Generic problem for all TV Receivers and DVRs
Celestial HD Digital Television Receiver DVB8800HD (by 2 users)
posted by CathGill on Jul 24, 2008
Hi - my husband's connected the box as per the diagram (and we have a DVD player as well) - what next? There are no other instructions in the box apart from the connection diagram. I've turned it on via the remote - could you pls give us some idea of where to go next? Thanks & regards - Cath
1 Other User Has The Same Problem
Comment by laurnic, posted on Jul 30, 2008
We have connected the Celestial HD Receiver in Component mode but when we see the menu on the TV screen it is split into 7 columns. I was able to guess my way down the menu to auto scan, which seemed to work but the split screen problem is still there. Could it be our TV? It's an LG Flatron Model RT28FZ10RX bought in late 2002. Thanks.
Solution #1
posted on Jul 25, 2008
Normally, there are 2 ways to hook these devices up. One is the component cable that has 3 colors, red white and yellow. these color codes match an aux. input on the TV (or vid1 or vid2) You need to change the TV input to whichever you used by the remote or maybe under Ch2 (4,3,2,vid2, vid1, aux,111,110,etc) The other way is to use the round 4-5 pin S-video instead of the yellow jack, that is self explanetory. The 3rd way and this depends on your TV and receiver is to use the HDMI, composite or DVI cable connection. These are only for Hi def players and will be either a large multi-pinned computer type plug, 5 colored/lead "octopus" cable, or a smaller D shaped high density cable with the row of contacts inside the plug. In any case you need to tell the TV which input you are using.
Once you get the TV to show a picture of the receiver, then you autoprogram the receiver with the remote under setup or other menu.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for TV Receivers and DVRs
Email this problem
Email this problem
This Problem Also Relates To:
Motorola HDT101 DTV Receiver
Remington 02550WD 800-Hours Video Recorder
Rio ReplayTV 5504 40-Hours Video Recorder
Sony LocationFreeŽ LF-B10 Digital Media Streamer
Sony CPF-IX001 Digital Media Streamer
Bosch DVR16E2302 Video Recorder
Bosch DVR16F2162 Video Recorder
Can you Help with these TV Receivers and DVRs problems?
Ikasu DVR3031 unlock code...
Hi all, I have just received an... Answer This...
Samsung SIR-S300W DirecTV DTV Receiver
unlocking parental lock
I just reactivated a reciever... Answer This...
Sagem PVR 6280 Freeview DTV Receiver /...
18th Aug update accepted and...
On the last update when I... Answer This...
Repair Service
Find TV Receiver and. Repairman Near You:
