My split system airconditioner made a bang when turned on and it threw the safety mechanism in the fuse box. When the safety trip was restored in the fuse box, the airconditioner displayed a code "CS" or "C5" (can't tell the difference). What does this code mean? My split system airconditioner made a bang when turned on and it tripped the safety switch in the fuse box. When the safety trip was restored in the fuse box, the airconditioner displayed a code CS ? Was unable to find any reference of CS in the instruction manual. Turned the unit off and on again, no safety tripped, but unit would not operate and after a couple of minutes displayed the same message CS. When switched back on all displays were working fine but no air at all coming out of unit? Please help.
  • 143 Answers
Something has exploded. Look inside to see what it was.
Posted on Jul 24, 2008
What meaning of e7 error code on disply starway split airconditioner.
This is all I could find for E7 error code:
E7 Loss of 120 VAC power to all power module boards on the system. The system will shut down.
Look for tripped circuit breaker or tripped GFCI outlet. Any outlet wired downstream of GFCI (for example on same circuit as GFCI in bathroom) will lose power if bath GFCI is tripped.
May 13, 2017 | Miscellaneous
My Bonaire evap cooler keeps tripping the fuse when I turn it on
there is an electrical short in the unit that is causing the fuse / breaker to trip
could be insulation, moisture in a junction connection or failing motor
Call in an accredited electrician to find / fix the fault
Mar 12, 2016 | Dryers
Is it worth trying to repair a conia dishwasher that tripped our safety switch and appears to have burnt out the element?
May be an element that needs to be replaced. It also may have taken a logic board along with it. What make and model number are you asking about?
Aug 19, 2015 | Dishwashers
Is there a reset button?
The bang came from the fuse box (circuit breaker) or the machine? Check your fuse box for a tripped breaker (one switch slightly out of alignment). Turn fully off then on to reset.
Jul 29, 2014 | Fisher and Paykel Washing Machines
Went bang tripped fuse now wont turn on
Did you flip the switch in the switch box back on?
Dec 26, 2013 | Kitchen Ranges
Wont Turn on at breaker or fuse box.
check the braker box, and also there shold be a togle switch by the furnace that could be turned off.it sounds like you don't have any power at all
May 29, 2009 | Ruud Matching Split Air Conditioner
Oven element tripped main fuse box switch
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
Feb 24, 2009 | Bosch HBL 5032 Electric Single Oven
My split system airconditioner made a bang when turned on and it threw the safety mechanism in the fuse box. When the safety trip was restored in the fuse box, the airconditioner displayed a code...
It sounds like the compressor in the outdoor unit is shorted to ground. Checking this should probably be done by a qualified professional due to the dangerous nature of the high voltage that the outdoor unit uses.
Jun 19, 2008 | LG Heating & Cooling
Heating & Cooling Logo
282 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
