on the you know that this isn't the case).
C. The Power Adapter Circuitry or fuse has gone defective. This is NOT recommended opening up and troubleshooting!! SMPS crammed into a little box are DANGEROUS !!!
D. The cable going from the power adapter circuitry housing to the computer ends connector is defective. You can test the power adapter output voltage at the connector end if you know what your doing with a multimeter, otherwise also not advised to do!!
E. The connector on your power adapter assembly has gone defective and no longer mates properly with the female power jack on your computer.
F. The power jack on the computer may be damaged and no longer mates with the Male power adapter end.
G. The power jack on the computer's solder connections on the motherboard have become damaged.
H. The power jacks cable going to the motherboard is defective.
I. The motherboard has been damaged by any of the above conditions.
There you go 9 possibilities. All in all; get a new power adapter that matches Voltage and Current Requirements printed on the sticker underneath your laptop. If that doesn't work, then you would have to open up your laptop and get real technical with your power jack and motherboard.
May 16, 2012 | Sony VAIO VGN-NW160J/S PC Notebook
Broken power plugin port
The power plug in port you refer to is the DC Power Jack.
The AC adapter (Charger) converts AC electricity into DC electricity.
DC electricity has two poles. Positive, and Negative.
(Just like on a D cell flashlight battery)
The center pin of the DC Power Jack is the Positive connection.
The outer metal spring-like pieces, on the inside of the cylindrical shape surrounding the center pin, are the Negative connection.
(The pieces of spring-like metal, all connect to the Negative connection in the DC Power Jack)
Example of a replacement DC Power Jack, for the Asus Eee PC 1005HA Netbook,
http://www.batterysupport.com/asus-eee-pc-1005ha-jack-p-303527.html
[ Note*
Cannot agree with the replacement instructions they offer, at the bottom of the page.
Not everyone has access to a hot-air gun. A 25 Watt soldering iron, and Desoldering Braid, is better, and more easily accessed ]
A few articles dealing with replacement of a DC Power Jack,
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
http://www.laptoprepair101.com/laptop/2006/01/28/toshiba-satellite-m35x-a75-power-jack-problem/
http://www.laptoprepair101.com/laptop/2006/05/27/failed-laptop-power-jack-workaround/
1) Remove ALL power. Remove the AC adapter, (Charger), and Battery.
2) Observe Anti-Static Precautions. Buy, and use an ESD wrist strap.
Electro Static Discharge.
(Average cost is from $3 to $6. Connect the alligator clip to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
If you wish to proceed in replacing your DC Power Jack, and need guidance, post back in a Comment.
Regards,
joecoolvette
Dec 01, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Will not power up, tried switching batt and a/c adpt. Like the on/off button does not work
You may have a problem with the input power jack. The jack itself maybe open and does not provide power to charge the battery or power the computer. The laptop must be disassembled to check and/or repair the jack. Try getting the battery charged from another similar laptop and then see if the laptop powers up - if it does, the problem is the jack. Worst case is a bad motherboard.
Oct 28, 2010 | IBM ThinkPad T40 2373 Notebook
No light when charger connected to laptop.
You do not have to resolder the connection, the dc jack is attached to the motherboard via a cable and plug. You can purchase these on Ebay for under 20 bucks. Below is the link to the disassebly guide that will assist you.
This link here is for the DC jack...
http://cgi.ebay.com/HP-G60-CQ60-DC-IN-Power-Jack-Cable-50-4H515-001-/110525996737?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item19bbdcdec1
This link is for the illustrated guide to removal of the motherboard.
http://www.insidemylaptop.com/remove-motherboard-from-compaq-presario-cq50-cq60-cq70-laptop/
Jul 27, 2010 | HP Computers & Internet
Laptop won't power on, suspect bad power port, is it better to replace just the power port or the whole motherboard? How hard is it to replace the whole motherboard?
Depends on the machine. In some case, the dc jack is easy to replace. IN other cases, you need to do soldering.
It takes about an hour to open an average laptop for the first time. When you get down the motherboard and jack. If the jack has power lines coming from it, you should be able to replace the jack for about $30.
If it is directly on the motherboard, you will need to solder. I would suggest a pro to do the soldering. That will cost you about $100 to $150.
You don't need to bother with the motherboard. It will cost more than an new computer.
May 15, 2010 | Gateway MT6705 Notebook
A105 won't power up...no power adapter light on
Did you experienced any overheating before that happened?
Apr 11, 2010 | Toshiba Satellite A105 Notebook
Need to open Advent 7072 case to resolder power jack socket...How?
This is something that should be left to a professional. A local repair shop should be able to handle this task easily. but if you insist you can try here
Apr 17, 2009 | Computers & Internet
Averatec 3200 Notebook Logo
79 people viewed this question
Top Averatec Computers & Internet Experts
k24674
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
