Hi, I want to use my H.P Deskjet 520 (mono-printer) to print standard paper with a spirit-based and colourless solution that contains a percentage of 'linseed oil'. However the linseed oil is clogging the print-cartidge-jets. Can anyone assist in solving this problem ?? I'm offering a financial reward for the correct answer of £100 / US$200 This REWARD could be DOUBLED, Best regards. Edd.
    Novelist:
    Scholar:
  • 125 Answers
I'm not sure why you need to use a solution w/ linseed oil. But the cartridge is not designed for oil based printing. It's original use is for water based dye inks. So any oil based or oil mixed product will eventually clog the jet sooner or later. Since you are printing w/ this I can only guess you are planning to coat the surface of the paper. There is another chemical that might be available w/ one of your ink manufacturers that is used to refill some Epson cartridges that they use to do a kind of gloss coating on paper. Using a printer to spot coat an area is possible. But most people just roller brush the whole sheet. It's faster than using the inkjet printer.
Posted on Jul 24, 2008
Why can't I insert ink cartage in slot?
please open the door of printer and push the cartridge slowly and then the cartridge push down, the cartridge come out.repeat this same process to insert new ink cartridge.
Oct 01, 2015 | HP Deskjet 2540 Inkjet Multifunction...
How do i get printing drivers for this machine
Dear
the driver may downloaded from the site on putting the model.
http://support.hp.com/us-en/drivers
Thanks.
Feb 15, 2015 | HP Deskjet 1510 Inkjet Multifunction...
How do i put in the ink carrages
Lok at :
1-YouTube
2-or this http://www8.hp.com/h20621/video-gallery/us/en/customer-care/printers-and-all-in-ones/replace-ink-and-toner/2868853667001/replacing-a-cartridge---hp-deskjet-2540-all-in-one-printer/video/
Feb 12, 2015 | HP Deskjet 2540 Inkjet Multifunction...
How do I insert new cartridge into HP desktop 1510
Easy answer , though this here isn't your answer but try googling it or you tube. I've always found answers there.
Good luck !
Jan 02, 2015 | HP Deskjet 1510 Inkjet Multifunction...
Why does my HP OfficeJet L7780 print blank copy with the regular copy
This is normally caused by a driver issue. Check that your device driver is correct for this particular machine.
Oct 19, 2014 | HP Officejet Pro L7780 All-in-One -...
Installing hp 1510e, plugged cable, wiil not recognize
then try to install manually, under Windows click add new printer,...
then find your printer on list and choose it.... and install it....
use drivers either to load by Windows automatically, or use path to your CD with software and drivers
Jan 13, 2014 | HP Deskjet 1510E Inkjet Multifunction...
Lost instructions. What cartridges does printer
Here is the manual for your printer with instructions:
http://www.lexmark.com/publications/eng/7100/index.html
Here is the full spec info on your printer.
Print Resolution:
4800x1200 dpi best mode - Photo paper
2400x1200 dpi best mode - All other media
Print Speed:
mono draft mode 22 ppm
color draft mode 15 ppm
Copy Speed:
color draft mode 14 ppm
Fax Speed:
33.6 Kbps
Cartridge Compatibility:
  • Black: Moderate Yield – 32
  • Black: Standard Yield – 34
  • Color: Moderate Yield – 33
  • Color: Standard Yield – 35
  • Photo: Standard Yield – 31
Connectivity:
USB only
Media Handling:
Paper: Up to 150 sheets (20 lb or 75 g/m2 bond)
  • Envelopes: 15 envelopes
  • Labels: 35 sheets
  • Transparencies: 75 transparencies
  • Hagaki: 45 cards
  • Card stock: 35 sheets
Size & Weight:
490.8mm x 422.7mm x 305.4mm (W x D x H)
9.34kg
Scan Resolution:
  • Optical: 1200ppi
  • Interpolated: 19,200 x 19,200
Jan 08, 2010 | Lexmark X7170 All-In-One InkJet Printer
Can't get instuctions for my paper feed cleaning kit!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry. Keep printer unplugged for about 2 minutes and replug and try a test print. Also make sure that you have waited long enough for the printer to heat up before giving a print job. Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Thanks
Thiru
Jun 15, 2009 | HP DeskJet 520 InkJet Printer
HP 520 Desk Jet printing garbage
fot resolve this issue you should try that get a self test print ,( demo print) if it is good you have a software problem and also you should install the dirvers . if the demo test print is not good you have a hardware problem about carriage and ink system and you have to replace the carriage system.
Jan 26, 2009 | HP DeskJet 520 InkJet Printer
113 people viewed this question
jasbo
jasbo
