Question about Canon imageRUNNER 3300 All-In-One Laser Printer
Hello We connected our Cannon IR3300 photocopier using lpt1 printer cable. no printouts. please help.
    Sniper:
  • 89 Answers
You have C Boot Rom. You need N Boot Rom and a tech to install N system software using SST. You may as well get a NIC and network it while you're at it. Cannot print without N Boot Rom and correct firmware installed on copier.
Posted on Jul 17, 2009
  • 3 Answers
Go to add printer, and select not lpt1, goto creat port and select standard tcp/ip and put it ip address whatever in copier then print out came
check it
from
Muthu, India
pearlpdy@yahoo.com
Posted on Aug 13, 2008
    Problem Solver:
  • 11 Answers
First, I assume that it copies, etc. I would try rebooting the computer and go into the BIOS settings and check the configuration of the lpt port. You might see choices such as: EPP, ECP, BiDirectional or some such nomenclature. Whatever it is currently set at, try another one of the settings. I've typically found that either ECP or BiDirectional tend to work the best. Or, as an alternative, you could use the network interface and make it a network printer.
Posted on Jul 28, 2008
How do i fix toner stain on printout and photocopies? please what might be the cause of the dot stains?
There are several reasons for stains on a Laser printer or photocopier
1. Clean all rollers. Fuser; transfer and pickup.
2. Ensure the toner is clean from outside.
3. Hope the Toner is not refilled and Is not leaking.
4. Clean paper path.
Mar 08, 2016 | Office Equipment & Supplies
Canon printer prints an extra page with a message ""@PJL INFO STATUS""
More information is required like are you using windows 7 or windows 8. Suspect you may have wrong PCL driver. PCL.
Press additional functions on printer keypad. Press report settings on LCD screen. Press Printer on lcd screen then press configuration and press yes to printing configuration page.
Look at the configuration printout to see if you can find the language the printer is using is it PCL3 ,PCL6, PCL5E, PS3 ..
This has to match the driver you are using !
All these drivers are available to download from Cannon but finding the matching driver can be done via trial and error but the configuration page is easier and less painful.
A mismatched driver to printer is possibly the cause of the extra page print.
Nov 09, 2013 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Where is LPT1 USB port on Lenovo H430 for printer
Few computers use LPT1 connections, most use USB .Use a Printer cable with a USB to laptop. Your printer should have a cable that has a printer connection to a USB laptop connection? What is the Printer?
Dec 13, 2012 | Lenovo H430-2558-1CU Desktop PC
Having trouble adding printer canon ir3300 thru ethnet connection. directly to laptop. This printer isn't on the current network. So, I'm not sure if I need to add it first. Can you please advise.
You will need to buy a "Crossover Ethernet Cable". A ordinary straight through ethernet cable will not work. When you connect the crossover cable the laptop will see it and assign an IP address as though it was on a network. You then need to create a standard IP Port. take a config printout and look for the ip address. Add a single digit one to the address and make that you std IP Port.
Install your network driver and it will look for the printer on your new network (your laptop and printer). providing it does then all should work ok.
Good luck.
Aug 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
I lost the installation of my ir3300 and we need to install it in one of our new computer
Hi, web site, should have your solution:-
The Canon imageRUNNER iR3300 Photocopier/Copier/Multifunction ...
The Canon imageRUNNER iR3300 Photocopier/Copier/Multifunction Printer/Multifunctional Device will handle all of your office or workgroup's tasks.
www.canoncopiers.co.uk > Discontinued Photocopiers
Jun 05, 2011 | Office Equipment & Supplies
Scanner driver for cannon ir3300 connected to lpt1 port
Canon Network ScanGear only works over an ethernet connection. There is no scanning available via LPT1 port.
Dec 23, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Sir, Print coming out like a sign wave..
sir i have a canon ir3300 machine its print clarity and neetness
but the problem is coming print out is in a waves how can i solve this
Dec 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Canon ir3300 or 405 better
Definitely go with the 3300 (if you haven't already). It's one of the best B&W copiers Canon has ever produced. The 3300s still sold as refurbs by Canon in the US so parts will be around for them over there for quite a while yet.
Oct 08, 2008 | Canon Office Equipment & Supplies
Unsloved probl?me IR3300
Some unknown problem my ID is saying Big Lots not my normal na44f.
May 29, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
161 people viewed this question
old marine
old marine
