Question about Fuji FinePix S5000 Digital Camera
Fuji FinePix S500
Camera has been working fine no problems like the images and the camera too. I have not used the camera for some months no batteries were left in it. Upon putting batteries in read the memory card and set up with date etc no problems. When I went to use the camera had a white screen seemed that it was being flooded with light when try to take photograph the camera shuts down but the lens stays retracted. Seems that it is safety feature of the camera. Nothing shows up view finder now and cuts out immediately camera lens has deployed. Is it fixable or time to buy a new camera?
Thanks
  • gewilke Jul 28, 2008
    Hello. I am having the same problem. I have tried new batteries and it did not help. The camera works ok inside but not outside in bright light.
  • Anonymous Dec 15, 2008
    I have the same problem; how do I get this issue resolved?
  • 188 Answers
Try using it with fresh pair of fully charged batteries.
Posted on Jul 25, 2008
I have this same problem..my fuji finepixa500 got white screen i dont how it come like this...what i gonna do?
Posted on May 07, 2011
  • 74 Answers
Count me in on this problem... Extremely washed out/white image on mine. New batteries did not help.
Posted on Aug 23, 2008
Turned my fuji finepix camera on today and the screen remains white and I get no image of the scene in view. The batteries are fine and all the remaining functions such as menu items all work fine. The...
The iris may have stuck closed due to moisture or the CCD may be bad. Let it dry out for about a day if the iris is stuck. If you still can't get an image, then more likely the CCD is bad - take it in for repair.
Dec 14, 2010 | Fuji FinePix S5500 Digital Camera
Fuji Finepix F30 Suddenly takes only all pink screens (no image)
This sounds like one of two problems -
Either an LCD screen problem or a bad CCD sensor.
A LCD screen problem would indicate one of two of the following - it was cracked, or the cable inside is either damaged or moved out of the plug and need to be reseated.
A bad CCD sensor would show a pink screen on cameras, but would also show menus on the screen as well, do you see those? The CCD basically captures the image the lens is seeing and translates it to an image the camera can save. Generally the CCD can not be replaced separately from the lens and will require an entire lens assembly for repair.
Mar 16, 2010 | Fuji FinePix F30 Digital Camera
Fuji FinePix S1000fd Digital Camera, freezes!
We have the same problem. Less than 6 months after using it the flash seems to lockup the camera and the only way to free it up is to remove the batteries.
Hopefully someone has a solution or answer.
Jan 16, 2009 | Fuji FinePix S1000FD Digital Camera
Fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac.  I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
Sep 09, 2008 | Fuji FinePix J10 Digital Camera
Fuji Finepix 3800
The date time problem ist he internal battery[ A watch type button inside the camera body]
has worn out- replacing it will be a workshop job.
The other problem seems like wear and tear on the switch any repair will be costly.
Just live with[out]it- or buy a new camera
Nov 20, 2007 | Fuji FinePix 2800 Zoom Digital Camera
Fuji Finepix F31fd - Write error; then power problem
As it was a write error, it could be that your card is corrupted. What you could do is to backup all of the images from the card to your computer, then re-format the card in the camera, so at least all your images are safe. Then, if the problem occurs again, contact Fuji.
Mar 10, 2017 | Fuji Finepix F31FD Digital Camera
My computer will no longer recognize the camera
Maybe you need to add a software driver for your FinePix 2800, got a disk with the camera? Try loading (reloading?) the driver.
Jun 11, 2007 | Fuji FinePix 2800 Zoom Digital Camera
A BATTERY PROBLEM WITH THE FUJI S500
Old motors and mechanism is eating too much power, thats what you will expect after three or more years using your unit. Digital cameras lasts for about three years working in good condition, after that expect your head to turn using that cam.
Oct 04, 2006 | Fuji FinePix S5000 Digital Camera
NEW Batts but keep getting low batt indicator and....
Sorry, no solution. Same problem here. I am very unhappy because initially it took great pictures. The first one I tried only worked a couple of days and I returned to store and they replaced. Second worked a couple of months and now immediately draws down power and won't work on new batteries. I was told to use NH-10 batteries (rechargeable). I did this from the beginning. Still won't hold charge.
Jul 29, 2006 | Fuji FinePix A340 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
862 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
