Question about 3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch
Dynamic Vlans sir i have in problem about Dynamic Vlans Configuration in 3com superstack 4 switches. i have been configured IAS server, Active directory, dhcp and winxp client but i m not able to connect LAN. kindly help me about Dynamic Vlans configuration and provide me authentic document.. i m very thankful to u.. REGARDS, SYED BAQAR RAZA
alex8642
  • 21 Answers
SOURCE: frequent wireless disconnections 802.1X WPA TKIP
try using predefined IP addresses. Let each pc make it's own IP address and see if the conflicts continue, if they do, post again. :)
Posted on Feb 11, 2007
fossilruins
  • 114 Answers
SOURCE: enter the switch configuration
page 22 of the 3com user guide for your switch talks about how to use the console cable and how to connect to your pc, I included the link below for your manual, if you don't have it:
http://support.3com.com/infodeli/tools/switches/baseline/3Com_Baseline-Switch-2916-2924_User-Guide.pdf
Posted on Jun 21, 2008
SOURCE: Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Posted on Jun 08, 2010
  • 17 Answers
SOURCE: I want to know the
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Posted on Jul 18, 2011
  • 9 Answers
SOURCE: 3com superstack 3 switch 3300 reset himself randomaly need a solution
take it to the 4s garage, if you want to find out the problem by yourself,you first have some professional tool , there are some diagnostic that always can figure out the problem i can show you: www.xcardiag.com/
Posted on Apr 12, 2012
How to configure VLANS and Tagging
https://m.youtube.com/watch?v=krE16IRIHw4
Watch this video for switch port access . You will need to be in global config interface mode.
Jun 05, 2016 | HP ProCurve Computers & Internet
Superstack 3 3848 reset at default
Hi ! I think this solution should be approached. Because this procedure is the same for switches 3Com and HP A-series with Comware OS.
1. Connect light blue console cable between a computer (serial) and the 3COM switch (RJ45 console port)
2. Open PUTTY or Xshell or HyperTerminal with a serial connection and the following settings (19200, 8, 1, N) If not connected may use 9600 or 115200 bps
Starting......
* 3COM 2928-SFP Plus BOOTROM, Version 119 *
Creation Date : Feb 3 2010
CPU L1 Cache : 32KB
CPU Clock Speed : 333MHz
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Mac Address : 002473959EC8
4. When "Press Ctrl-B to enter Extended Boot menu..." appears, press "CTRL+B"
Press Ctrl-B to enter Extended Boot menu...0
Please input BootRom password:
BOOT MENU
5. Press "7" to "Skip current system configuration"
1. Download application file to flash
2. Select application file to boot
3. Display all files in flash
4. Delete file from flash
5. Modify BootRom password
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set BootRom password recovery
9. Set switch startup mode
0. Reboot
Enter your choice(0-9): 7
7. Press "Y" to skip the current config at next reboot
The current setting will run with current configuration file when reboot.
Are you sure you want to skip current configuration file when reboot? Yes or
No (Y/N):Y
Setting...Done!
8. Now Press "0" to reboot the switch
BOOT MENU
0. Reboot
Enter your choice(0-9): 0
9. The switch will reboot, allow it to fully boot this time
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Starting to get the main application file--flash:/S2900-CMW520-R1101P09.bin!...
The main application file is self-decompressing................................
.........................Done!
System is starting...
Configuration file is skipped.
User interface aux0 is available.
10. Press "Enter", you will not need a password to login.
Press ENTER to get started.
<3Com Baseline Switch>
#Apr 26 12:00:16:292 2000 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>: login from Console VMadmin.co.uk
%Apr 26 12:00:16:461 2000 3Com Baseline Switch SHELL/4/LOGIN: Console login from aux0
11. Now type "initialize" to delete the configuration file and reboot the switch once more, Press "Y" to accept reboot.
<3Com Baseline Switch>initialize
The startup configuration file will be deleted and the system will be rebooted. Continue? [Y/N]:Y
Please wait...
#Apr 26 12:00:33:537 2000 3Com Baseline Switch DEV/1/REBOOT:
Reboot device by command.
%Apr 26 12:00:33:641 2000 3Com Baseline Switch DEV/4/SYSTEM REBOOT:
System is rebooting now.
12. The switch will full start up again, this time completely factory reset.
Starting......
CPU L1 Cache : 32KB
Memory Size : 128MB
Flash Size : 128MB
CPLD Version : 002
PCB Version : Ver.B
Startup configuration file does not exist.
13. Press "Enter", then enter the username "admin" and password "<blank>". Press "Enter" and you will be logged in.
Login authentication
Username:admin
Password:
#Apr 26 12:00:19:811 2000 this article is from VMadmin.co.uk 3Com Baseline Switch SHELL/4/LOGIN:
Trap 1.3.6.1.4.1.43.45.1.10.2.2.1.1.3.0.1<h3cLogIn>:admin login from Console
%Apr 26 12:00:19:981 2000 3Com Baseline Switch SHELL/4/LOGIN: admin login from aux0
14. If you type "summary" you will see all the switch details.
Amongst these details are the IP address of the switch. If you have DHCP on your network this switch is connected to it will receive one as in my case below, so I can now configure the rest via a web browser.
If not you can use the "ipsetup" command to set a static management IP and access via a web browser.
<3Com Baseline Switch>summary
Select menu option: Summary
IP Method: DHCP
IP address: 192.168.1.250
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.254
Current boot app is: flash:/S2900-CMW520-R1101P09.bin
Next main boot app is: flash:/s2900-cmw520-r1101p09.bin
Next backup boot app is: NULL
3Com Corporation
3Com Baseline Switch 2928-SFP Plus Software Version 5.20 Release 1101P09
Copyright (c) 2004-2010 3Com Corp. and its licensors. All rights reserved.
3Com Baseline Switch 2928-SFP Plus uptime is 0 week, 0 day, 0 hour, 1 minute
128M bytes DRAM
128M bytes Nand Flash Memory
Config Register points to Nand Flash
Hardware Version is REV.B
CPLD Version is 002
Bootrom Version is 119
[SubSlot 0] 24GE+4SFP Hardware Version is REV.B
15. Once you can access the web management page for the switch make sure you set a strong password for "admin" and store it in a secure encrypted location for next time.
16. Don't forget to save your new configuration! Otherwise the switch will be at factory defaults if the power goes off!!
Jul 24, 2017 | 3Com SuperStack 3 3848 48-Port Gigabit...
Can not connect my laptop. wireless signal on laptop says limited access and cannot find ip address
Check these :
- Check that your ip adresse is not configured as a static, if it is switch it to dynamic.
- Check that the network you are trying to connect to has a DHCP server.
- If a DHCP server exists then check it's configuration, Gateway and DNS. if you can'nt do it talk to the administrator so that he can check that.
- Check that the access point is not configured with MAC adress restriction.
- Check that the gateway is active and you have all permissions to get over internet.
Nov 27, 2010 | Computers & Internet
Sir I have 4200 series 26 ports Switch i want to Configure intra VLAN But I am Getting a problem to Configure that switch . After Cnfigure VLAN on Consol prompt. I am not accessing to my Server & WAN...
If you are creating only Layer 2 VLANs on the switch , you wont be able to ping the servers and Routers as they are in default VLAN1.
you can do the below steps
1. Create sub interfaces on the router LAN interface
2. Provide a new ip range to the new sub interface
3. Make the switch port connecting router as trunk, so that it will carry both the VLAN info
4. on your Labtop/PC give the IP address in the newly defined range
5. Make your switch port to be in the new VLAN
This will work , if you wont be able to configure the above settings, let me know i will give you the detailed config
Nov 01, 2010 | 3Com 4500 24-Port Ethernet Switch
I have win2003 i want it serover what can i do
You can do a lot with this operating system.
Some of his features are: DOMAIN Controller, Active Directory, Ftp Server, DHCP, Web Server, Terminal Server, File server etc.
Here i have some very useful links.
About Windows 2003 Server Editions: http://en.wikipedia.org/wiki/Windows_Server_2003
Futures: http://www.microsoft.com/WindowsServer2003/evaluation/features/default.mspx
Configuring DNS Server: http://www.petri.co.il/install_and_configure_windows_2003_dns_server.htm
Configuring DHCP Server: http://www.windowsreference.com/windows-server-2003/install-and-configure-dhcp-server-in-win-server-2003-step-by-step-guide/
Configuring File Server: http://www.windowsnetworking.com/articles_tutorials/File_Server_Windows_2003.html
Configure Printing Server: http://www.brightrev.com/how-to/enterprise/55-best-practices-for-setting-up-a-windows-print-server.html
Configure FTP Server: http://support.microsoft.com/kb/323384
Configure Active Directory: http://helpdeskgeek.com/how-to/windows-2003-active-directory-setupdcpromo/
Configure Web Server: http://support.microsoft.com/kb/324742
All these are only some of his features.
I hope is useful to you and your friends
Mar 13, 2010 | Microsoft Windows Server 2003 Enterprise...
3 vlans, data,1; data 2,;voip,5. Ports carry voice tagged, and data. currently Windows 2000 DHCP server lives on Vlan 1 (AND WORKS). Need to upgrade. When we test the new servers we are unable to make both...
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Aug 06, 2009 | HP ProCurve 4104gl Networking Switch
DHCP installation problem
First of all, read this M$ article on setting up DHCP: http://support.microsoft.com/kb/139904
Secondly, check the following:
1. You have defined a valid scope and ACTIVATED it
2. You have AUTHORISED the DCHP server in Active Directory (see http://technet.microsoft.com/en-us/library/cc759688(WS.10).aspx)
3. Make sure that there are enough unused IPs in the address pool
Make sure that the DHCP server service is running - and check the EVENT LOG for errors
4. Make sure that there is no other, especially unauthorized, DHCP servers (i.e. router with DHCP enabled)
Actually the best article overall to review is http://technet.microsoft.com/en-us/library/cc781697(WS.10).aspx, which gives a big picture view regarding the role of DHCP autorization and what can happen in a mixed environment
May 21, 2009 | Microsoft Windows Server 2003 Enterprise...
IP Addressing by dhcp for vlans
tell each vlan about DHCP server using
ip helper <DHCP servers ip adddress>.
in config mode.
Mar 03, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Frequent wireless disconnections 802.1X WPA TKIP
Jan 25, 2007 | 3Com Wireless LAN Access Point 7250...
Open Questions:
Random reboot of 3com 4400 stack Can you help, please? I have a 3Com 4400 stack running the latest version v6.13S. The stack sometimes reboots randomly. The logs showed the following: Unit 1 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 42 42 6.13s S/W Watchdog (r) 17 Hrs 42 Mins 52 Secs Uptime Hours 16828 Reset 41 43 43 6.13s S/W Watchdog (r) 0 Hrs 51 Mins 14 Secs Uptime Hours 16828 Reset 42 44 44 6.13s S/W Watchdog (r) 0 Hrs 47 Mins 54 Secs Uptime Hours 16828 Reset 43 45 45 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 15 Secs Uptime Hours 16828 Reset 44 46 46 6.13s S/W Watchdog (r) 0 Hrs 18 Mins 48 Secs Uptime Hours 16828 Reset 45 47 47 6.13s S/W Watchdog (r) 0 Hrs 33 Mins 59 Secs Uptime Hours 16828 Reset 46 48 48 6.13s S/W Watchdog (r) 1 Hrs 9 Mins 57 Secs Uptime Hours 16829 Reset 47 49 49 6.13s S/W Watchdog (r) 0 Hrs 59 Mins 28 Secs Uptime Hours 16829 Reset 48 50 50 6.13s S/W Watchdog (r) 0 Hrs 42 Mins 37 Secs Uptime Hours 16829 Reset 49 51 51 6.13s S/W Watchdog (r) 20 Hrs 17 Mins 57 Secs Uptime Hours 16849 Reset 50 52 52 6.13s S/W Watchdog (r) 0 Hrs 5 Mins 19 Secs Uptime Hours 16849 Reset 51 53 53 6.13s S/W Watchdog (r) 0 Hrs 55 Mins 15 Secs Uptime Hours 16849 Reset 52 54 54 6.13s S/W Watchdog (r) 0 Hrs 37 Mins 23 Secs Uptime Hours 16849 Reset 53 55 55 6.13s S/W Watchdog (r) 1 Hrs 26 Mins 17 Secs Uptime Hours 16850 Reset 54 56 56 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 12 Secs Uptime Hours 16851 Reset 55 57 57 6.13s S/W Watchdog (r) 17 Hrs 26 Mins 34 Secs Uptime Hours 16868 Reset 56 Assertions : Id S/W Rel File Name Line 5 3.00 agg_sma.c 1215 6 3.00 agg_sma.c 1215 7 3.00 agg_sma.c 1215 8 3.00 agg_sma.c 1215 9 3.00 agg_sma.c 1215 10 3.00 agg_sma.c 1215 14 3.00 agg_sma.c 1215 Last System Error Data: ID (57) S/W Rel (6.13s) Reason (S/W Watchdog) Unit 2 Watchdog handler is RESET The History Log Id No S/W Rel Reason UpTime SysErr 236 236 6.13s S/W Watchdog (r) 0 Hrs 10 Mins 55 Secs Uptime Hours 48145 Reset 235 237 237 6.13s S/W Watchdog (r) 2 Hrs 2 Mins 20 Secs Uptime Hours 48147 Reset 236 238 238 6.13s S/W Watchdog (r) 0 Hrs 29 Mins 15 Secs Uptime Hours 48147 Reset 237 239 239 6.13s Power (r) 2 Hrs 0 Mins 0 Secs Uptime Hours 48149 Reset 238 240 240 6.13s S/W Watchdog (r) 17 Hrs 5 Mins 9 Secs Uptime Hours 48166 Reset 239 241 241 6.13s S/W Watchdog (r) 2 Hrs 55 Mins 1 Secs Uptime Hours 48168 Reset 240 242 242 6.13s Power (r) 3 Hrs 0 Mins 0 Secs Uptime Hours 48171 Reset 241 243 243 6.13s S/W Watchdog (r) 91 Hrs 47 Mins 28 Secs Uptime Hours 48262 Reset 242 244 244 6.13s S/W Watchdog (r) 45 Hrs 25 Mins 25 Secs Uptime Hours 48307 Reset 243 245 245 6.13s S/W Watchdog (r) 4 Hrs 29 Mins 38 Secs Uptime Hours 48311 Reset 244 246 246 6.13s S/W Watchdog (r) 117 Hrs 3 Mins 10 Secs Uptime Hours 48428 Reset 245 247 247 6.13s S/W Watchdog (r) 0 Hrs 32 Mins 9 Secs Uptime Hours 48428 Reset 246 248 248 6.13s S/W Watchdog (r) 3 Hrs 11 Mins 54 Secs Uptime Hours 48431 Reset 247 249 249 6.13s S/W Watchdog (r) 20 Hrs 52 Mins 50 Secs Uptime Hours 48451 Reset 248 250 250 6.13s S/W Watchdog (r) 3 Hrs 5 Mins 37 Secs Uptime Hours 48454 Reset 249 251 251 6.13s S/W Watchdog (r) 1 Hrs 42 Mins 13 Secs Uptime Hours 48455 Reset 250 Assertions : Id S/W Rel File Name Line 129 6.10s lazy_ack.c 890 137 6.10s poller.cc 1104 138 6.10s poller.cc 1104 152 6.10s lazy_ack.c 890 158 6.10s lazy_ack.c 890 159 6.10s lazy_ack.c 890 169 6.10s lazy_ack.c 890 170 6.10s lazy_ack.c 890 173 6.10s lazy_ack.c 890 175 6.10s lazy_ack.c 890 187 6.10s lazy_ack.c 890 191 6.10s lazy_ack.c 890 199 6.10s lazy_ack.c 890 208 6.13s lazy_ack.c 890 209 6.13s lazy_ack.c 890 225 6.13s lazy_ack.c 890 Last System Error Data: ID (251) S/W Rel (6.13s) Reason (S/W Watchdog)
May 14, 2009 | 3Com SuperStack 3 4400 (3C17204-US)...
3Com SuperStack 3 4400 (3C17204-US) 48x10/100 Mbps Networking Switch Logo
163 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
