Question about Motorola Mobility RAZR V3i Cellular Phone
Motoprob the prob actually seems to be with the keypad!!! the keys continuously gettin pressed or somethin close to it!!!! will changing the keypad fix the prob!!!
  • 59 Answers
Hello there. yes changing the keypad will slove your problem without hassle. Hope i helped bye!
Posted on Aug 04, 2008
How do i get the internet explorer message that appears from time to time off the screen of motorola mc3190 without having to shut it down
The key combination you looking for to close any window or message in a Windows environment is ALT+F4, depending on the type of keypad the Motorola MC3190G are using.
Please Note: Keypad functions can be changed by an application so the mobile computer keypad may not function as described.
48-Key Keypad
The ALT functions are indicated in blue on the keypad, so in order to use these, you have to activate the ALT Functions first by pressing the BLUE BUTTON (FUNC) (Right side below ENTER button) and then press the CTRL BUTTON (left side below BKSP button).
After the key combination is pressed, the ALT icon appears on the taskbar on WinCE devices or the ALT icon appears at the bottom of the screen on Windows Mobile 6.5 devices.
Now you can press the "D" button to use F4, this will close any window or message that is currently in view.
38-key Keypad
Press the blue FUNC BUTTON (Right side below RIGHT ARROW button), and then press CTRL button (Middle below UP ARROW button), now you can press the F4 button.
28-Key Keypad
Press the blue FUNC button (Bottom right next to Power button), and then press the CTRL button (Top right side below RIGHT ARROW button), now you can press number 4 to use F4.
Hope this helps, good luck.
Jul 02, 2014 | Zebra Symbol MC3190G Handheld Mobile...
Hello I have an Access Master Chamberlain garage door opener and i never had to change the garage code. Can u assist me in changing the code?
Well I have to assume you want to change the code for the keypad because that is the only code you can actually change. Locate the smart/learn button on the rear of the motor unit near where all the white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jun 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My spouse changed my security and phonelock codes
Try this out:
  • Press Menu
  • Use the Navigation Key to scroll to Settings and press the Center Select Key
  • Use the Navigation Key to scroll down to Security and press the Center Select Key
  • Use the Navigation Key to scroll down to New Passwords and press the Center Select Key
  • Use the Navigation Key to scroll down to Unlock Code and Press the Center Select Key
  • Press the keypad to Enter Old Unlock Code (Default 1234) and select OK by pressing the right soft key. If you have forgotten the unlock code, press Menu and enter the Security Code (000000)
  • Press the keypad to Enter New Unlock Code and select OK by pressing the right soft key
  • Press the keypad to Re-enter New Unlock Code and select OK by pressing the right soft key
Nov 10, 2009 | Motorola Mobility RAZR V3m Cellular Phone
My keypad is crazy,presses keys itself,all func. hav changed.
ok!!! your phone needs some clean coz the your keypad is randomly cant press will right!!!! then there is something on the switch of your phone i think you press it hard thats why the switch is not functioning well!!! that is tjust the problem of your cellphone ok!!!!
May 20, 2009 | Nokia N72 Cellular Phone
How do i reprogram my HV board?
HERE TIS RIGHT OFF THE INSTRUCTION SHEET.  THE TECH JUST LEFT. POWER UP REF. PROGRAM CODE IS LOCATED ON SERIAL PLATE ON THIS UNIT AFTER THE WORD CODE.-1. PRESS & HOLD THE DOOR ALARM KEYPAD.-2. PRESS & HOLD FREEZER TEMP DOWN KEYPAD.-3. RELEASE DOOR ALARM KEYPAD AND WAIT 3 SECS.-4.CONTROL WILL DISPLAY PE TO INDICATE PROGRAMMING MODE-5. ENTRY IS CONFIRMED BY PRESSING TEMP DOWN - KEYPAD ONCE MORE.-CONTROL WILL DISPLAY CURRENT PROGRAM CODE. THIS VALUE SHOULD BE VALIDATED THE THE PROGRAM CODE PRINTED ON UNIT SERIAL PLATE.-NOTE: IF PROGRAM CODE IS CORRECT, THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOOR.-7.PRESS REFRIG TEMP UP KEYPAD + OR REFRIG DOWN KEYPAD -TO CHANGE THE DIGIT VALUE WITH EACH KEY PRESS.-8.THE DECIMAL POINT INDICATES THE SELECTED DIGIT. PRESS THE FREEZER TEMP UP KEYPAD + TO SELECT NEXT DIGIT.-9.ONCE DEIRED PROGRAM CODE IS DISPLAYED, PRESS AND HOLD THE FREZZER TEMP DOWN KEYPAD - UNTIL UNIT PROGRAM CODE BEGINS FLASHING INDICATING IT HAS BEEN SAVED. *note* IF YOU ATTEMPT TO ENTER AN INVALID PROGRAM CODE, THE CONTROL WILL NOT SAVE THE NEW CODE, BUT WILL BEEP! (THE UNIT WILL NOT RUN RUN WITH A UNIT PROGRAM CODE OF 0000). ONCE THE PROGRAM CODE HAS BEEN SAVED THE PROGRAMMING MODE IS EXITED BY CLOSING THE FRIG DOORS.
Oct 26, 2007 | Maytag MFI2568AES Stainless Steel Bottom...
Razr Key pad not working
hi
it seems you have a prob in its keypad flex... try changing it and your prob is solved...
Oct 10, 2007 | Motorola Mobility RAZR V3
Some menu automatic update key not work
hi
i think thiers a prob in your switch. try opening your phone and try cleaning your keypad boards. maybe it is shorted or get dirty inside...
hope it helps...
Jul 10, 2007 | Sony Ericsson K510i Cellular Phone
KEYPAD PROBLEMS
Dear Make is software if ur phone key are working on wrong function. if not ok then change the key pad ic (both)even not ok then its prob from CUP check might be possible that when u press the button with speed ur mobile goes on restart then its prob from CPU.
Mar 30, 2007 | Nokia 7610
Motorola Mobility RAZR V3i Cellular Phone Logo
41 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
