Question about HP 1040 Plain Paper Inkjet Fax
Fax no longer works. Calls are coming in but the system will not switch to fax
  • tonybrogdon Aug 07, 2008
    calls come but does not answer
    how do I set to auto recieve fax after 4 rings?
    I have set for fax mode
  • 51 Answers
Check that your receive mode is set on FAX ONLY.
Posted on Jul 24, 2008
1. Machine is on telephone line shared with a 3 handset cordless Uniden system so telephone may be answered around the house. The machine no longer rings when calls come in so we only here the Uniden...
These machines come with several receiving modes that can be programmed ... mostly by design but quite often ... by accident.
I would check the User Manual for Ring Patterns, Silent Reception and Fax Priority.
You can always see or print out the Option Settings of your facsimile. There it will show the exact picture of what the fax must know before answering the incoming call.
Does it have Fax Tone Detection? Is it set for automatic answering? Faxback? Polling?
Maybe a power hickup might have scrambled some of the programmed features?
Obviously nobody in the location monkeyed around with tha fax buttons, right?
By George. Of course not!
Please feel free to contact me anytime.
Feb 14, 2011 | Canon FAXB840 Plain Paper Bubblejet Fax
We went to a roll over system on our phone lines and now we cannot receive faxes. We can send them though.
Your roll over system is sending calls to the first line in the sequence and it does not differentiate between voice and fax. You will have to change the roll over so it does not send calls to your fax line. Your internal phone system may still use the fax line for outgoing faxes and voice calls but incoming fax calls have to be sent to the line the fax is on.
Jul 13, 2010 | Brother IntelliFax-2820 Laser Fax
My printer is hooked up to a phone line that gives a different ring when a fax come in. I have been able to fax documents,,can't receive them and no longer get calls on the line because when i pick up the...
Perhaps you can talk to your telephone service about setting up a second line just for your fax sending and retrieval. There must be some type of deal they could give you..especially if you are a loyal customer.
Feb 26, 2010 | HP J4680 Office Jet All-In-One Printer
Switched to shaw digital phone service from mts. my ph # and my fax # are different numbers but when phone calls come in the fax picks it up instead of the do i change this?
Call a cell phone from the fax machine to find out what the machine's number is.
Be warned, tho, fax machines will not work reliably on digital phone lines.
Feb 20, 2009 | Brother IntelliFAX 2800 Laser Fax
FAX Is Receiving all calls-No Voice Calls
In usermode go to rx settings and switch "incoming ring "to on.
Sep 15, 2008 | Canon FAXPHONE L80 Laser
Canon image class MF4150 distinctive ring
How to Set the Receive Mode (MF4140/MF4150)
1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Tel/Fax/Answering machine keeps freezing
Dear mariss34
While receiving a fax you shouldnt pick up the handset, but if u pick accidently then u will not recieve fax and hence u will hear an engage tone. If you are using a single line for both tel and fax then the party who is sending the fax should pre-inform you that it is a fax call so that when it rings you dont pivk up the handset.
You can also check your line weather it is working properly by using a normal telephone. This should be the first step rather, make calls to confirm it.
The last option is Power off the tel/fax machine for 3min completely and then try again.Also make sure the tel/fax is in tel mode and not in fax mode. Try to assign it in both modes.
If still you are not clear then the mannual which comes along with should help you, If still you cannot figure it out, Then you can call your service provider for help, they should definetely help you out.
Feb 10, 2008 | Office Equipment & Supplies
Epson ACULASER CX11NF incoming fax problem
Try this:
Unplug line from back of printer
Set the Incoming mode to autoswitching
set DRPD to Off so that it will recognize all incoming calls
** if possible call your telephone company and set a distinctive ring pattern for phone calls
replug cable on line port at the back of printer
then ask someone to send you a fax...
Feb 05, 2008 | Epson ACULASER CX11NF All-In-One Printer
Sharp plain paper ink jet fax ux-b750
to stop the fax automatically switching to fax mode you have to set it to manual to recieve calls and dissable the fax,there should be an auto/fax and call mode, therefore when someone calls it will go to your voicemail, but that means that you will not be able to recieve a fax. Normally auto mode, will first try the fax, if no fax is recognised it will switch to normal line ringer, then if no answer it should go to your voicemail if unanswered.
Oct 01, 2007 | Office Equipment & Supplies
HP 1040 Plain Paper Inkjet Fax Logo
Ben Johnson
