Question about HP Photosmart 2410 All-In-One InkJet Printer
Printer jam My friend is in need of help. When printing the printer ink cartridges have just stopped in the middle of the carriage and it just won't clear. Any idea how to solve it.
    Novelist:
    Scholar:
  • 125 Answers
I think you should bring the printer to have Hp check it out. If you think you can fix it, probability is that there is something snagging the inkjet carriage that is preventing it from printing. This is not unusual for HP printers. We have had 2 HP's that did this. We didn't fix it but sent it to Hp who replaced them. The problem was mechanical failure where one of their component broke off and caused the carriage to get stuck. Hope this helps.
Posted on Jul 24, 2008
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
Alarm message says "cartridge jammed". Does that
What you see moving is the print carriage. The carriage moves the cartridge, adjacent to the printhead, back and forth.
Although the carriage is moving, the ink cartridge can not dispense ink because an obstruction is
blocking the path of the ink.
Remove the ink cartridges, inspect the cartridges as well as the cartridge holders for any foreign debris and reinstall.
If the alarm message continues, I suggest changing the ink cartridges.
Feb 17, 2011 | Canon MultiPASS F50 All-In-One InkJet...
Paper keeps getting jammed
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.
Nov 23, 2010 | Lexmark Office Equipment & Supplies
I need to replace the print cartridge but the carriage only stops on the far left under the frame. How do I get it to stop in the middle so the ink cartridges can be replaced?
switch the machine off then open the cover for ink cartrigde move the belt that the printer heads are on until in the middle replace cartridges and switch on machine this should work if the cartridges still does want to move the carriage rail could be very dirty and requires cleaning if you do not what you are doing advise you get a tech to assist you in this matter
Oct 18, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to free carriage jam on lexmark X4550
There is a rod in the carriage of your printer that is meant for holding the cartridges. It keeps on moving and spreading the ink on the paper throughout the process of printing. If this rod is jammed because of any reason, you face a carriage jam. As mentioned above, the main function of the carriage rod is to spread the ink, so obviously any clog or ink failure will lead to a poor print quality. If rollers of your printer are leaving marks on the document, then you need to clean them with a wet cleaning pad. Never use the chemical cleaners such as benzine, thinner, or alcohol to clean the rollers. In extreme cases you might need to replace an old cartridge of your Lexmark Printer with a newer one. Once you get a new cartridge for your printer, you need to be very careful while replacing it, otherwise it might cause a carriage jam.fix Lexmark Carriage Jam .
Sep 18, 2010 | Lexmark Office Equipment & Supplies
Its stop printing and the LED power light green and orange at the center blink, like there is a paper jam.
Feb 11, 2010 | HP DeskJet 1280 InkJet Printer
Unable to install cartridge
Hello my friend, regarding on your problem in installing your cartridge you can see it inside in your printer. Open the printer cover then wait for the cartridge holder to stop swinging and stay in the middle then pull out the two platic attach to the cartridge holder. The plastic u pull out are the ink cartridge and then insert new ink cartridge then insert it again in the cartridge holder the close the printer cover and then you can print and used the printer. Don't forget to turn on first your printer before removing the cartridge.
Jun 16, 2009 | HP DeskJet F4280 All In One Printer InkJet
Carriage jam on HP Officejet J5780 All-in-One
We have several of these in our company and the most common "Carriage Jam" cause is a glob of black ink in the bay on the right side. Once glob is removed, and "Carriage Jam" message appears again, press OK, and it prints fine from then on. Today the black ink glob was flat on top. Watch out for leaky cartridges, as the design of the particular HP device provides a nice catch pan for the tri-color ink cartridge, but not for the black one, so a leaky cartridge, besides being expensive and wasteful, can goop up the bay causing the carriage jam error message to try to get you to take a closer look.
Jan 09, 2009 | HP Officejet J5780 All-In-One InkJet...
Ink cartridge carrier jam
If possible, shut off the printer completely and manually move the ink carriage to where the cartridges can be swapped out. turn it back on and try again. try to see if some mechanism that holds the missing cartridge in place has swung down and is bumping into something, preventing the carriage from moving past a certain point.
Aug 21, 2008 | Dell 926 All-In-One InkJet Printer
HP Photosmart 2410 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
