posted by warasta on Jul 24, 2008
we buy canon copier ir3035 with all acces,every thing is don but we cant install properly pdl kit,because its not accepet printing from networking or we tray to print through usb port as will after install cd to our pc.we have access licence number as will but when we go online so its not accept and not issue acctivation code to get printer option.please guid us with advance thanks
Best Solution
posted on Jul 29, 2008
(This is for your information)First ur problem is not mentioned clearly. You are mentioning network printing is having problem (this is ok) but it is not clear that printing from USB is having problem or not. And you did not mention the type and version of your operating system(OS) and the nature of your network. Installing driver is very crucially depend upon the OS and the type of network that you are having.
Let assume that you are having genuine MS Windows 2003 Server as the backbone of your network and genuine MS Windows XP SP2 as the OS of the client PCs. Some basic knowledge of networking is required to understand and execute the remedy mention below. And you should read completely first before trying out this.
For network printing problem of Canon ir3035, first check the physical network cable(UTP) if it is properly crimped & properly connected, then check the connectivity by pinging the IP of the copier (which is needed to set manually if there is no DHCP server in the network). If the copier is responding properly. Check again by pinging the server from the copier (which you will find under MENU and NETWORK OPTIONS of the copier). If both the way is responding properly uninstall the printer driver totally and restart the system. Re-install the USB driver first and then re-installed the network driver (before re-installing the network driver first check whether it has got the required IP from the DHCP server, if not assigned one according to your network). If there is no error message during the installation of the USB driver(normally USB installation does not show any error), USB printing should be ok. Thus USB case is close.
Then check the network by using the same procedure mention above. If everything is ok, you can carry out the installation process for network driver. This way there should be no network printing problem. If still there is the problem please check that you are not using pirated copy of OS. Network printing for ir3035 is not ok if pirated copy of OS is used. You have to get a genuine copy and will solved the problem A to Z.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Canon FAXPHONE L80 Plain Paper Laser
Canon FAX-L200 Plain Paper Laser
Canon FAX-L250
Canon FAX-L800 Plain Paper Laser
Canon FAX L-120 Plain Paper Laser
Canon FAXPHONE L170 Plain Paper Laser
Canon LaserClass 2050 Plain Paper Fax
Can you Help with these Fax Machines problems?
Repair Service
Find Fax Machine Repairman Near You:
