FixYa.com
Tags:
Network Adapters
Generic problem for all Intel Network Adapters
Drivers
posted by ilove2care on Jul 24, 2008
i have an msi motherboard with intel chipset[msi 6541]
so could u kindly give me correct drivers
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jul 26, 2008
Not Rated (0)
colyn25
Rank:Master Master
Rating: 79%, 5 votes
hullo put the following link in either your browser or your download accelerator. download that file and use it to install your sound driver.
ftp://ftp.hp.com/pub/softpaq/sp27001-27500/sp27103.exe
if it doesnt work please post the model of that computer.
i wish you luck.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 25, 2008
Not Rated (0)
olad
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
just create an account in driversguide.com
when you have an account.. just login on the login page
den select the type of driver you want to search
including the model number
diversguide will open the driver that you want
and you have to download it
after downloading... run the EXE or ZIP file
den it will automatically update the driver for your kind of device
Solution #3
Not Rated (0)
lucentrip
Rank:Wiz Wiz
Rating: 91%, 10 votes
I couldn't find the drivers on Microstar's website. There's a good chance you can download all the drivers you need from the computer manufacturer's website. For example, some of the Compaq EVO models have the MS-6541 motherboard.
In that case you would go to the HP website (since the two companies are now one), and look up the model number of your computer. From that location you can usually get all the motherboard drivers you need.
What is the make and model of your computer?
Solution #4
Not Rated (0)
Consultapro
Rank:Master Master
Rating: 73%, 5 votes
Please go to driveragent.com
This Problem Also Relates To: Intel REALTEK PHRE10/100PCI ETH RJ45 100MB (nc-r150201) Network Adapter Intel PILA8474B / PRO/100 S Server Adapter(TP) (PILA8474BUSED) Network Adapter Intel PILA8470B /OEMIntel PRO/ 100+ Server Adapter(TP) (PILA8470BUSEDOEM) Network Adapter Intel PRO/100 S Network Adapter PCI PCI-X 2 x RJ-45 10/100Base-TX 10Mbps Ethernet 100Mbps Fast Ether... Network Adapter Intel PILA8464B /RETAILIntel PRO/100 S Management (TP) (PILA8464BRETAIL) Network Adapter Intel PILA8470B / PRO/ 100+ Server Adapter(TP) (PILA8470BUSED) Network Adapter Intel PILA8460BN / PRO/100+ PCI MANAGEMENT ADAPTER (PILA8460BNUSED) Network Adapter
Can you Help with these Network Adapters problems?
Network Adapters
microsoft isatap adapter #15
i cant find the solution why my... Answer This...
Network Adapters
siemens dc drive dc500s
control card not com with... Answer This...
Minicom Classnet Twist Network Adapter
Minicom Classnet Twist Network...
Hi, I used to use Minicom... Answer This...
Network Adapters
lan drivers problem
hi  munish here actually... Answer This...
Broadcom BCM5721 NetXtreme Gigabit Ethernet...
RHEL5 with BCM572 probs
having problems w/ this... Answer This...
Repair Service
Find Network Adapter Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
