Question about Gigabyte GA-K8NXP-SLI Motherboard
Ga-k8nxp-sli troubleshoot wen i start my computer up there is 1 long beep then a shoot beep and then after the the long beeps keeps coming and wont PLEASE HELP
  • Anonymous Jul 24, 2008
    wen i start my computer 4 the 1st time after installing my new hardware (ddr 512x2, ga-k8nxp-sli mother board, amd athlon 64 bit 3200, 7900 gtx grphics) my computer turned on but the screen neva came on there was no beeps from the motherboard so i turn it off and had a look at the compoments to see if they were all pushed in properly and then turn back on then it had a long beep then a short beep and a long beep as the st 1 and contunes like every 3 secs any ideas please help
    Sergeant:
  • 458 Answers
Check your memory.
Posted on Jul 24, 2008
GA-H77M-D3H 6 beeps on POST and then restarts
Check timing between each beep---Make sure It's 6 Even beeps--Not 3+3--1+5--2+4 ect----Timing between beeps will tell you---let me know.
Mar 01, 2014 | Gigabyte GA-H77M-D3H Socket 1155/ Intel...
Powers up ,but no bios beep or video ,displays error 50 on pc analyzer
Accordin to manual: Error Code – 50
Phoenix (50)Display CPU type and speed.(Beep)=2-2-1-1.(50)Per- form LSL instruction test.[Beep]=none Custom chip set or custom platform.
The POST process stop detecting CPU.
M2N-E SLI use Award/Phoenix BIOS.
Oct 19, 2009 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
When I turn on my computer i hears a few double beeps and I don't see anything on my monitor while computer sounds like it running
Here is a link for with some information for the GA-M55plus-S3G motherboard:
http://china.giga-byte.com/FileList/Manual/motherboard_manual_ga-m55plus-s3g_3.x_e.pdf
The below was taken out of the document:
The beep codes below may help you identify the possible computer problems. However, they are
only for reference purposes. The situations might differ from case to case.
�� AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Jul 07, 2009 | Gigabyte GA-M55plus-S3G Motherboard
I have no sound
hi try to go to the oficcial site which support all drivers u need for ur mother boad so install al of them to verify if it works or not http://www.gigabyte.com.tw/Support/Motherboard/Driver_Model.aspx?ProductID=1859
Jun 08, 2009 | Gigabyte GA-K8NXP-SLI Motherboard
Bios wont start. 1 long beep 2 short
You are going to need to lookup your BIOS version and manufacturer and find the Beep codes list. each BIOS has non beep codes and beep codes. the beep codes are bad. find out what this code means and do as they say if you dont know how to find what BIOS version your running Goole "What BIOS am i runninng?"
Once you have that like i said google it and its beep codes and if you cant find it ill help
Apr 09, 2009 | ASUS M2N-E SLi Motherboard
Motherboad processor getting hot,new fan change,powersupply change & ram change but its still too hot plz what that problem u can tel me
install orinal fan of intel or cpucoolar .............and check your prosser is cool ...ok and all problem in mother board in prosser panal .................
Mar 19, 2009 | Gigabyte GA-K8NXP-SLI Motherboard
Ga-k8nxp-sli problem
you have a hardware fault try removing 1 set of memory test if not work try different video card suspect one or other wrong
Jul 24, 2008 | Gigabyte GA-K8NXP-SLI Motherboard
Asus m2n sli motherboard
That single beep is most likely POST. Power on self test. You're board, Asus M2N-E SLI uses an Award bios. The beep error codes can be found at this link: http://www.bioscentral.com/beepcodes/awardbeep.htm
If you are using a single PCI-E card, check that you have the bios set correctly. Shown on page 4.4.6. Do you have you're memory in slot A-1 & A-2? Check that you have PCI-E set for primary display adapter, pg 4.4.4
For windows XP Pro with out SP2, please disale ACPI in you're bios. After SP2 & updates, you can turn it back on. It's realy odd that you're high power PSU did not come with an ATX 4-pin_12v connector for the board. (Needed for CPU).
This is a standard feature for current PSU's. Can you swap the PSU? Considering what devices you are running. You can easely run a 350w PSU? This swap would only be used as a test. Next test, go into the bios & go to Advanced, CPU configuration, check hardware monitor. Stay here a bit & watch temp settings.
Go over these suggestions. Let me know if any one of these suggestions has helped? Can you see the drive in you're bios?
Luck!
M
Jun 06, 2008 | ASUS M2N-E SLi Motherboard
Gigabyte motherboard AMD 2000+
Ok these beeps indicate an error they can be decoded... I have posted a link below to help with this all. You must identify what BIOS manufacturer your board uses to decode the Beeps correctly http://articles.techrepublic.com.com/ 5100-6349-1054916.html
Sep 05, 2007 | Gigabyte GA-K8NXP-SLI Motherboard
Wont even load onto bios.
you could be right but it's hard defining beeps but i would reseat your memory and graphics card as 1 long and 3 short beeps refers mainly to graphics
Aug 28, 2007 | ASUS A8N-SLI Premium Motherboard
Gigabyte GA-K8NXP-SLI Motherboard Logo
116 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
