I have a kleenmaid washing machine which has stopped agitating and spinning. Motor turns freely, gearbox turns freely but the belt is badly frayed. Can this be my problem.
  • mark1835 Aug 15, 2008
    My 1998 Kleenmaid washering machine doesn't spin at full speed. The gearbox and components and bearings all seem to rotate freely. I noticed there is a brake system on the spinner. Does this brake bit fail? or is a likely that a new belt would get the spinner back to full speed?
    Problem Solver:
  • 12 Answers
Replace the belt with the correct type and size for that machine.....
Posted on Apr 03, 2010
    Scholar:
  • 111 Answers
If the belt turns the gearbox it's not your problem. Otherwise it is. Could also be the clutch.
Posted on Jul 25, 2008
Washer will not spin or agitate
Can you move the agitator freely by hand?
Jun 26, 2013 | GE WJRR4170E Top Load Washer
Whirlpool mach. is humming when u turn on but agitator won't move
Hello friend,
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
In case of the agitator not moving check the following:
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer.
Check the above, It seems that your washer needs a repair and would not be possible to do it yourself. So yau will have to call a technician.
Do feel free to get back to us in case of any other assistance if problem is not solved or if you have any other query.
Thanks
Mar 05, 2010 | Whirlpool Washing Machines
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Agitator sounds as if it's stripped
The agitator and drive gearbox are all one part and are not serviceable (sealed), if it is the gearbox the machine is possibly scrap as the part is more expensive than a new machine. Will need further investigation.
Is the spin OK (quiet) the motor rotates one way to agitate and the other way in fast to spin, the belt may be removed at the middle pulley (Below) rotated in each direction to test. try the machine without the belt and listen to motor.
Nov 25, 2009 | Admiral AW22 Top Load Washer
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Washer won't spin or agitate
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
188 people viewed this question
Top Washing Machines Experts
