Video sender when using the sender the recieving tv does not get a colour picture it recieves a black and white one what can i do
  • brosie Jul 28, 2008
    did not work. thanks anyway if it helps the video sender i am using is a thomson video sender VS360U any help would be brill
The sender is off frequency
do a channel search and your tv will find the improper one.
Thanks guy9
Posted on Jul 25, 2008
Wii connect to samsung smart tv series 8
This is due to incompatibility of color system,i.e., using PAL for Secam etc. Always connect yellow RC jack to yellow RC socket.
Jul 30, 2012 | Televison & Video
Black and white picture from blu ray player
Run the Blue Ray straight to the TV and see if the picture is still in black and white. If it is you know that your reciever is fine and the problem lies in the player or the TV. If the picture is normal then you probably have a bad HDMI IC that will need to be replaced.
May 09, 2012 | Onkyo TX-SR607 Receiver
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Hy does a colored tv record in black and white on
I suspect that you have the video standard is incorrect. Ensure you are recording in the same format as the signal you recieve. IE: NTSC or PAL. Whatever but they should both be the same. IE: Signal recieved = NTSC Video recorder must be set NTSC as well. Same goes for PAL.
Jan 13, 2010 | Quasar VV-2002 20 in. TV/VCR Combo
Connected denon avr 1800 reciever to new hd tv. i cant find my reciever manual. how do i set the reciever to play the tv sound?
If you connect your tv's audio output to the reciever's audio input in the (TVor video section) using audio cables only---red & black or red & white) then select TV or Video on the front of the reciever depending on which connection on the back that you use it should work fine!!
Nov 06, 2009 | Denon AVR-1800
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Help with AG-D9320
These recievers are prime for running surround sound through you TV. It all depends on your TV service, Now if you have a cable box from Dish network, this is the easiest in the world, all you need to look for is an output labeled "OPTICAL OUT". It's a small port with probably a small glowing red light coming out of it. You'll need to buy and optical cable and plug it in there, and then run the other end to the optical input of your surround sound reciever, and then assign a video input to that digital audio signal. It's the best audio you can get by far.
Now if you down't have that, it is still very easy. Find you reciever look for a video input and plug an audio cable in(Red and White cable). Plug the other end into your TV's audio output, a red and white output that is probably labeled audio out, plug that in, switch TV to whatever you are viewing, turn on the reciever to whichever input you assigned and there you go.
If your TV doesn't have an audio output, then you need to go to your cable or sattleite box, and find the audio output, the R/W(Red & white), and run that out to your reciever, the sound won't come through the tv unless you run a second audio out from the reciever into you tv's audio input on the same signal your picture is coming from.
I hope that helps.
Jan 07, 2008 | Teac AG-D9320 Receiver
Avermedia Averkey lite - Monitor Colour Display Issue
I had the same problem. I was going from PC -> Dvd recorder -> TV.
I had the S-Video output from the averkey going via an adaptor into the DVD scart input. I discovered a setting within the DVD menu which could select between 's-video' and 'composite video' on the scart socket. (it appears that scart can carry either/or, I guess).
I changed from composite to s-video, and I got colour.
I think seeing a greyscale image indicates that the signal being sent is S-Video, but the equipment that is recieving it is expecting composite video.
Sep 23, 2007 | Avermedia QUICKPLAY (pquickplay)
Televison & Video Logo
212 people viewed this question
Top Televison & Video Experts
